05-04-2018, 14:06 | #17 (permalink) |
No Life Poster Join Date: Nov 2009 Location: huanuco-peru
Member: 1168673 Status: Offline Sonork: 100.1638333 Thanks Meter: 235 | help to release modems Port : COM25 : FC - PC UI Interface (COM25) Baud Rate : 921600 Device : Huawei E5573Cs-322 Operation : Read Info Opening Port... OK Reading Information... OK Manufacturer : huawei Model : E5573Cs-323 Revision : 21.322.01.00.1430 IMEI : 862204031251304 Build : Dec 08 2016, 10:26:14 Software : 21.322.01.00.1430 Dashbaord : WEBUI_17.100.15.01.1430_MRE5 Hardware : CL1E5573CSM14 Ver.B Flash Code : 34690114 Lock Status : Unlocked (10 Attempts Left) Port Closed. Operation Finished. Elapsed Time: 00:05 [Module Ver. 4.9] Log Saved to Logs\180502_082411.log Port : COM25 : FC - PC UI Interface (COM25) Baud Rate : 921600 Device : Huawei E5573Cs-322 Operation : Unlock Opening Port... OK Reading Information... OK Manufacturer : huawei Model : E5573Cs-323 Revision : 21.322.01.00.1430 IMEI : 862204031251304 Build : Dec 08 2016, 10:26:14 Software : 21.322.01.00.1430 Dashbaord : WEBUI_17.100.15.01.1430_MRE5 Hardware : CL1E5573CSM14 Ver.B Flash Code : 34690114 Lock Status : Unlocked (10 Attempts Left) Resetting Network Lock... Failed Flash Unlock Firmware from Support First! Port Closed. Operation Failed. Elapsed Time: 00:05 [Module Ver. 4.9] Log Saved to Logs\180502_082441.log |
05-05-2018, 05:10 | #19 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Jalal Abad , Afghanistan
Member: 1318893 Status: Offline Sonork: 100.1640487 Thanks Meter: 279 | this is called weekly update , and hope to work on other huawei modems which are not supported, tnk team for ur effort. |
05-05-2018, 09:08 | #24 (permalink) |
Junior Member Join Date: Oct 2008 Location: chennai
Member: 879731 Status: Offline Sonork: 1234 Thanks Meter: 5 | Port : COM59 : Handset Diagnostic Interface(DFU) (COM59) Baud Rate : 921600 Device : ZTE V9C Operation : Unlock Opening Port... OK Reading Phone Information... OK Compile : Jul 13 2011 00:42:28 Release : Oct 26 2010 14:00:00 Hw Ver. : TSNCJOLY Build : 9GB_RLNC_V9CV1.0.0B03 IMEI : 355913041...... WIFI Addr : 000000000000 BT Addr : 344B50D362FB Unlocking Phone... Err 0x01 Port Closed. Operation Failed. Elapsed Time: 00:02 [Module Ver. 4.9.1] Log Saved to Logs\180505_133127.log |
The Following User Says Thank You to SSRLUCKY For This Useful Post: |
05-05-2018, 13:18 | #26 (permalink) |
Freak Poster Join Date: Nov 2016 Location: karachi
Member: 2650777 Status: Offline Sonork: 100.650600 Thanks Meter: 161 | Port : COM5 : HUAWEI Mobile Connect - 3G PC UI Interface (COM5) Baud Rate : 115200 Device : Huawei E5573s-320 Operation : Write Firmware (Emergency) Opening Port... OK Firmware : [BV7R11EU__4] [21.321.01.00.306] Partitions : 10 Checking Device... OK Validating Boot Mode... OK Bootloader : 7200B--SKCBADZM Device : HUAWEI BV7R11EU__4 Starting Flashing Process... Writing Partition... [0x00110000]... OK Writing Partition... [0x00200000]... OK Writing Partition... [0x00010000]... OK Writing Partition... [0x00090000]... OK Writing Partition... [0x00220000]... OK Writing Partition... [0x00230000]... OK Writing Partition... [0x00240000]... OK Writing Partition... [0x00250000]... OK Writing Partition... [0x00590000]... OK Writing Partition... [0x005A0000]... OK Waiting for Modem... . . OK Port : COM5 : HUAWEI Mobile Connect - 3G PC UI Interface (COM5) Restoring Data... Done Port Closed. Operation Finished. Elapsed Time: 01:09 [Module Ver. 4.9.1] Log Saved to Logs\180505_153537.log |
The Following User Says Thank You to kundicom For This Useful Post: |
05-05-2018, 19:00 | #28 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,665 | Quote:
Playing online games, or posting selfies? If you need support, open a thread and post full details with screenshot. This is the only normal way and NORMAL users do it. | |
The Following User Says Thank You to U.M.T For This Useful Post: |
