Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 02-12-2018, 05:58   #46 (permalink)
U.M.T's Avatar
Member: 2465108
Sonork: No More Used
Thanks Meter: 13,431
Originally Posted by mickeybrown026 View Post
please speed up reading time in edl mode reading a firmware is very very slow
its takes almost 45 t0 50 minute to read a large file
Show me log.
Userdata must be Encrypted, and probably you are reading it too.
Br,
Ultimate Multi Tool
Old 02-14-2018, 06:27   #47 (permalink)
Member: 2697228
Thanks Meter: 8
UMT team add plz ARTEL P5
Old 02-14-2018, 07:16   #48 (permalink)
saif@cellplus's Avatar
Member: 26488
Sonork: 100.1581233
Thanks Meter: 151
ASUS X00LDA FRP done
Device : ASUS X00LDA
Operation : Reset FRP
Checking for existing devices...Found
Port : COM20
Opening Port...OK
Init Handshake Sequence...OK
Hardware ID : E1F00400 [8937] 39A21620
OPK_DATA : FDB379775FEB07C551EFBC01F78CD6ABAC99A2829E6F63768E 4491B32485B6E5
Initializing Protocol...OK
Using Auto Loader Selection [1]
Preparing Firehose Loader...Done
Sending Loader [8937_015.ufl]...Done
Executing Loader...OK
Detecting Chip Type...OK
Hardware* : 8937, eMMC, 32 GB
Warning! High Speed Driver is not installed.
Please install driver from QcFire\Drivers folder using Device Manager.
Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512
Reading Partition Table...OK
Reading Device Information...OK
Device : asus ASUS_X00LDA [msm8937]
Software : NMF26F.WW_Phone-14.0400.1709.165-20170928, WW_Phone-14.0400.1709.165-20170928 [Thu Sep 28 09:01:16 CST 2017]
Android Ver. : 7.1.1
The Following 2 Users Say Thank You to saif@cellplus For This Useful Post:
Old 02-15-2018, 13:59   #49 (permalink)
Member: 998504
Thanks Meter: 8
Good update
very good update but umt team please update mtk spd and huwaie with life time support
Old 02-19-2018, 12:08   #50 (permalink)
Member: 2754458
Thanks Meter: 3
Question QcFire DOWNLOAD ?
:rolar os olhos:QcFire DOWNLOAD ?
Old 02-19-2018, 17:02   #51 (permalink)
lolo24's Avatar
Member: 2572618
Sonork: no
Thanks Meter: 185
Pls add ZTE Zmax Pro Z981, FS, Read n Write frimware.
Best Regards
Luis Manresa
Old 02-20-2018, 11:24   #52 (permalink)
Member: 2501288
Thanks Meter: 328
vdf 710 read done
Operation : Read Firmware
Port : COM52
Opening Port...OK
Hardware ID : E1B00600 [8937] 00000400
OPK_DATA : C7EF5E9C6DE5335E2E3B54BF2C47DFF605D327262E03B79E51 5436BF642B09F4
Sending Loader [8937_017.ufl]...Done
USERDATA : Encrypted
Reading USERDATA will cause large firmware size and slow read.
Device : Vodafone VFD 710 [msm8937]
Software : VFD-710_MRB01-3, 20170925.121502 [2017年 09月 25日 星期一 12:15:05 CST]
Reading [fsc]...Done
Reading [fsg]...Done
Reading [modemst1]...Done
Reading [modemst2]...Done
Reading [persist]...Done
Reading [sec]...Done
Reading [devinfo]...Done
Reading [keystore]...Done
Reading [config]...Done
Saved to : C:\UMTool\QcFire\Read\Vodafone_VFD 710_VFD-710_MRB01-3_7.1.1\
Operation Finished.
Module Ver. 1.7
The Following User Says Thank You to Steve-1 For This Useful Post:
Old 02-21-2018, 00:59   #53 (permalink)
Member: 2754458
Thanks Meter: 3
buy
How do I buy QcFire in brazilian
Old 02-24-2018, 17:50   #54 (permalink)
Member: 1999073
Sonork: 100.1672641
Thanks Meter: 3
Hi umt team plz update lg nexus 5x frp remove android 7.1.2 and above
Old version 1.7 frp done but not remove
I am try on download mode fastboot not work
Old 02-24-2018, 17:53   #55 (permalink)
Member: 1999073
Sonork: 100.1672641
Thanks Meter: 3
Umt team plz how to install Qualcomm high speed driver
Give example
Old 02-24-2018, 19:26   #56 (permalink)
U.M.T's Avatar
Member: 2465108
Reading LOGS really helps, for more help, google is always there.
Br,
Ultimate Multi Tool
Old 02-24-2018, 20:26   #57 (permalink)
Member: 2501288
Thanks Meter: 328
Operation : Flash
Checking for existing devices...Not Found
Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable.
Some phones may need Special Boot Cable or TestPoint for EDL mode.
Found Port : Qualcomm HS-USB QDLoader 9008 (COM52)
Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2
Connecting to phone...OK
Waiting for response...Ignored
Hardware ID : E1009900 [8976] 00000000
OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A2 6AB1B4B3F1CF9E
Using Auto Loader Selection [3]
Device may possibly not boot with this loader.
Sending Loader [8976_002.ufl]...Done
Hardware* : 8976, eMMC, 16 GB
Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512
Writing [modem_0.img] -> [modem]...Done
Writing [sbl1_0.img] -> [sbl1]...Done
Writing [sbl1bak_0.img] -> [sbl1bak]...Done
Writing [rpm_0.img] -> [rpm]...Done
Writing [rpmbak_0.img] -> [rpmbak]...Done
Writing [tz_0.img] -> [tz]...Done
Writing [tzbak_0.img] -> [tzbak]...Done
Writing [devcfg_0.img] -> [devcfg]...Done
Writing [devcfgbak_0.img] -> [devcfgbak]...Done
Writing [dsp_0.img] -> [dsp]...Done
Writing [sec_0.img] -> [sec]...Done
Writing [splash_0.img] -> [splash]...Done
Writing [aboot_0.img] -> [aboot]...Done
Writing [abootbak_0.img] -> [abootbak]...Done
Writing [boot_0.img] -> [boot]...Done
Writing [recovery_0.img] -> [recovery]...Done
Writing [system_0.img] -> [system]...Done
Writing [cache_0.img] -> [cache]...Done
Writing [persist_0.img] -> [persist]...Done
Writing [misc_0.img] -> [misc]...Done
Writing [mdtp_0.img] -> [mdtp]...Done
Writing [cmnlib_0.img] -> [cmnlib]...Failed
Operation Finished.
Module Ver. 1.7
Old 02-25-2018, 07:43   #58 (permalink)
U.M.T's Avatar
Member: 2465108
Try again, and if error on same partition, then most possibly issue with hardware.
Alternative method is to untick partition which failed to flash and also those which flashed already, and then Flash again.
Br,
Ultimate Multi Tool
Old 02-25-2018, 09:07   #59 (permalink)
Member: 2501288
Thanks Meter: 328
Br,
Ultimate Multi Tool
Bro other tool flash this phone without any error.
Old 02-25-2018, 16:34   #60 (permalink)
U.M.T's Avatar
Member: 2465108
So, phone revived? If yes, then its ok, and we will try to fix this issue.
Br,
Ultimate Multi Tool
Page generated in 0.23714 seconds with 8 queries
