01-13-2021, 09:15 | #65 (permalink) |
No Life Poster Join Date: Aug 2005 Location: MY
Member: 172261 Status: Offline Thanks Meter: 362 | Device: Samsung Device Operation: Reset FRP (New Method) Port: COM70 : SAMSUNG Mobile USB Modem #22 Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: LSI7870 [HiSpeed] Resetting FRP Lock Data... . Done Closing Session... Binary Rejected! Failed to reset FRP.! Possibly unsupported firmware, flash phone and try again Elapsed Time: 00:23 [Ultimate Samsung Flasher v1.5] |
01-13-2021, 19:28 | #66 (permalink) | |
Freak Poster Join Date: Aug 2009 Location: Bangladesh
Member: 1092417 Status: Offline Sonork: 100.1645946 Thanks Meter: 45 | Quote:
How to Install a DLL File: - Copy the extracted .dll file to the installation folder (C:\UMTool\UltimateGSM) of the application or game. Check if the problem is solved. If the problem persists or you are not sure which software is having problems, install the .DLL file directly to Windows. - Copy the file to "C:\Windows\SysWOW64\" (32bit) - Copy the file to "C:\Windows\System32\" (64bit) You can install the .dll file in both system folders without any problems. | |
The Following User Says Thank You to ASM_FARUQUE For This Useful Post: |
03-15-2021, 14:20 | #72 (permalink) |
Freak Poster Join Date: Aug 2010 Location: india, haryana,
Member: 1358048 Status: Offline Thanks Meter: 699 | show succes but stil lock Port : Android ADB Interface Baud Rate : Not Applicable Device : Oppo Generic Operation : Disable Privacy Lock Searching for Device... Found Brand : OPPO Model : CPH1945 Firmware : CPH1945EX_11_C.45 Build Date : Mon Jan 4 23:44:35 CST 2021 Version : 10 Patch Level : 2021-01-05 Board : oppo6779 Hardware : mt6779 Baseband : M_V3_P10,M_V3_P10 ABI : arm64-v8a,armeabi-v7a,armeabi Disabling Privacy Lock... Done Operation Finished. Elapsed Time: 00:06 [Module Ver. 5.5.1] Log Saved to Logs\210315_184711.log |
03-15-2021, 15:44 | #73 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,377 | Quote:
Br, UMT | |
05-05-2021, 04:03 | #75 (permalink) |
Member: 172261 Status: Offline Thanks Meter: 362 | Device: Samsung Device Operation: Reset FRP (New Method) Port: COM213 : SAMSUNG Mobile USB Modem #210 Checking for Device... Found [Normal Mode] Reading Phone Information... OK Model: SM-G610F IMEI: 352810094379720 Software: G610FDXU1CRL2/G610FOLB1CRL1/G610FDDU1CRJ5/G610FDXU1CRL2 Init Download Mode... OK Port: COM70 : SAMSUNG Mobile USB Modem #22 Reading Data from Phone... Done Chipset: LSI7870 [HiSpeed] Resetting FRP Lock Data... . Done Closing Session... Binary Rejected! Failed to reset FRP.! Possibly unsupported firmware, flash phone and try again Elapsed Time: 01:08 [Ultimate Samsung Flasher v1.5] |
