![]() | #68 (permalink) |
Junior Member ![]() ![]() Join Date: Apr 2016 Location: philippines
Member: 2562120 Status: Offline Sonork: [email protected] Thanks Meter: 1 | plz... how read fw cherry mobile flare s3 lite 7.0 not read cstool not boot volume + - plz........... help Action : Read Info Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM5 ] Connecting... Connection Done. Read CPU Info... CPU_SW: 0000 CPU_HW: CA00 CPU_ID: 6580 BV: 01 SecConf: 00000000 uploading boot image to RAM... Handshake received from Phone. Tips 1: In case some phone required to hold bootkey to enter download boot mode Tips 2: SecureBoot phone found, According to the brand, Select the supported sign DA from boots list and try again. Action completed Time taken : 00:02:51 Reconnect Battery/USB Cable CS-Tool Ver 1.60 |
![]() | #69 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2008 Location: Bangladesh
Member: 821462 Status: Offline Thanks Meter: 889 | Quote:
![]() | #70 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2006 Location: Philippines
Member: 235905 Status: Offline Sonork: 100.1580742:mamomogon03 Thanks Meter: 145 | Vivo 1716 Tested 100% -Flash reading -Passcode & FRP -Flashing not yet log: Action : Reset all to default Brand: VIVO Model: Common (Qualcomm) Tips ![]() Waiting for Phone Usb... Phone found [ USB Port:COM379 ] Connecting... Reading cpu info...ok MSM ID: 0x0009A0E1 Serial: 0xF76FBDB6 Processor: MSM8937, Snapdragon450 Sending the boot...ok Receive ACK, Boot runs normally. Config parameters has been completed. Storage: eMMC Reading Partitions info...ok Reading storage info...ok eMMC Size: 64GB, usable capacity: 58.24GB Reading Project Property ... Android7.1.2 Formatting ... Action completed Time taken : 00:00:06 Reconnect Battery/USB Cable CS-Tool Ver 1.38.2 Created: 19/03/2018 4:59:12 p.m. Action : Reset all to default Brand: VIVO Model: Common (Qualcomm) Tips ![]() Waiting for Phone Usb... Phone found [ USB Port:COM379 ] Connecting... Reading cpu info...ok MSM ID: 0x0009A0E1 Serial: 0xF76FBDB6 Processor: MSM8937, Snapdragon450 Sending the boot...ok Receive ACK, Boot runs normally. Config parameters has been completed. Storage: eMMC Reading Partitions info...ok Reading storage info...ok eMMC Size: 64GB, usable capacity: 58.24GB Reading Project Property ... Android7.1.2 Formatting ... All Done Action completed Time taken : 00:03:30 Reconnect Battery/USB Cable CS-Tool Ver 1.38.2 Created: 19/03/2018 5:05:51 p.m. |
The Following User Says Thank You to mamo_mogon03 For This Useful Post: |
![]() | #71 (permalink) |
Member: 235905 Status: Offline Sonork: 100.1580742:mamomogon03 Thanks Meter: 145 | Oppo CPH1723 Not working Action : Reset all to default Brand: OPPO Model: Common (MTK) Tips: 1.Remove Battery, Insert usb cable, Insert battery [Preloader Mode] 2.power off Phone, Remove & Reinsert Battery , insert USB Cable [Preloader Mode] (In Case Some Phone Required to hold bootkey) [BROM Mode] Waiting for Phone Usb (Press "F2" to activate fast scan mode)... HID: USB\VID_0E8D&PID_0003&REV_0100 FNM: MediaTek USB Port (COM9) Phone found [ USB Port:COM9 ] Connecting... Connection Done. Read CPU Info... CPU_SW: 0001 CPU_HW: CA01 CPU_ID: 0690[MT6763] BV: FE SecConf: 000000E5 Error: S-Module is required. uploading boot image to RAM... Handshake received from Phone. Action completed Time taken : 00:00:11 Reconnect Battery/USB Cable CS-Tool Ver 1.38.2 Created: 19/03/2018 5:26:28 p.m. |
![]() | #72 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2015 Location: Hongkong
Member: 2409100 Status: Offline Sonork: 100.1667267 Thanks Meter: 3,757 | Error: S-Module is required. == this means you need to activate S module |
The Following User Says Thank You to CS-Tool For This Useful Post: |
