03-12-2016, 15:19 | #1 (permalink) |
No Life Poster Join Date: Sep 2013 Location: INSIDE YOUR MIND
Member: 2025428 Status: Offline Thanks Meter: 445 | Bontel 225 password remove done in sec Code: Action : Format / Reset Boot : SC6531-NOR Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found : SCI USB2Serial (COM3) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... FDL test...OK SC Boot Ver : 6531 SC Boot Mode : 6531000100005A00 Loading CST Boot image to RAM... The CST Boot runs normally. CHIP : 65310001 CPU ID : 65310001 NOR ID : 00C8006000160000 NOR Size : 4MB NOR Name : SF_GD27Q32 Boot Information completed. Reading FileSystem info... FileSystem Version: 80 Start=0x003B0000, Size=0x00050000 Erasing ... The eraser is completed. Action completed Time taken : 00:00:13 Reconnect Battery/USB Cable CS-Tool Ver 1.40.1 Code: Action : Read Flash Boot : SC6531-NOR Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found : SCI USB2Serial (COM3) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... FDL test...OK SC Boot Ver : 6531 SC Boot Mode : 6531000100005A00 Loading CST Boot image to RAM... The CST Boot runs normally. CHIP : 65310001 CPU ID : 65310001 NOR ID : 00C8006000160000 NOR Size : 4MB NOR Name : SF_GD27Q32 Boot Information completed. Dumping Flash Image Now... Flash Image size : 4.00MB Saved to: C:\Users\JOHNOROO37\Documents\CS-TOOL READED FILES\BONTEL--225_-FUL-FILE-CSTOOL.cst Dumping Flash Image Completed. Action completed Time taken : 00:00:34 Reconnect Battery/USB Cable CS-Tool Ver 1.40.1 PICS AFTER EVERY |
The Following 2 Users Say Thank You to johnoroo37 For This Useful Post: |
