07-10-2021, 19:42 | #61 (permalink) |
Insane Poster Join Date: Sep 2016 Location: Peshawar, Pakistan Age: 40
Member: 2622185 Status: Offline Sonork: 100.1675196 Thanks Meter: 19 | Great Team Great Update |
The Following User Says Thank You to Amin0092 For This Useful Post: |
07-11-2021, 06:53 | #64 (permalink) |
Freak Poster Join Date: Oct 2012 Location: Tanzania
Member: 1825908 Status: Offline Sonork: juju Thanks Meter: 60 | Redmi Note 8 qcn restore problem Hello, i need help.. Redmi Note 8 (ginko) flashed Eng rom then reset Efs in order to write Qcn (to repair imei) but unfortunatelly after write eng rom phone not power on! After i flashed original firmware set Ok but imei 0/98 (both imei 1&2). But bad lucky i tried all means to write qcn without success Tried to unlock bootloader also no way (full error) Tried to root (not possible because bootloader locked) Help me please engineers Phone is in MIUI 11 I used UMT with latest exe Qcfire 7.0 Last edited by U.M.T; 07-12-2021 at 00:00. Reason: Unnecessary Quote removed |
07-12-2021, 00:01 | #66 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Please read update post again. or read it: https://forum.gsmhosting.com/vbb/f97...-done-2978797/ Br, UMT |
The Following User Says Thank You to U.M.T For This Useful Post: |
07-14-2021, 17:01 | #72 (permalink) |
No Life Poster Join Date: Nov 2006 Location: DEATH VALLEY
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks Meter: 500 | NOKIA TA-1288 I GET THIS ERROR,,KINDLY SUPPORT IN NEXT UPDATE Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : HS-USB Diagnostics 9008 (COM25) Driver Info : Mobile, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1601300 [E1601300] 00000000 OPK_DATA : 33C81B0D9C95728D384C524C64A4E5996B51A9D888417B18AB 704ECD276936FF Initializing Protocol...OK Using Auto Loader Selection [0] CPU not found in database. Operation Finished. |
07-14-2021, 17:43 | #74 (permalink) |
Insane Poster Join Date: Dec 2010 Location: Pakistan
Member: 1471387 Status: Offline Sonork: 100.1596108 Thanks Meter: 12 | Solution please CPH2239 Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM108 Port Name: MediaTek USB Port (COM108) Path: \\?\usb#vid_0e8d&pid_0003#6&18e39b13&0&4#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0766, [MT6765] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: False DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... Disable Auth Success DA : MTK_AllInOne_DA.bin Waiting for Phone in Flash Mode... Disconnect cable and Power ON phone. Please check if correct Platform/DA is selected Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.3] |
07-14-2021, 17:43 | #75 (permalink) |
Member: 1471387 Status: Offline Sonork: 100.1596108 Thanks Meter: 12 | CPH2239 Lock remove Solution please CPH2239 Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM108 Port Name: MediaTek USB Port (COM108) Path: \\?\usb#vid_0e8d&pid_0003#6&18e39b13&0&4#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0766, [MT6765] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: False DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... Disable Auth Success DA : MTK_AllInOne_DA.bin Waiting for Phone in Flash Mode... Disconnect cable and Power ON phone. Please check if correct Platform/DA is selected Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.3] |
