12-15-2018, 12:31 | #61 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Br, UMT |
The Following User Says Thank You to U.M.T For This Useful Post: |
12-15-2018, 15:13 | #62 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Samsung N9005 write flash error :( Code: Model : Samsung Universal Operation : Flash Searching for Phone...Found Port: : COM11 : SAMSUNG Mobile USB Modem #2 Checking for Device...Found [Download Mode] Reading Data from Phone...Done Chipset : MSM8974 [HiSpeed] Sending Partition [ABOOT]...Done Sending Partition [SBL1]...Done Sending Partition [RPM]...Done Sending Partition [TZ]...Done Sending Partition [DBI]...Done Sending Partition [APNHLOS]...Done Sending Partition [BOOT]...Done Sending Partition [PERSIST]...Done Sending Partition [RECOVERY]...Done Sending Partition [SYSTEM]...Done Sending Partition [USERDATA]...Finalization Error Operation Failed. Elapsed Time 05:22 Module Ver. 0.2 |
The Following User Says Thank You to syed tuqeer For This Useful Post: |
12-17-2018, 18:52 | #64 (permalink) |
No Life Poster Join Date: May 2006 Location: wordwide Age: 48
Member: 279394 Status: Offline Sonork: 1591760 Thanks Meter: 105 | mr support Remove MDM Lock (Need Root Access / ENG Root) I have a question as is it possible to root samsung with the MDM locked at the moment of flashing ENG Root says it is locked ????? i have samsung J400M MDM locked br treo29 |
12-25-2018, 08:06 | #65 (permalink) |
Junior Member Join Date: Dec 2015 Location: ho chi minh cyty
Member: 2500472 Status: Offline Thanks Meter: 0 | Frp done but not done Model : J510FN Operation : FRP Reset (Format UD) Searching for Phone...Found Port: : COM86 : SAMSUNG Mobile USB Modem #41 Checking for Device...Found [Normal Mode] Reading Phone Information...OK Model: : SM-J510FN IMEI: : 357202077860709 Software: : J510FNXXU2BRB1/J510FNOLB2BRA6/J510FNXWU2BRA6/J510FNXXU2BRB1 Product : XXV Init Download Mode...OK Waiting for phone in Download Mode...OK Port: : COM70 : SAMSUNG Mobile USB Modem #32 Reading Data from Phone...Done Chipset : MSM8916 [HiSpeed] Loading Data...Done Sending Data...Done Closing Session...Done Operation Finished. Elapsed Time 00:43 Module Ver. 0.2 |
12-26-2018, 14:38 | #67 (permalink) |
Insane Poster Join Date: Jan 2016 Location: Derbent
Member: 2516133 Status: Offline Thanks Meter: 55 | SM-J510FN dead after trying to bypass userlock. The AP, BL and Combination files were correct. And now no charging, no detecting with PC. Model : Samsung Universal Operation : Flash ByPass Firmware Searching for Phone...Found Port: : COM116 : SAMSUNG Mobile USB Modem #45 Checking for Device...Found [Download Mode] Reading Data from Phone...Done Chipset : MSM8916 [HiSpeed] Loading Data...Done Sending Data...Done Closing Session...Done User cancelled the process. Operation Finished. Elapsed Time 19:30 Module Ver. 0.2 |
01-03-2019, 09:12 | #69 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Quote:
Br, UMT | |
01-10-2019, 12:17 | #72 (permalink) |
Insane Poster Join Date: Apr 2014
Member: 2171504 Status: Offline Thanks Meter: 51 | J727s Please call me remove issue i m trying to remove j727s please call me Oem lock Onn i flash combination and try to remove please call me but its need Eng root Anyone can pls share here is logs Model : Samsung Operation : Remove Call Me Searching for Device...Found Brand : samsung Model : SM-J727S Product : j7popelteskt Device : j7popelteskt Andriod Ver. : 7.0 Patch Level : 2017-02-01 PDA : FA70_J727SKSU2ARC1 Bootloader : FA70_J727SKSU2ARC1 Build ID : NRD90M.FA70_J727SKSU2ARC1 Build Date : Fri Mar 9 14:09:10 KST 2018 Checking Root Status...Done Root : No Root Please root phone, or use ENG Root from FRP Method. Operation Failed. Elapsed Time 00:04 Module Ver. 0.2 LOG Saved to !Logs\190110_161401.log |
01-11-2019, 11:26 | #74 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | N910P DRK repair error :( Code: Port : Android Debugging/Recovery Baud Rate : Not Applicable Device : Samsung Universal Operation : Fix Device Root Key Searching for Device in Recovery... Found Model : trltespr Version : 5.1.1 Hardware : qcom Platform : apq8084 CPU : armeabi-v7a Serial No. : 258adaa1 Preparing Data.... Done Fixing Device Root Key... Done Rebooting Phone... Done Operation Finished. Elapsed Time: 00:11 [Module Ver. 5.2] |
