Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > CS-Tool
Old 05-24-2021, 09:18   #1 (permalink)
kavithamobiles's Avatar
Member: 1874918
Sonork: 100.1605418
Thanks Meter: 65
Arrow Coolpad note3 plus 8676-103 flash atfer dead need working firmware
flashing time forgot to untick pre loader after flash set dead need correct solution
Old 05-24-2021, 09:57   #2 (permalink)
Member: 1874918
Sonork: 100.1605418
Thanks Meter: 65
Card found : S/N : 8C8B1321 , v0136
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 484A01906532474131040705551B6CB8
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , e2GA
[eMMC] : FLASH_CID : 90014A484147326505070431B86C4355
[eMMC] : FLASH_LEN : 0x00000003AB800000
[eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB]
DEV RID : 0xF4DD27339CE03367F91CFDA0F4CE0B72
INT RAM : 0x00020000
EXT RAM : 0xC0000000 [3 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Error read initial info! Make "Identify" first!
Operation Failed
Elapsed: 00:00:08
Reconnect Power/Cable!
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Info read not done Erased/damaged phone?
Done!
Elapsed: 00:00:10
Operation : Reset Privacy Lock [ v1.58 ]
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Error read initial info , erased flash or wrong init?
Done!
Elapsed: 00:00:11
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Operation Failed
Elapsed: 00:00:08
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Operation Failed
Elapsed: 00:00:10
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Operation Failed
Elapsed: 00:00:07
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Operation Failed
Elapsed: 00:00:07
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Operation Failed
Elapsed: 00:00:07
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Operation Failed
Elapsed: 00:00:07
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:12
Operation : Repart User Memory [ v1.58 ]
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
That device not have free internal memory for repartition!
Done!
Elapsed: 00:00:11
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Operation Failed
Elapsed: 00:00:11
Scatter Load Ok , BaseBand : MT6753 , Project : CP8676_I03 , Storage : EMMC
Files found : 15 , Set to Flash : 14
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6753 , Project : CP8676_I03 , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3825 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 1
Erase : 0x0000000001C80000-0x0000000127380000
Flash Pre-Erase Done, time used : 00:00:00
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader.bin
Preloader Sent , Init passed
PartCount : FFFFFFFF
PartErr : Not initialized , will update PMT now ...
[SpecOp] : Extend UserArea
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : LK
Image Flash Ok
Flash now : BOOT
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : YL_PARAMS
Image Flash Ok
Flash now : AUTOBAK
Image Flash Ok
Flash now : PANIC
Image Flash Ok
Flash now : LK_BAK
Image Flash Ok
Flash now : SECRO
Image Flash Ok
Flash now : TEE1
Image Flash Ok
Flash now : TEE2
Image Flash Ok
Flash now : SYSTEM
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USERDATA
Image Flash Ok
Flash Write Done, time used : 00:04:38
Processing : Verify
Verify Passed : LK
Verify Passed : BOOT
Verify Passed : RECOVERY
Verify Passed : LOGO
Verify Passed : YL_PARAMS
Verify Passed : AUTOBAK
Verify Passed : PANIC
Verify Passed : LK_BAK
Verify Passed : SECRO
Verify Passed : TEE1
Verify Passed : TEE2
Verify Passed : SYSTEM
Verify Passed : CACHE
Verify Passed : USERDATA
Data Verify Done, time used : 00:00:35
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:05:30
Flashing done but phone cant turn on
Old 05-24-2021, 09:57   #3 (permalink)
Member: 1874918
Sonork: 100.1605418
Thanks Meter: 65
Flash now : LK
Image Flash Ok
Flash now : BOOT
Image Flash Ok
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Image Flash Ok
Flash now : AUTOBAK
Image Flash Ok
Flash now : PANIC
Image Flash Ok
Flash now : LK_BAK
Image Flash Ok
Flash now : SECRO
Image Flash Ok
Flash now : TEE1
Image Flash Ok
Flash now : TEE2
Image Flash Ok
Flash now : SYSTEM
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Image Flash Ok
Processing : Verify
Verify Passed : LK
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:05:30
Page generated in 0.18409 seconds with 8 queries
