06-30-2015, 20:27 | #1 (permalink) |
Freak Poster Join Date: Aug 2010 Location: USA
Member: 1361178 Status: Offline Thanks Meter: 95 | xtc2clip no work [solved] Sending oem writesecureflag 0 ... (bootloader) [JAVACARD_ERR] SD/USBDISK Init error (bootloader) writesecureflag: Permission denied, value 1 Execution time is 281(ms) OKAY Operation finished offline mode: |
06-30-2015, 22:39 | #3 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | You must connect clip before powering phone on. Otherwise you have to press 'reboot bootloader' prior to using direct mode. |
The Following 2 Users Say Thank You to xtc2clip For This Useful Post: |
07-01-2015, 08:50 | #5 (permalink) | |
No Life Poster Join Date: Jan 2010 Location: China
Member: 1222089 Status: Offline Sonork: 100.1583019 Thanks Meter: 2,688 | Quote:
Try also offline method http://forum.gsmhosting.com/vbb/f961...steps-1964502/ | |
07-01-2015, 09:16 | #6 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2335578 Status: Offline Thanks Meter: 105 | Sending oem readsecureflag ... (bootloader) read secure flag: 3 cause my phone was s-off before I put hook to box now it won't s-off or flash ruu or download mode will not change to s-off |
07-01-2015, 10:32 | #7 (permalink) | |
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
2. The good idea is: a) power off phone b) connect clip to phone c) power on phone in bootloader mode d) goto fastboot mode using phone menu e) Use XTC2Tool in direct mode and use "Write security flag" and set it to 0. f) Post result here. | |
07-01-2015, 10:47 | #8 (permalink) | |
1. You cannot turn phone to S-ON just by "hooking the box" 2. Some commands and one some phones like writecid will turn S-ON, you simply need to do S-OFF after this. 3. Please post your model and the way you are trying to S-OFF, your logs only shows that you are reading the security flag. And next time please be so kind to create a separate thread for your problem to help us to support you better. | |
07-01-2015, 11:08 | #9 (permalink) |
Member: 2416253 Status: Offline Thanks Meter: 4,162 | You can flash it to original firmware and it will remove the tamper flag. However, we will consider adding this feature to the nearest updates. The flag itself doesn't affect the way your phone works, and if you are intended to take it to your service center, you should know that they will detect modified firmware even without the tamper flag and may refuse to service it. So if you need to pass it to service center, it's always good to reflash with original firmware. |
07-01-2015, 15:27 | #10 (permalink) | |
Member: 1361178 Status: Offline Thanks Meter: 95 | Quote:
07-01-2015, 15:31 | #11 (permalink) | |
07-01-2015, 15:50 | #12 (permalink) | |
You may try to reset your clip using this procedure: http://forum.gsmhosting.com/vbb/f961...t-etc-1964648/ | |
07-01-2015, 15:58 | #13 (permalink) | |
direct mode: Sending oem writesecureflag 0 ... (bootloader) [JAVACARD_ERR] SD/USBDISK Init error (bootloader) writesecureflag: Permission denied, value 1 Execution time is 281(ms) OKAY Operation finished i know how to use because i have java card, same card reader java card work xtc2clip not, try to repair the filesystem and will post the results thanks | |
07-01-2015, 16:07 | #14 (permalink) | |
And what do you mean by "same reader java card work" - are you saying that your clip is not detected on computer? | |
07-01-2015, 17:13 | #15 (permalink) | |
... (bootloader) vreg_set: request is duplicated id 14 (bootloader) ruby_init_sd, SD card power on ok (bootloader) [SD_HW_ERR] SD: No device attached (bootloader) [JAVACARD_ERR] SD Init error (bootloader) writesecureflag: Permission denied, value 1 Execution time is 2250(ms) OKAY Operation finished Phone connected ! flex changed, filesystem repaired now what? Last edited by onaikel; 07-01-2015 at 17:15. Reason: add | |
