12-30-2015, 09:05 | #1201 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | mobicell petro theft lock done http://i.imgur.com/gDToPUv.png Action : Reset Privacy Lock Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM31 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 90014A483447316404 CHIP : MT65720000 CPU ID : EMMC ID : 90014A483447316404 EMMC Size: 4GB, usable capacity: 3.65GB EMMC Name: eMMC_Hynix_H9TP32A8JDACPR_KGM Read Hardware Information is done. Removing privacy lock ... Done. Action completed Time taken : 00:00:08 Reconnect Battery/USB Cable CS-Tool Ver 1.38 |
12-30-2015, 13:11 | #1203 (permalink) |
Crazy Poster Join Date: Oct 2009 Location: Eh Tan Rab Nu Pta Age: 39
Member: 1145569 Status: Offline Sonork: 373cbd71b5eb99f4e3001d009 Thanks Meter: 24 | Samsung Original B310 Phone Lock Read Done Action : Read Codes Boot : SC6530-NOR Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (bootkey's Volume Down or volume up) Waiting for Phone Usb.... Phone found : SPRD U2S Diag (COM44) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... FDL test...OK SC Boot Ver : 6530 SC Boot Mode : 6530C00000005A00 Loading CST Boot image to RAM... The CST Boot runs normally. CHIP : SC6500E CPU ID : 6530C000 NOR ID : 00C8006000170000 NOR Size : 8MB NOR Name : SF_GD27Q64 Boot Information completed. Reading Locks Location.. [code]: 91946332 [PhoneLock]: 3325612 [PhoneLock]: 1313 [code]: 17010 [code]: 12630088 [code]: 543212 Read done. Action completed Time taken : 00:00:20 Reconnect Battery/USB Cable CS-Tool Ver 1.38 |
12-30-2015, 19:14 | #1204 (permalink) |
No Life Poster Join Date: Jan 2008 Location: PAKISTAN KARACHI Age: 44
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Qmobile R220 write flash done Code: Action : Write Flash Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM33 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6261 CPU_SW: CB01 CPU_HW: 8000 uploading boot image to RAM... Handshake Received from Phone. uploading boot image to RAM... Handshake Received from Phone. CHIP : MT6261 CPU ID : 00000000 NOR ID : 00EF004000160000 NOR Size : 4MB NOR Name : [WINBOND] W25Q32BV NAND ID : 0000000000000000 NAND Size: 0MB NAND Name: Nand:N/A Boot Information completed. Reading Phone Info... Project ID: QMOBILE_R220_V21_12_11_2014 checking uid protection... not found, it is safe. Programming Flash Image... Erasing.. Erasing done, Programming ... Load File : F:\CS-TOOL\MTK\R220 Qmobile R220 6261 4mb.bin Programming Flash Image Completed. Action completed Time taken : 00:00:48 Reconnect Battery/USB Cable CS-Tool Ver 1.38 THANKS TO CS-TOOL |
12-30-2015, 19:15 | #1205 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Rivo A200 imei repair done Code: Action : Repair IMEI Connecting, Pls hold on the power on key... hold on the power key... can release power key now. old imei1 : 358688000000158 new imei1=358344060547627 old imei2 359688000000159 new imei2=358344060547635 Action completed Time taken : 00:00:03 Reconnect Battery/USB Cable CS-Tool Ver 1.38 THANKS TO CS-TOOL |
12-31-2015, 06:31 | #1206 (permalink) |
No Life Poster Join Date: Nov 2010 Location: Atif mobile,goal, faisalabad
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | R350 privacy code read done Action : Read Codes Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM45 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6260 CPU_SW: CB00 CPU_HW: 8000 Switching to Meta Mode... Waiting for mete ack... handshake protocol is done. Reading ... password: 0306 Action completed Time taken : 00:00:33 Reconnect Battery/USB Cable CS-Tool Ver 1.38 |
12-31-2015, 09:53 | #1208 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Vinko note3 remove screen lock done Code: Action : Format / Reset Boot : SC6531-NOR Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (bootkey's Volume Down or volume up) Waiting for Phone Usb.... Phone found : SPRD U2S Diag (COM17) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... FDL test...OK SC Boot Ver : 6531 SC Boot Mode : 6531000100005A00 Loading CST Boot image to RAM... The CST Boot runs normally. CHIP : 65310001 CPU ID : 65310001 NOR ID : 00C8006000170000 NOR Size : 8MB NOR Name : SF_GD27Q64 Boot Information completed. Reading FileSystem info... FileSystem Version: 80 Start=0x00790000, Size=0x00070000 Erasing ... The eraser is completed. Action completed Time taken : 00:00:22 Reconnect Battery/USB Cable CS-Tool Ver 1.38 THANKS TO CS-TOOL |
