Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 12-15-2018, 12:31   #61 (permalink)
U.M.T's Avatar
Member: 2465108
Sonork: No More Used
Thanks Meter: 13,432
You can try new method to reset frp or use combination. Then root phone using root image and then try Remove Call Me.
Br,
UMT
The Following User Says Thank You to U.M.T For This Useful Post:
Old 12-15-2018, 15:13   #62 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
Samsung N9005 write flash error :(
Model	: Samsung Universal
Operation	: Flash
Searching for Phone...Found
Port: 	: COM11 : SAMSUNG Mobile USB Modem #2
Checking for Device...Found [Download Mode]
Reading Data from Phone...Done
Chipset	: MSM8974 [HiSpeed]
Sending Partition [ABOOT]...Done
Sending Partition [SBL1]...Done
Sending Partition [RPM]...Done
Sending Partition [TZ]...Done
Sending Partition [DBI]...Done
Sending Partition [APNHLOS]...Done
Sending Partition [BOOT]...Done
Sending Partition [PERSIST]...Done
Sending Partition [RECOVERY]...Done
Sending Partition [SYSTEM]...Done
Sending Partition [USERDATA]...Finalization Error
Operation Failed.
Elapsed Time 05:22
Module Ver. 0.2
Same USB port / Cable Done with other Tool.
The Following User Says Thank You to syed tuqeer For This Useful Post:
Old 12-16-2018, 15:27   #63 (permalink)
Member: 654997
Thanks Meter: 4,073
Need Info
Hello Team ,
can i use this cable for RESET FRP (uart option ) ?
Old 12-17-2018, 18:52   #64 (permalink)
treo29's Avatar
Member: 279394
Sonork: 1591760
Thanks Meter: 105
mr support
Remove MDM Lock (Need Root Access / ENG Root)
I have a question as is it possible to root samsung with the MDM locked at the moment of flashing ENG Root says it is locked ?????
i have samsung J400M MDM locked
br
treo29
Old 12-25-2018, 08:06   #65 (permalink)
Member: 2500472
Frp done but not done
Model : J510FN
Operation : FRP Reset (Format UD)
Port: : COM86 : SAMSUNG Mobile USB Modem #41
Checking for Device...Found [Normal Mode]
Reading Phone Information...OK
Model: : SM-J510FN
IMEI: : 357202077860709
Software: : J510FNXXU2BRB1/J510FNOLB2BRA6/J510FNXWU2BRA6/J510FNXXU2BRB1
Product : XXV
Init Download Mode...OK
Waiting for phone in Download Mode...OK
Port: : COM70 : SAMSUNG Mobile USB Modem #32
Chipset : MSM8916 [HiSpeed]
Loading Data...Done
Sending Data...Done
Closing Session...Done
Operation Finished.
Elapsed Time 00:43
Module Ver. 0.2
Old 12-25-2018, 14:43   #66 (permalink)
U.M.T's Avatar
Member: 2465108
You need to wait until phone reboots and enter home screen.
Then do factory reset from menu.
Br,
UMT
Old 12-26-2018, 14:38   #67 (permalink)
Member: 2516133
Thanks Meter: 55
SM-J510FN dead after trying to bypass userlock. The AP, BL and Combination files were correct. And now no charging, no detecting with PC.
Operation : Flash ByPass Firmware
Port: : COM116 : SAMSUNG Mobile USB Modem #45
Loading Data...Done
Sending Data...Done
User cancelled the process.
Operation Finished.
Elapsed Time 19:30
Module Ver. 0.2
Old 01-02-2019, 15:29   #68 (permalink)
Member: 2253540
Sonork: N/A
Thanks Meter: 35
Sir, unlock some model networks???????
Old 01-03-2019, 09:12   #69 (permalink)
U.M.T's Avatar
Member: 2465108
Loading Data...Done
Sending Data...Done
Operation Finished.
Elapsed Time 19:30
Module Ver. 0.2
You selected old COMBINATION when making Reset Firmware, and it is the sole reason.
Br,
UMT
Old 01-05-2019, 02:06   #70 (permalink)
sindhi.aslam's Avatar
Member: 1919988
Thanks Meter: 178
Originally Posted by treo29 View Post
mr support
I have a question as is it possible to root samsung with the RMM locked at the moment of flashing ENG Root says it is locked ?????
i have samsung J400M RMM locked
br
treo29
Yes possible
Come inbox
Old 01-07-2019, 12:57   #71 (permalink)
Member: 654997
Thanks Meter: 4,073
@Team
Hello,
Please Add firmware name/ version in logs ..
Old 01-10-2019, 12:17   #72 (permalink)
Member: 2171504
Thanks Meter: 51
J727s Please call me remove issue
i m trying to remove j727s please call me
Oem lock Onn
i flash combination and try to remove please call me but its need Eng root
Anyone can pls share
here is logs
Model : Samsung
Operation : Remove Call Me
Searching for Device...Found
Brand : samsung
Model : SM-J727S
Product : j7popelteskt
Device : j7popelteskt
Andriod Ver. : 7.0
Patch Level : 2017-02-01
PDA : FA70_J727SKSU2ARC1
Bootloader : FA70_J727SKSU2ARC1
Build ID : NRD90M.FA70_J727SKSU2ARC1
Build Date : Fri Mar 9 14:09:10 KST 2018
Checking Root Status...Done
Root : No Root
Please root phone, or use ENG Root from FRP Method.
Operation Failed.
Elapsed Time 00:04
Module Ver. 0.2
LOG Saved to !Logs\190110_161401.log
Old 01-10-2019, 23:14   #73 (permalink)
U.M.T's Avatar
Member: 2465108
Either ENG ROOT or make rooted image with umt.
Br,
UMT
Old 01-11-2019, 11:26   #74 (permalink)
Member: 654997
Thanks Meter: 4,073
N910P DRK repair error :(
Port	: Android Debugging/Recovery
Baud Rate	: Not Applicable
Device	: Samsung Universal
Operation	: Fix Device Root Key
Searching for Device in Recovery... Found
Model	: trltespr
Version	: 5.1.1
Hardware	: qcom
Platform	: apq8084
CPU	: armeabi-v7a
Serial No.	: 258adaa1
Preparing Data.... Done
Fixing Device Root Key... Done
Rebooting Phone... Done
Operation Finished.
Elapsed Time: 00:11
[Module Ver. 5.2]
repair done in logs , but in phone same drk failed xxxxxx problem
Old 01-11-2019, 17:11   #75 (permalink)
U.M.T's Avatar
Member: 2465108
Try to full flash phone and check again.
Or, try UART Method.
Br,
UMT
Page generated in 0.25723 seconds with 8 queries
