02-03-2018, 17:01 | #1 (permalink) |
Banned Join Date: May 2013 Location: Hacked by Hackflax on tiktok
Member: 1941705 Status: Offline Thanks Meter: 1,248 | Meizu M5s Read/ Write Flash With CS-Tool Code: Action : Read Flash Brand: Meizu Model: Common (MTK) Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... HID: USB\VID_0E8D&PID_0003&REV_0100 FNM: MTK USB Port (COM217) Phone found [ USB Port:COM217 ] Connecting... Connection Done. Read CPU Info... CPU_SW: 0000 CPU_HW: CA00 CPU_ID: 0337[MT6753_S01] BV: FE SecConf: 00000007 Decryping(Meizu)...ok uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. Warning: failed to init dram, loading default settings Waiting for DRAM detection... Done. Size=0x00000000C0000000 uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 150100524531424D42 CHIP : MT6753 CPU ID : EMMC ID : 150100524531424D42 EMMC Size: 16GB, usable capacity: 14,57GB EMMC Name: eMMC_Samsung_RE1BMB Read Hardware Information is done. usb switching to high speed ... New Port: COM219 ......ok switch done. Reading Project Property ... done. Dumping Flash Image Now(without user data)... Dumping Flash Image Completed. Flash Image size : 2922,00MB Saved to: C:\Users\Roman\Desktop\meizu m5s\злите без передньоъ камери\MT6753_Meizu_M5s_16GB_Meizu_M1612_Meizu_Android6.0_Flyme 6.7.8.8G beta_20180203_173938.cst Action completed Time taken : 00:05:15 Reconnect Battery/USB Cable CS-Tool Ver 1.37 |
The Following 5 Users Say Thank You to Xaker2012 For This Useful Post: |
02-03-2018, 17:05 | #2 (permalink) |
Member: 1941705 Status: Offline Thanks Meter: 1,248 | read nvram meizu m5s Code: Action : Read NVRAM(DwonloadMode) Brand: Meizu Model: Common (MTK) Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... HID: USB\VID_0E8D&PID_0003&REV_0100 FNM: MTK USB Port (COM217) Phone found [ USB Port:COM217 ] Connecting... Connection Done. Read CPU Info... CPU_SW: 0000 CPU_HW: CA00 CPU_ID: 0337[MT6753_S01] BV: FE SecConf: 00000007 Decryping(Meizu)...ok uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. Warning: failed to init dram, loading default settings Waiting for DRAM detection... Done. Size=0x00000000C0000000 uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 150100524531424D42 CHIP : MT6753 CPU ID : EMMC ID : 150100524531424D42 EMMC Size: 16GB, usable capacity: 14,57GB EMMC Name: eMMC_Samsung_RE1BMB Read Hardware Information is done. Reading Project Property ... done. Reading nv ... NV backup is done. Save as: C:\Users\Roman\Desktop\CSTool_All-in-One_Ver1.37_VerSM_1.59\CSTool_All-in-One_Ver1.37_VerSM_1.59\backup\NV__MT6753_Meizu_M5s_Android6.0_Flyme 6.7.8.8G beta_20180203_180456.cst Action completed Time taken : 00:01:00 Reconnect Battery/USB Cable CS-Tool Ver 1.37 |
The Following 3 Users Say Thank You to Xaker2012 For This Useful Post: |
02-03-2018, 17:07 | #3 (permalink) |
Member: 1941705 Status: Offline Thanks Meter: 1,248 | Reset all settings Code: Action : Reset all to default Brand: Meizu Model: Common (MTK) Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... HID: USB\VID_0E8D&PID_0003&REV_0100 FNM: MTK USB Port (COM217) Phone found [ USB Port:COM217 ] Connecting... Connection Done. Read CPU Info... CPU_SW: 0000 CPU_HW: CA00 CPU_ID: 0337[MT6753_S01] BV: FE SecConf: 00000007 Decryping(Meizu)...ok uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. Warning: failed to init dram, loading default settings Waiting for DRAM detection... Done. Size=0x00000000C0000000 uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 150100524531424D42 CHIP : MT6753 CPU ID : EMMC ID : 150100524531424D42 EMMC Size: 16GB, usable capacity: 14,57GB EMMC Name: eMMC_Samsung_RE1BMB Read Hardware Information is done. Formatting ... FRP Partition found, erasing ... Format done |
