08-09-2015, 02:07 | #20 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2335578 Status: Offline Thanks Meter: 105 | Starting bootloader unlock procedure Phone detected, reading token... Error: Unexpected token format: ... (bootloader) [KillSwitch] : /dev/block/bootdevice/by-name/frp (bootloader) [KillSwitch] Last Byte is 0X00, disable unlock (bootloader) [KillSwitch] oem unlock Turn Off! Execution time is 87(ms) OKAY |
08-09-2015, 07:12 | #23 (permalink) |
Junior Member Join Date: Jul 2015
Member: 2420279 Status: Offline Thanks Meter: 22 | I tried the unlock on my Verizon M8, with CID VZW__001, and got the following output Starting bootloader unlock procedure Phone detected, reading token... Token detected successfully Checking server connection... Communicating with the XTC 2 Clip ... Connecting to the server... Waiting for the server to process request, it may take up to 5 minutes... Your request was processed successfully! Unlock token has been obtained Sending flash unlocktoken unlocktoken_HT435SF03725 . bin Execution time is 151(ms) sending 'unlocktoken' (0 KB)... OKAY writing 'unlocktoken'... FAILNot support on this device! FAILED (remote: Not support on this device!) Error: The unlock token was not accepted by the phone. Try to re-calculate it again. So, first of all it failed for some reason. Also, I'm wondering if it had been successful, would it have wiped my data? P.S. There was no spaces between "unlocktoken_HT435SF03725 . bin" - but with only 3 posts, the forum thinks it is a link. |
08-09-2015, 10:57 | #24 (permalink) |
No Life Poster Join Date: Sep 2008 Location: India
Member: 851193 Status: Offline Sonork: 100.1615313 Thanks Meter: 348 | https://forum.gsmhosting.com/vbb/****************************/?2601t7azottbj1y xtc2tool_1.07_setup - Download - 4shared hope this will helpful for users |
The Following User Says Thank You to kariakala For This Useful Post: |
08-10-2015, 14:20 | #27 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
Some firmware/hboot versions do not allow bootloader unlock. Usually you can simply reflash with any other generic firmware and then do the unlock. And yes, it will wipe the data as it's needed for the unlocking process to be done, sorry. | |
The Following User Says Thank You to xtc2clip For This Useful Post: |
