12-21-2016, 09:33 | #2 (permalink) |
No Life Poster Join Date: Jan 2014 Location: GSM-WORLD
Member: 2116947 Status: Offline Sonork: 100.1652193 Thanks Meter: 1,302 | yes bro i know.... the real and perfect update for qualcom is coming from best team.... br muzammil rashdi |
The Following 3 Users Say Thank You to muzammilrashdi For This Useful Post: |
12-21-2016, 11:52 | #5 (permalink) |
No Life Poster Join Date: Jul 2013 Location: Pakistan. Rahim Yar Khan
Member: 1977629 Status: Offline Thanks Meter: 429 | Also need to remove some bugs tha that have on previous ver. like andirod data recovery not work on many cpus . and spd 7715 nand read and write not accurate on new exe . 1.42 work good with spd 7715 nand . |
12-21-2016, 14:29 | #10 (permalink) |
Member: 1977629 Status: Offline Thanks Meter: 429 | Spd 7715 Nand chips writing not work . after write a tested file with new exe set not power on . but with older exe its work again fine with the same file . at this movement i am using 1.42 for these chips . and about data recovery i give u some logs on next 2.3 days for understanding. then u can found the problem easily . BR |
12-22-2016, 07:28 | #14 (permalink) |
Member: 1977629 Status: Offline Thanks Meter: 429 | Qmobile X37 Try to recover media files but get error Qmobile X37 Try to recover media files but get error Action : Export media file Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM168 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 6572 CPU_SW: 0000 CPU_HW: CA01 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 90014A483447326111 CHIP : MT65720000 CPU ID : EMMC ID : 90014A483447326111 EMMC Size: 4GB, usable capacity: 3.65GB EMMC Name: eMMC_Hynix_H4G2a Read Hardware Information is done. Reading internal storage info ... Error: Read data [0x522] Action completed Time taken : 00:00:09 Reconnect Battery/USB Cable CS-Tool Ver 1.50.2 Created: 12/22/2016 11:14:21 AM |
