Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 05-05-2020, 06:23   #46 (permalink)
umardarz's Avatar
Member: 1054358
Sonork: 100.1626312
Thanks Meter: 269
oppo f11 pro support....????
The Following User Says Thank You to umardarz For This Useful Post:
Old 05-08-2020, 07:31   #47 (permalink)
Member: 2544709
Sonork: shivapradhan0
Thanks Meter: 25
how to solve
The Following User Says Thank You to hackersofnepal For This Useful Post:
Old 05-08-2020, 08:04   #48 (permalink)
yuranc8's Avatar
Member: 2680008
Thanks Meter: 922
Hello, I have a Xiaomi Redmi Note 8 with MIUI 11 if I pass the Partition (Persist) with UMT EMMC after I connect to the wifi, will it be blocking again? or first of all having to activate USB debugging and use Mi account relock Fix!
The Following User Says Thank You to yuranc8 For This Useful Post:
Old 05-09-2020, 06:54   #49 (permalink)
Member: 2404246
Thanks Meter: 11
Originally Posted by hackersofnepal View Post
how to solve
same my error , plz help
The Following User Says Thank You to ngminh888 For This Useful Post:
Old 05-09-2020, 09:47   #50 (permalink)
zeeshan ali 786's Avatar
Member: 2711874
Sonork: 100.650600
Thanks Meter: 447
oppo relme new models sported....?
The Following User Says Thank You to zeeshan ali 786 For This Useful Post:
Old 05-09-2020, 15:30   #51 (permalink)
Member: 2835487
Thanks Meter: 144
[url=https://postimages.org/][img]https://i.postimg.cc/28YNqNk1/FREEFIRE-DAIMOND.jpg[
how to solve
u need activation for using umt emmc tool
The Following User Says Thank You to samfrnds90 For This Useful Post:
Old 05-13-2020, 17:44   #52 (permalink)
Ankit Verma's Avatar
Member: 506648
Sonork: 100.1614254
Thanks Meter: 688
Oppo A7 CPH1901 Password Unlock by Umt Emmc Isp Tool
http://www.youtube.com/watch?v=Y-lfvf1nWhw
Old 05-13-2020, 23:01   #53 (permalink)
Member: 366884
Thanks Meter: 11
Thumbs down Umt emmc adapter not detected
Please i need you to put me through, i tried to work on 2 different phone with the emmc adapter to no success. When i connected the emmc adapter to the PC it show noting at the device manager, please do i need any driver for the emmc adapter?
The Following User Says Thank You to JOTECH For This Useful Post:
Old 05-14-2020, 16:44   #54 (permalink)
U.M.T's Avatar
Member: 2465108
Sonork: No More Used
Thanks Meter: 10,682
EMMC Adaptor does not need any driver.
It will be detected under Disk Drives in Device Manager.
If you connect emmc properly, it will be detected witout any issue.
Br,
UMT
The Following User Says Thank You to U.M.T For This Useful Post:
Old 05-17-2020, 05:25   #55 (permalink)
Iftakhar Rajper's Avatar
Member: 2705849
Thanks Meter: 496
Good update plz add oppo A1k support
The Following User Says Thank You to Iftakhar Rajper For This Useful Post:
Old 05-23-2020, 14:13   #56 (permalink)
geriaf's Avatar
Member: 193303
Sonork: 100.1613585
Thanks Meter: 94
I can use another EMMC interfase tool? for example Medusa Pro or easy tool?
I not have box i have dongle.
br
The Following User Says Thank You to geriaf For This Useful Post:
Old 05-25-2020, 10:39   #57 (permalink)
Member: 366884
Thanks Meter: 11
My UMT Adapter was detected, but like 5 phones tried but the results were reading partition failed, I already modified adapter with 150 ohms resistors to no avail. Please what could be the problem why i am not getting it working. All isp point connection were confirmed to be properly connected with millimeter. Please guide on what maybe wrong.
Old 05-25-2020, 19:54   #58 (permalink)
Member: 2478245
Sonork: 100.1669922:JOTECH
Thanks Meter: 5
Oppo password reset problem
i wanted to reset some Oppo password with UMT + THE ADAPTER, i soldier the isp pinout, the CLK, CMD, DATA-O AND GND WITHOUT CONNECTING THE VCC AND VCCQ but used usb cable instead. on device manager the phone is detected as HS-USB Diagnostics 9008 and not as drive. please i need help. Thanks
The Following User Says Thank You to ILESANMI JOSEPH For This Useful Post:
Old 05-26-2020, 02:52   #59 (permalink)
okello's Avatar
Member: 1610674
Sonork: 210921
Thanks Meter: 154
my advice is connect the usb cable to a charger or another source rasther the same pc you are using
The Following User Says Thank You to okello For This Useful Post:
Old 05-26-2020, 03:32   #60 (permalink)
Mobile_Control's Avatar
Member: 998119
Thanks Meter: 79
where is the error correction for MTK, itís been a long time since the bug report
The Following User Says Thank You to Mobile_Control For This Useful Post:
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.32812 seconds with 7 queries