02-03-2018, 17:52 | #4 (permalink) |
Member: 1941705 Status: Offline Thanks Meter: 1,248 | Meizu m5s Write Flash With CS-Tool Code: Action : Write Flash Brand: Meizu Model: Common (MTK) Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... HID: USB\VID_0E8D&PID_0003&REV_0100 FNM: MTK USB Port (COM217) Phone found [ USB Port:COM217 ] Connecting... Connection Done. Read CPU Info... CPU_SW: 0000 CPU_HW: CA00 CPU_ID: 0337[MT6753_S01] BV: FE SecConf: 00000007 Decryping(Meizu)...ok uploading boot image to RAM... Handshake received from Phone. Detected eMMC FlashType. Warning: failed to init dram, loading default settings Waiting for DRAM detection... Done. Size=0x00000000C0000000 uploading boot image to RAM... Handshake Received from Phone. eMMC cid: 150100524531424D42 CHIP : MT6753 CPU ID : EMMC ID : 150100524531424D42 EMMC Size: 16GB, usable capacity: 14,57GB EMMC Name: eMMC_Samsung_RE1BMB Read Hardware Information is done. usb switching to high speed ... New Port: COM219 ......ok switch done. Load File : C:\Users\Roman\Desktop\meizu m5s\злите без передньоъ камери\MT6753_Meizu_M5s_16GB_Meizu_M1612_Meizu_Android6.0_Flyme 6.7.8.8G beta_20180203_173938.cst Image Size: 0x00000000B6A02000 Programming Flash Image... Programming Flash Image Completed. Action completed Time taken : 00:04:38 Reconnect Battery/USB Cable CS-Tool Ver 1.37 |
The Following 4 Users Say Thank You to Xaker2012 For This Useful Post: |
10-14-2020, 09:33 | #6 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 44
Member: 136052 Status: Offline Thanks Meter: 75 | Code: Action : Read Flash Brand: Meizu Model: Common (MTK) Tips: 1.Remove Battery, Insert usb cable, Insert battery [Preloader Mode] 2.power off Phone, Remove & Reinsert Battery , insert USB Cable [Preloader Mode] (In Case Some Phone Required to hold bootkey) [BROM Mode] Waiting for Phone Usb (Press "F2" to activate fast scan mode)... HID: USB\VID_0E8D&PID_0003&REV_0100 FNM: MediaTek USB Port (COM24) Phone found [ USB Port:COM24 ] Connecting... Connection Done. Read CPU Info... CPU_SW: 0000 CPU_HW: CA00 CPU_ID: 0337[MT6753_S01] BV: FE SecConf: 00000007 Error: S-Module is required. uploading boot image to RAM... Tips: Some phones need to connect in Brom Mode, and some in Preloader Mode Action completed Time taken : 00:00:10 Reconnect Battery/USB Cable CS-Tool Ver 1.38.2 Code: Action : Format / Reset Brand: Meizu Model: Common (MTK) Tips: 1.Remove Battery, Insert usb cable, Insert battery [Preloader Mode] 2.power off Phone, Remove & Reinsert Battery , insert USB Cable [Preloader Mode] (In Case Some Phone Required to hold bootkey) [BROM Mode] Waiting for Phone Usb (Press "F2" to activate fast scan mode)... HID: USB\VID_0E8D&PID_2000&REV_0100 FNM: MediaTek PreLoader USB VCOM (Android) (COM26) Phone found [ USB Port:COM26 ] Connecting... Connection Done. Read CPU Info... CPU_SW: 0000 CPU_HW: CA00 CPU_ID: 0337[MT6753_S01] BV: 01 SecConf: 00000007 uploading boot image to RAM... Handshake received from Phone. Tips 1: In case some phone required to hold bootkey to enter Brom Mode Tips 2: SecureBoot phone found, According to the brand, Select the supported signed DA from boots list and try again. Action completed Time taken : 00:00:09 Reconnect Battery/USB Cable CS-Tool Ver 1.38.2 |
