![]() | #5641 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2008 Location: Bangladesh
Member: 821462 Status: Offline Thanks Meter: 889 | Action : Reset all settings / FRP Boot : SC7731C-EMMC Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found : SPRD U2S Diag (COM7) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... waiting for ack... 1st boot done. Sending 2nd boot... 2nd boot done. Checking H/W report info... Read info is done. Reading Project Property ... done. Android6.0 resetting all settings ... All done. Action completed Time taken : 00:00:32 Reconnect Battery/USB Cable CS-Tool Ver 1.60 |
![]() | #5642 (permalink) |
Member: 821462 Status: Offline Thanks Meter: 889 | Symphony E80 FRP Remove Done Action : Reset all settings / FRP Boot : SC7731C-EMMC Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found : SPRD U2S Diag (COM7) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... waiting for ack... 1st boot done. Sending 2nd boot... 2nd boot done. Checking H/W report info... Read info is done. Reading Project Property ... done. Android6.0 resetting all settings ... All done. Action completed Time taken : 00:00:32 Reconnect Battery/USB Cable CS-Tool Ver 1.60 |
![]() | #5643 (permalink) |
Member: 821462 Status: Offline Thanks Meter: 889 | Read Codes done Action : Read Codes Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM14 ] Connecting... Connection Done. Read CPU Info... CPU_SW: CB01 CPU_HW: 8000 CPU_ID: 6261 Switching to Meta Mode... Waiting for mete ack... handshake protocol is done. Reading ... password: 1234 password: 0019 Action completed Time taken : 00:00:34 Reconnect Battery/USB Cable CS-Tool Ver 1.59 |
The Following User Says Thank You to sajid01913 For This Useful Post: |
![]() | #5644 (permalink) |
Member: 821462 Status: Offline Thanks Meter: 889 | itel 1513 FRP Remove Done Action : Reset all settings / FRP Boot : SC7731C-EMMC Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found : SPRD U2S Diag (COM7) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... waiting for ack... 1st boot done. Sending 2nd boot... 2nd boot done. Checking H/W report info... Read info is done. Reading Project Property ... done. Android6.0 resetting all settings ... All done. Action completed Time taken : 00:00:36 Reconnect Battery/USB Cable CS-Tool Ver 1.60 |
![]() | #5645 (permalink) |
Member: 821462 Status: Offline Thanks Meter: 889 | Symphony T100 Password Read Done Action : Read Codes Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM14 ] Connecting... Connection Done. Read CPU Info... CPU_SW: CB00 CPU_HW: 8000 CPU_ID: 6260 Switching to Meta Mode... Waiting for mete ack... handshake protocol is done. Reading ... password: 827546 Action completed Time taken : 00:01:05 Reconnect Battery/USB Cable CS-Tool Ver 1.59 |
![]() | #5646 (permalink) |
Junior Member ![]() ![]() Join Date: Apr 2016 Location: philippines
Member: 2562120 Status: Offline Sonork: [email protected] Thanks Meter: 1 | Add CS Tool New update 1.80 |
![]() | #5647 (permalink) |
Member: 821462 Status: Offline Thanks Meter: 889 | Symphony V75 FRP Remove Done Action : Reset all to default Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM4 ] Connecting... Connection Done. Read CPU Info... CPU_SW: 0000 CPU_HW: CA00 CPU_ID: 6580 BV: 01 SecConf: 00000000 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 90014A483847316505 CHIP : MT65800000 CPU ID : EMMC ID : 90014A483847316505 EMMC Size: 8GB, usable capacity: 7.29GB EMMC Name: eMMC_Hynix_H8G1e Read Hardware Information is done. Formatting ... FRP Partition found, erasing ... Format done Action completed Time taken : 00:00:18 Reconnect Battery/USB Cable CS-Tool Ver 1.60 |
![]() | #5648 (permalink) |
Member: 821462 Status: Offline Thanks Meter: 889 | Mycell S2 Calling Problem done by Format. Action : Format / Reset Boot : SC6531-NOR Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found : SPRD U2S Diag (COM7) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... FDL test...OK SC Boot Ver : 6531 SC Boot Mode : 6531000100005A00 Loading CST Boot image to RAM... The CST Boot runs normally. CHIP : 65310001 CPU ID : 65310001 NOR ID : 00C8006000160000 NOR Size : 4MB NOR Name : SF_GD27Q32 Boot Information completed. Reading FileSystem info... FileSystem Version: 80 Start=0x003B0000, Size=0x00050000 Erasing ... The eraser is completed. Action completed Time taken : 00:00:15 Reconnect Battery/USB Cable CS-Tool Ver 1.59 |
![]() | #5649 (permalink) |
![]() | #5650 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2014 Location: Turkiye-Konya
Member: 2199727 Status: Offline Thanks Meter: 217 | Vestel 5000 6.0.1 frp reset ok Action : Reset all to default / FRP Tips ![]() Waiting for Phone Usb... Phone found [ USB Port:COM10 ] Connecting... Reading cpu info...ok MSM ID: 0x009600E1 Serial: 0x08D8D1EA Processor: MSM8909, Snapdragon210 Sending the boot...ok Receive ACK, Boot runs normally. Config parameters has been completed. Storage: eMMC Reading Partitions info...ok Reading storage info...ok eMMC Size: 16GB, usable capacity: 14,68GB Reading Project Property ... Android6.0.1 Formatting ... All Done Action completed Time taken : 00:04:44 important: frp reset after full flashing... |
The Following User Says Thank You to bulutiletisim For This Useful Post: |
![]() | #5651 (permalink) |
Member: 2199727 Status: Offline Thanks Meter: 217 | Wiko sunny2 frp reset ok here is log Action : Reset all settings / FRP Boot : SC7731C-EMMC Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found : SPRD U2S Diag (COM33) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... waiting for ack... 1st boot done. Sending 2nd boot... 2nd boot done. Checking H/W report info... Read info is done. Reading Project Property ... done. Android6.0 resetting all settings ... All done. Action completed Time taken : 00:00:30 Reconnect Battery/USB Cable CS-Tool Ver 1.60 |
![]() | #5653 (permalink) |
Member: 2199727 Status: Offline Thanks Meter: 217 | Reeder m7 go 2019 frp reset ok here is the log: Action : Format / Reset Boot : SC7731C-EMMC Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb.... Phone found : SPRD U2S Diag (COM29) Connecting... Bootstrap: SPRD3 Connected done. sending 1st boot... waiting for ack... 1st boot done. Sending 2nd boot... 2nd boot done. Checking H/W report info... Read info is done. Erasing userdata partiton, it will take a minute or so, pls wait... Erase has been completed. Auto formatting... Format Done. Action completed Time taken : 00:00:39 Reconnect Battery/USB Cable CS-Tool Ver 1.60 |
