06-03-2020, 08:20 | #1 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,262 | [03-06-20] UMTv2 / Pro - UltiamteGSM v5.5 Released - Oppo Privacy Lock & SPRD Repair UMTv2 / UMT Pro UltimateGSM v5.5 Innovative and Intelligent Whats New: Oppo Privacy Lock Disable - Need to Enable ADB - Should work on all devices, if not, please report with log SPRD Enable Diag - For Anrdoid devices which don't have diag enabled - For old phones, you may need to tick on Old Method - You must connect powered off phone without pressing any key Updated IMEI Repair Function - Enable Diag first to use this function - After Diag enabled, Scan and select Diag Port Added BT Address Repair - Enable Diag first to use this function - After Diag enabled, Scan and select Diag Port Added WIFI MAC Repair - Enable Diag first to use this function - After Diag enabled, Scan and select Diag Port Added Factory Reset in Diag Mode - Enable Diag first to use this function - After Diag enabled, Scan and select Diag Port - It will wipe data on phone, so use with caution Added SPRD Driver in Installer - If you face issues, please use this driver Improved COM Port Communication Special Thanks to: - Unlockinfo - UnlockwithCode - kabul - miftahulbari - owais a WARNING : ESN / MEID / IMEI REPAIR IS INTENDED TO REPAIR ESN / MEID / IMEI TO ORIGINAL ONE WRITTEN ON PHONE BACK LABEL / BOX. WE DO NOT ENDORSE OR ENCOURAGE ESN / MEID / IMEI CHANGING. ITS ILLEGAL. USER IS SOLE RESPONSIBLE FOR ANY ILLEGAL ACTIVITY DONE WITH USE OF FEATURES PROVIDED IN OUR SOFTWARE, NOT LIMITED TO ESN / MEID / IMEI. ANY USER USING OUR SOFTWARE FOR ILLEGAL PURPOSE WILL BE SOLE RESPONSIBLE FOR HIS ACTS. WE CONDEMN USE OF OUR SOFTWARE FOR ANY ILLEGAL PURPOSE. STATUTORY WARNING - READ CAREFULLY Using International Edition of our software is prohibited by Indian Law. We strictly advice you to use Indian Edition if you are in India. If you use International Edition in India, it may cause legal action against you by local law enforcement agencies. We will not be liable for any loss or damaged caused. :: NO FAKE ADVERTISEMENT :: :: NO FAKE UPDATES :: :: NO FAKE WORLD'S FIRST :: :: NO FAKE BLA BLA BLA :: How to Download: - Download UMT Support Access. - Connect UMT Box/Dongle to PC and Run UMT Support Access. - Download required Executable from Installer folder. - Enjoy! - Download Mirrors PLEASE DO NOT POST OFF TOPIC HERE. ONLY POST REGARDING THIS UPDATE AND SUPPORTED MODELS. ANY OFF TOPIC POST WILL BE DELETED IMMEDIATELY. FOR THANKS, USE ONLY THANKS BUTTON. |
The Following 73 Users Say Thank You to Fast Unlocking For This Useful Post: |
06-03-2020, 09:16 | #4 (permalink) |
No Life Poster Join Date: Jul 2013 Location: ROGER/BELL/TELUS/NTT/AU KDDI Age: 38
Member: 1981870 Status: Offline Thanks Meter: 16,502 | Mmx Q402 Factory Reset Done With Great Umt King Code: Connect power off phone, DO NOT PRESS any button... Device Found Path : \\?\USB#VID_1782&PID_4D00#5&212ac8fc&0&4#{4d36e978-e325-11ce-bfc1-08002be10318} Switching to Diag Mode... Done Wait for port to appear, then click [Scan] and select Port. Listing Available Ports... Done Port : COM9 : SCI USB2Serial (COM9) Baud Rate : 921600 Device : Spreadtrum Operation : Read Info Opening Port... OK Reading Phone Information... OK Platform Ver. : MOCORTM_15C_W16.39.3_P3.09_Debug Project Ver. : sharkl_cp1 Base Ver. : FM_BASE_15C_W16.39.3_P3.09 Hw. Ver. : sc9630_modem Build : MMX_Q402_SW_V14_HW_V2.0_20170804 Reading IMEI Information... IMEI[1] : 91156285xxxxxx IMEI[2] : 91156285xxxxxx Reading BT/WIFI Information... BT MAC : 3C97112423CE WIFI MAC : 3C97112A3E4E Operation Finished. Elapsed Time: 00:04 [Module Ver. 5.5] Log Saved to Logs\200603_134006.log Port : COM9 : SCI USB2Serial (COM9) Baud Rate : 921600 Device : Spreadtrum Operation : Factory Reset Opening Port... OK Reading Phone Information... OK Platform Ver. : MOCORTM_15C_W16.39.3_P3.09_Debug Project Ver. : sharkl_cp1 Base Ver. : FM_BASE_15C_W16.39.3_P3.09 Hw. Ver. : sc9630_modem Build : MMX_Q402_SW_V14_HW_V2.0_20170804 Reading IMEI Information... IMEI[1] : 91156285xxxxxx IMEI[2] : 91156285xxxxxx Reading BT/WIFI Information... BT MAC : 3C97112423CE WIFI MAC : 3C97112A3E4E Resetting Factory Settings... Done Operation Finished. Elapsed Time: 00:04 [Module Ver. 5.5] Log Saved to Logs\200603_134022.log |
The Following 3 Users Say Thank You to UnlockwithCode For This Useful Post: |
06-03-2020, 11:51 | #13 (permalink) |
Junior Member Join Date: Oct 2015 Location: Islamabad
Member: 2473814 Status: Offline Sonork: 1669719 Thanks Meter: 6 | Added Factory Reset in Diag Mode - Enable Diag first to use this function - After Diag enabled, Scan and select Diag Port - It will wipe data on phone, so use with caution Pls we need FRP solution in Diag Mode |
