Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 08-30-2015, 21:03   #1 (permalink)
Member: 2131029
Thanks Meter: 4
Thumbs up HTC M8_UL S-OFF and Write super CID
30/08/2015 09:49:54 م Phone connected [FA51DWM01765]
30/08/2015 09:49:55 م Sending oem writesecureflag 0
30/08/2015 09:49:55 م ... (bootloader) SecuritySDInit: counter = 2
(bootloader) m8_init_sd, SD card already power on
(bootloader) [SPEW] GPIO 0 status is 0
(bootloader) sdhci_open: id=0
(bootloader) Initializing MMC host data structure and clock!
(bootloader) mmc slot#2 clock enabled
(bootloader) sdhci_set_clock: slot 2, freq 192000000
(bootloader) GPLL0 is enabled
(bootloader) clock_update_cfg_sd is done
(bootloader) sd clock set done
(bootloader) sdhci_set_bus_width: bus width 0
(bootloader) sdhci_clk_supply: freq 400000
30/08/2015 09:49:56 م (bootloader) Error: Command never completed
(bootloader) Error: Command timeout error
(bootloader) Error: Command completed with errors
(bootloader) The response for CMD8 does not match the supplied value
(bootloader) Decoded CID fields:
(bootloader) Manufacturer ID: 7f
(bootloader) OEM ID: 0x0
(bootloader) Product Name: 5270
(bootloader) Product revision: 5.2
(bootloader) Product serial number: B4E
(bootloader) Manufacturing date: 2 2015
(bootloader) sdhci_clk_supply: freq 50000000
(bootloader) sdhci_set_bus_width: bus width 1
(bootloader) Done initialization of the card
(bootloader) erase_grpsize: -16777216
(bootloader) erase_grpmult: 261078256
(bootloader) wp_grpsize: 1
(bootloader) wp_grpen: 1
(bootloader) perm_wp: 0
(bootloader) temp_wp: 0
(bootloader) [Tuxera][Error] No exFAT partition found
30/08/2015 09:49:59 م (bootloader) writesecureflag: KeyCard remain count 10000
(bootloader) PID:272
(bootloader) Start Verify: 3
30/08/2015 09:50:00 م (bootloader) [PGFS] partition_update_pgfs: pg1fs_security
(bootloader) TZ_HTC_SVC_ENC ret = 0
(bootloader) [PGFS] partition_update_pgfs: pg2fs_sec_recovery
Execution time is 4309(ms)
OKAY
30/08/2015 09:50:00 م Operation finished
30/08/2015 09:50:08 م Sending reboot-bootloader
30/08/2015 09:50:08 م Execution time is 13(ms)
rebooting into bootloader... OKAY
30/08/2015 09:50:08 م Operation finished
30/08/2015 09:50:09 م Phone DISconnected
30/08/2015 09:50:13 م Phone connected [FA51DWM01765]
30/08/2015 09:50:18 م Sending oem writecid 11111111
30/08/2015 09:50:18 م ... (bootloader) Start Verify: 0
(bootloader) Input CID is super CID
Execution time is 32(ms)
OKAY
30/08/2015 09:50:18 م Operation finished
Page generated in 0.11447 seconds with 9 queries
