01-08-2016, 09:36 | #1 (permalink) |
Product Supporter Join Date: Feb 2010 Location: .::INDIA::.
Member: 1236722 Status: Offline Sonork: 100.1601546 Thanks Meter: 4,180 | Intex Aura+ Format Done Nand Cpu Code: Action : Format / Reset Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM21 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 625A CPU_SW: CA01 CPU_HW: 8000 uploading boot image to RAM... Handshake Received from Phone. uploading boot image to RAM... Handshake Received from Phone. uploading boot image to RAM... Handshake Received from Phone. CHIP : MT625A CPU ID : 00000000 NOR ID : 00C2002500360000 NOR Size : 4MB NOR Name : [MX] MX25U3235E NAND ID : 0000000000000000 NAND Size: 0MB NAND Name: Nand:N/A Boot Information completed. Formatting ... Format done. Action completed Time taken : 00:00:16 Reconnect Battery/USB Cable CS-Tool Ver 1.38 Security Repair Code: Action : Repair IMEI Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Warning !!! Imei changing is Illegal. Use this function to Restore Orginal Imei we are not responsible for illegal Act Waiting for Phone Usb... Phone found [ USB Port:COM21 ] Connecting... Connection Done. Read CPU Info... CPU_ID: 625A CPU_SW: CA01 CPU_HW: 8000 Switching to Meta Mode... Waiting for mete ack... handshake protocol is done. Checking IMEI ... old IMEI: 368688000000158 ???: 0xe1 [Repairing IMEI1] old IMEI: 438688000000179 ???: 0xe1 [Repairing IMEI2] spec write... failed to Spec write. [Restart the Phone To Verify New imei ] Action completed Time taken : 00:01:19 Reconnect Battery/USB Cable CS-Tool Ver 1.38 CS-Team VC_INDIA |
