Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 07-04-2021, 21:35   #31 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Good update Keep it up
Old 07-05-2021, 06:19   #32 (permalink)
Member: 2818707
Thanks Meter: 48
Great job umt team love uuuuuu
Old 07-05-2021, 06:30   #33 (permalink)
Member: 2171555
Thanks Meter: 129
download link not working...
Old 07-05-2021, 08:24   #34 (permalink)
Member: 2983727
Thanks Meter: 16
what use of credit where xiaomi server is off? when you are fixing xiaomi server issue
Old 07-05-2021, 09:28   #35 (permalink)
Malik Shani G's Avatar
Member: 2963610
Thanks Meter: 560
always good update umt team....keep it up
Old 07-05-2021, 09:31   #36 (permalink)
Member: 2166052
Sonork: 100.1678339
Thanks Meter: 56
Great Update UMT Team. Keep it Up
Old 07-05-2021, 14:10   #37 (permalink)
Member: 1002905
Sonork: 100.1648296
Thanks Meter: 9
thanks team good update ................................
Old 07-05-2021, 14:56   #38 (permalink)
Member: 2879215
Joyeuse mi account ???
Old 07-06-2021, 02:47   #39 (permalink)
Member: 1598426
Thanks Meter: 31
another tool just copied umt update and called it world 1st
Old 07-06-2021, 14:43   #40 (permalink)
Member: 2067643
Sonork: 1611265
Thanks Meter: 474
oppo a37f
Device : Oppo A37f
Operation : Format FS
Checking for existing devices...Found
Port : Qualcomm HS-USB QDLoader 9008 (COM50)
Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0
Opening Port...OK
Init Handshake Sequence...OK
Hardware ID : E1507000 [8916] 00000000
OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A2 6AB1B4B3F1CF9E
Initializing Protocol...OK
Using Auto Loader Selection [1]
Preparing Loader...Done
Sending Loader [8916_014]...Done
Executing Loader...OK
Detecting Chip Type...OK
Hardware : 8916, EMMC, 16 GB
LU Count : 1 [0x01D1F000]
WARNING! High Speed Driver is not installed.
Please install driver from QcFire\Drivers folder using Device Manager.
Payload Info : In: 65536 [4096], Out: 16384, Sector Size: 512
Reading Partition Table...OK
Reading Device Information...OK
Device : OPPO A37f [msm8916]
Brand : OPPO
Prod.Name : A37f
Software : A37fEX_11_190711, 1480422943 [Thu Jul 11 03:29:34 CST 2019]
Android Ver. : 5.1.1
Patch Level : 2018-03-01
Formatting userdata [SafeMode]...Done
Resetting FRP Lock......Done
Operation Finished.
The Following User Says Thank You to iftikharrana58 For This Useful Post:
Old 07-07-2021, 22:28   #41 (permalink)
Member: 2082183
Sonork: 100.1638535
Thanks Meter: 53
Executing Loader...Failed! Possibly Wrong Loader
Operation : Reset Mi Account (New)
Checking for existing devices...Not Found
Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable.
Some phones may need Special Boot Cable or TestPoint for EDL mode.
Found Port : Qualcomm HS-USB QDLoader 9008 (COM13)
Driver Info : Network Connect, qcusbser.sys, 3.0.0.0
Connecting to phone...OK
Waiting for response...OK
Hardware ID : E1500A00 [SD855] 00007200
OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7
Sending Loader [prog_ufs_firehose_sdm855_ddr.elf]...Done
Please select Loader manually, or use Factory Loader in Custom Option.
Please use correct loader and check USB port / cable.
Operation Finished.
QcFire Ver. 7.0
Old 07-08-2021, 09:53   #42 (permalink)
Member: 2989421
keep stronger Umt team
Old 07-08-2021, 14:40   #43 (permalink)
Member: 1015679
Thanks Meter: 15
forbidden application 03 detected umt
dear sir i have installed new version(7.0) since then this error is coming
(forbidden application 03 detected umt)
i have not use any usb sharing software.
flexihub,WinPCap or USBPCap
i have find npf.sys in System32\Drivers folder. i am not able to delete or rename it
Edition Windows 10 Pro
Version 20H2
Installed on ‎15-‎05-‎2021
OS build 19042.1083
Experience Windows Feature Experience Pack 120.2212.3530.0
system type- 64-bit operating system, x64-based processor
Old 07-08-2021, 15:36   #44 (permalink)
U.M.T's Avatar
Member: 2465108
Sonork: No More Used
Thanks Meter: 13,432
Version 20H2
OS build 19042.1083
Simple way is to check ERR.LOG files in logs folder.
Br,
UMT
Old 07-09-2021, 04:18   #45 (permalink)
Member: 2989214
Thanks Meter: 89
Please add mi account + reset frp one click on mi account new option
Page generated in 0.26696 seconds with 10 queries
