04-03-2019, 06:04 | #51 (permalink) |
No Life Poster Join Date: May 2007 Location: india
Member: 500302 Status: Offline Thanks Meter: 157 | vivo vivo Y21L unlock done without data lose Operation : Reset Locks (Vivo) Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM148) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.3 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1507000 [8916] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A2 6AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8916_014]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8916, eMMC, 16 GB LU Count : 1 [0x01D1F000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 16384, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : vivo vivo Y21L [msm8916] Software : LMY47V release-keys, eng.compiler.20180317 [Sat Mar 17 18:54:47 CST 2018] Android Ver. : 5.1.1 Patch Level : 2018-03-01 USERDATA : Normal For Normal userdata, you can use [Reset Locks] button. Reading Extended Information...OK Model : vivo Y21L Resetting Locks (Vivo)...Done Please wait for phone to reboot. Operation Finished. QcFire Ver. 4.0 |
The Following 2 Users Say Thank You to Wasim007 For This Useful Post: |
04-03-2019, 07:56 | #53 (permalink) | |
No Life Poster Join Date: Sep 2009
Member: 1109337 Status: Offline Thanks Meter: 197 | Quote:
04-03-2019, 12:43 | #54 (permalink) |
Insane Poster Join Date: Jan 2016 Location: Derbent
Member: 2516133 Status: Offline Thanks Meter: 55 | Redmi Note 4X flashing failed. Still same problem as before. Operation : Flash Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM119) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Writing [NON-HLOS.bin] -> [modem] ...Done Writing [sbl1.mbn] -> [sbl1] ...Done Writing [sbl1.mbn] -> [sbl1bak] ...Done Writing [rpm.mbn] -> [rpm] ...Done Writing [rpm.mbn] -> [rpmbak] ...Done Writing [tz.mbn] -> [tz] ...Done Writing [tz.mbn] -> [tzbak] ...Done Writing [devcfg.mbn] -> [devcfg] ...Done Writing [devcfg.mbn] -> [devcfgbak] ...Done Writing [adspso.bin] -> [dsp] ...Done Writing [fs_image.tar.gz.mbn.img] -> [fsg] ...Done Writing [sec.dat] -> [sec] ...Done Writing [splash.img] -> [splash] ...Done Writing [emmc_appsboot.mbn] -> [aboot] ...Done Writing [emmc_appsboot.mbn] -> [abootbak] ...Done Writing [boot.img] -> [boot] ...Done Writing [recovery.img] -> [recovery] ...Done Writing [system.img ] -> [system]...FailedFailed Operation Finished. QcFire Ver. 4.0 |
04-03-2019, 13:55 | #55 (permalink) |
Major Poster Join Date: Dec 2016 Location: Defcon21
Member: 2663223 Status: Offline Thanks Meter: 3 | hello umt team i was flashing vio y51L suddenly flashing stoped at system partiton but after i flash this phone with qfil report success why umt failed system partition most of the handset please fix this bug i have returned many handset because of hardware problem but it was not hardware problem it was umt bug problem which cause system fail only system partition please fix asap by the way thanks for update |
04-03-2019, 15:28 | #56 (permalink) |
Crazy Poster Join Date: Nov 2013 Location: the land of promise,philippine
Member: 2068216 Status: Offline Sonork: redfoxvpn Thanks Meter: 8 | pocophone f1 Operation : Disable Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM11) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1B00800 [SD845] 00007200 OPK_DATA : 99AF649E077EBCE3E9E187442ABDC70BD715756DE9ED192E9F 7883A10EBE09F4 Initializing Protocol...OK Using Auto Loader Selection [4] No compatible loader found. Device may not boot with this loader. Preparing Loader...Done Sending Loader [SD845]...Write Error! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 4.0 |
04-04-2019, 08:05 | #58 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Malappuram. INDIA
Member: 412813 Status: Offline Sonork: 100.1594692 Thanks Meter: 353 | vivo v15 pro err Operation : Reset Locks (Vivo) Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM318) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1500900 [E1500900] 03007300 OPK_DATA : F754F13EE91BF54295CA1FBD64D182067440B35FC41B798A53 9670EA259771BA Initializing Protocol...OK Using Auto Loader Selection [0] CPU not found in database. Operation Finished. QcFire Ver. 4.0 Sabah Mangattupulam |
04-04-2019, 12:21 | #59 (permalink) |
Freak Poster Join Date: Dec 2006 Location: gujrat
Member: 417084 Status: Offline Thanks Meter: 36 | Operation : Reset Locks (Vivo) Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM9) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 00000000 OPK_DATA : 30315EBED1DD09CEAAE927CAE0EE967076BC178CA33718DB4F FF8F02A0E7FAD2 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8917_001]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8917, eMMC, 16 GB LU Count : 1 [0x01D5A000] Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : vivo vivo 1724 Software : OPM1.171019.011 release-keys, eng.compil.20180926.200120 [Wed Sep 26 20:01:20 CST 2018] Android Ver. : 8.1.0 Patch Level : 2018-09-01 USERDATA : Encrypted Reading Extended Information...OK Model : vivo 1801 Product : PD1731BF_EX Cust. Name : PD1731BF_EX_IN_NULL_NULL Version : PD1731BF_EX_A_1.10.2 Resetting Locks (Vivo)...Done Please wait for phone to reboot. Operation Finished. QcFire Ver. 4.0 |
The Following User Says Thank You to vinaykmobile For This Useful Post: |
04-05-2019, 05:46 | #60 (permalink) |
Junior Member Join Date: Dec 2014 Location: Avengers Mtk UMT Team
Member: 2306060 Status: Offline Sonork: [email protected] Thanks Meter: 8 | LENOVO Lenovo YT3-850M [msm8909] frp done thank you UMT Team Operation : Format FS Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM10) Driver Info : Lenovo Inc., leusbser.sys, 2.0.9.6 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1009600 [8909] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A2 6AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [2] Preparing Loader...Done Sending Loader [8909_012]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8909, eMMC, 16 GB LU Count : 1 [0x01D1F000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : LENOVO Lenovo YT3-850M [msm8909] Software : YT3-850M_S000114_161125_ROW, YT3-850M_S000114_161125_ROW [Fri Nov 25 07:02:09 CST 2016] Android Ver. : 6.0.1 Patch Level : 2016-11-01 Preparing Data...Done Formatting Userdata...Done Resetting FRP Lock.......Done Operation Finished. QcFire Ver. 4.0 ..............................................Than k you UMT Team......................................... |
The Following User Says Thank You to sathyam8225@gma For This Useful Post: |
