02-23-2018, 12:09 | #1 (permalink) |
Registered User Join Date: Jan 2008 Location: Where never ends.
Member: 669673 Status: Offline Thanks Meter: 301 | every time getting error Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM7 ] Connecting... Connection Done. Read CPU Info... CPU_SW: 0000 CPU_HW: CA00 CPU_ID: 0335[MT6735M_S01] BV: FE SecConf: 00000001 uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. Warning: failed to init dram, loading default settings Waiting for DRAM detection... New id found, testing... ID: 150100464531324D42 Error: failed to init DRAM ?. Error: 0xef [ReadInfo]. Action completed Time taken : 00:00:37 Reconnect Battery/USB Cable CS-Tool Ver 1.59 always getting error like marked in color. |
02-23-2018, 15:25 | #2 (permalink) |
No Life Poster Join Date: May 2013 Location: Far From Home..:(
Member: 1948608 Status: Offline Thanks Meter: 1,744 | bootloader locked, its seems secure boot device,not supported secure devices yet.. |
The Following User Says Thank You to -Mosin- For This Useful Post: |
02-24-2018, 11:22 | #3 (permalink) |
No Life Poster Join Date: Jun 2015 Location: Hongkong
Member: 2409100 Status: Offline Sonork: 100.1667267 Thanks Meter: 3,757 | You Select EMI Setting from POPup Window if not popup , please write Model and Brands, if you have Preloader for this phone, you can select preloadrr advance DRAM Option ad try read info or send us preloader |
The Following User Says Thank You to CS-Tool For This Useful Post: |
02-24-2018, 18:09 | #4 (permalink) | |
Member: 669673 Status: Offline Thanks Meter: 301 | Quote:
Thanks. | |
