09-26-2016, 19:38 | #16 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
http://forum.gsmhosting.com/vbb/f961...-step-1964502/ | |
02-21-2017, 13:53 | #20 (permalink) |
Freak Poster Join Date: May 2003 Location: Poland Age: 46
Member: 27843 Status: Offline Sonork: 100.1646294 Thanks Meter: 26 | after repair clip program works, but the clip does not want to give log: simlock\ open MCCMNC file fail Open IMEI file fail Open ATSDEB file fail Open SF file fail Open NAME file fail PROCESS DONE, reboot device? after that always did the S-off and unlock and now nothing happens several different phones |
02-21-2017, 18:24 | #21 (permalink) | |
Do you use Y cable or direct to SD slot ? | |
06-14-2017, 18:13 | #24 (permalink) |
Junior Member Join Date: Apr 2015
Member: 2377876 Status: Offline Thanks Meter: 3 | Unlock Htc One S Fail Hi Guys.. i bought the Xtc2Clip some months ago... im trying to use it for first time, unlocking an HTC One S and this is the Log: SD init OK Reading config. dat (37) Bytes Read MCCMNC file success Open CID file fail Open IMEI file fail Reading sf. txt (1) Bytes Read SF file success Open NAME file fail Please, i need your help!!! |
06-14-2017, 18:20 | #25 (permalink) | |
Does it hang on this stage? Please remove config.dat (uncheck simlock in SD editor) and leave only sf.txt, then try again. | |
06-14-2017, 19:28 | #26 (permalink) |
Member: 2377876 Status: Offline Thanks Meter: 3 | Thanks for the quick reply... yes, it hangs in that stage... As I said, i'm new with this tool. Removing config. dat means manually do it in windows file explorer or editing SD and saving from xtc2Clip tool?? Thanks again |
06-14-2017, 20:04 | #29 (permalink) |
Member: 2377876 Status: Offline Thanks Meter: 3 | Ok, manually removed config. dat from xtc2clip storage... this the log: SD init OK Open MCCMNC file fail Open CID file fail Open IMEI file fail Reading sf. txt (1) Bytes Read SF file success Open NAME file fail and it hangs in that stage |