12-31-2015, 09:54 | #1209 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Qmobile J5500 restart problem done Code: Action : Format / Reset Boot : SC6531-NOR Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (bootkey's Volume Down or volume up) Waiting for Phone Usb.... Phone found : SCI USB2Serial (COM27) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... FDL test...OK SC Boot Ver : 6531 SC Boot Mode : 6531000100005A00 Loading CST Boot image to RAM... The CST Boot runs normally. CHIP : 65310001 CPU ID: 65310001 NOR ID : 00C8006000160000 NOR Size : 4MB NOR Name : SF_GD27Q32 Boot Information completed. Reading FileSystem info... FileSystem Version: 80 Start=0x003D0000, Size=0x00030000 Erasing ... The eraser is completed. Action completed Time taken : 00:00:14 Reconnect Battery/USB Cable CS-Tool Ver 1.38 THANKS TO CS-TOOL |
12-31-2015, 09:55 | #1210 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Voice V177 lock remove factory reset done Code: Action : Format / Reset Boot : SC6531-NOR Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (bootkey's Volume Down or volume up) Waiting for Phone Usb.... Phone found : SPRD U2S Diag (COM17) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... FDL test...OK SC Boot Ver : 6531 SC Boot Mode : 6531000100005A00 Loading CST Boot image to RAM... The CST Boot runs normally. CHIP : 65310001 CPU ID : 65310001 NOR ID : 00C8006000170000 NOR Size : 8MB NOR Name : SF_GD27Q64 Boot Information completed. Reading FileSystem info... FileSystem Version: 80 Start=0x00788000, Size=0x00078000 Erasing ... The eraser is completed. Action completed Time taken : 00:00:20 Reconnect Battery/USB Cable CS-Tool Ver 1.38 THANKS TO CS-TOOL |
01-01-2016, 12:54 | #1213 (permalink) |
No Life Poster Join Date: Nov 2007 Location: ☆I-LOVE Pakistan☆
Member: 627475 Status: Offline Sonork: 100.1594828 Thanks Meter: 1,144 | O7 Tablet Write Flash Don with in unbelievable time |
The Following 3 Users Say Thank You to rafi_5217705 For This Useful Post: |
01-01-2016, 15:00 | #1214 (permalink) |
No Life Poster Join Date: Sep 2011 Location: IN_YOUR_HEART
Member: 1661953 Status: Offline Sonork: 100.1666694 Thanks Meter: 1,377 | Q-mobile e70 restart with call done with flashing Q-mobile e70 restart with call done with flashing Code: Action : Write Flash Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM19 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6260 CPU_SW: CB00 CPU_HW: 8000 uploading boot image to RAM... Handshake Received from Phone. uploading boot image to RAM... Handshake Received from Phone. uploading boot image to RAM... Handshake Received from Phone. CHIP : MT6260 CPU ID : 00000000 NOR ID : 00C8006000170000 NOR Size : 8MB NOR Name : [GigaDevice] GD25LQ64 NAND ID : 0000000000000000 NAND Size: 0MB NAND Name: Nand:N/A Boot Information completed. checking uid protection... not found, it is safe. Programming Flash Image... Erasing.. Erasing done, Programming ... Load File : C:\Documents and Settings\MohSiN\My Documents\Downloads\QMOBILE E70 FLASH FILE Programming Flash Image Completed. Action completed Time taken : 00:02:01 Reconnect Battery/USB Cable CS-Tool Ver 1.38 Created: 1/1/2016 3:48:01 PM br raza400 |
01-01-2016, 15:01 | #1215 (permalink) |
Junior Member Join Date: Mar 2015 Location: india.gujarat Age: 27
Member: 2355964 Status: Offline Thanks Meter: 4 | lenovo a369i invalid imei repair successfull lenovo a369i invalid imei repair successfull Action : Repair IMEI Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Warning !!! Imei changing is Illegal. Use this function to Restore Orginal Imei we are not responsible for illegal Act Waiting for Phone Usb... scanning the mtk usb device...... Phone found [ USB Port:COM8 ] Connecting... CPU: MT6572 Switching to Meta Mode... Waiting for mete ack... Done, reading... old IMEI: invalid old IMEI: invalid Repairing IMEI1: 865987========= done. Repairing IMEI2: 865987========= done. checking, pls wait ... [Restart the Phone To Verify New imei ] Action completed Time taken : 00:00:22 Reconnect Battery/USB Cable CS-Tool Ver 1.38 |
