02-13-2020, 16:36 | #91 (permalink) | ||
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Quote:
Auth Denied - How this message shows that it is server issue? And what about the line after this? May be we need to consult some language expert to make it readable for all. Br, UMT | ||
The Following 2 Users Say Thank You to U.M.T For This Useful Post: |
02-15-2020, 12:21 | #93 (permalink) |
Freak Poster Join Date: Apr 2016 Location: South Africa /Pakistan Age: 29
Member: 2555393 Status: Offline Thanks Meter: 268 | Device : Xiaomi_No_Auth RedmiNote8_ginkgo Operation : Reset Mi Account Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM116) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1A01000 [E1A01000] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7 Initializing Protocol...OK Preparing Loader...Done Sending Loader [RedmiNote8_ginkgo]...Done Executing Loader...Failed! Possibly Wrong Loader Please select Loader manually, or use Factory Loader in Custom Option. Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 5.3 |
02-19-2020, 07:43 | #98 (permalink) |
Junior Member Join Date: Apr 2010 Location: Gorontalo Age: 40
Member: 1279525 Status: Offline Thanks Meter: 0 | please help, umt auth credit yesterday I had 10 credits. so used 1 time flashing xiaomi redmi note 5pro my credit changed to 0 credit serial: UMT990300788 |
02-21-2020, 19:32 | #100 (permalink) | ||
Junior Member Join Date: Oct 2010 Location: Brasil
Member: 1425131 Status: Offline Thanks Meter: 1 | Quote:
and when my card's activation period ends, what will they do about these days that I'm not using? because if it was working I would be using it every day! and since it is not working they should not sell the credits. if the credit is sold at least from a more friendly support. because I didn’t have help or one from the umt company. Quote:
02-21-2020, 19:38 | #101 (permalink) | ||
02-21-2020, 19:59 | #102 (permalink) |
Member: 1425131 Status: Offline Thanks Meter: 1 | see the photo https://ibb.co/RpCtPkR |
02-22-2020, 18:27 | #103 (permalink) | ||
Turn Off Find Device first. If you think it is an error, try once again, if same then read previous line. Br, UMT | ||
The Following User Says Thank You to U.M.T For This Useful Post: |
02-22-2020, 22:26 | #104 (permalink) | |
I have a redmi 7 in infinite loop and another redmi 7 to bypass the mi account, what should i do to disable "FIND MY DEVICE" before doing any procedure? thanks. BR | |
