Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 04-09-2021, 00:07   #1 (permalink)
Fast Unlocking's Avatar
Member: 94675
Sonork: 100.8888 QQ3161545070
Thanks Meter: 87,885
[09-04-21] UMTv2/UMTPro - UltimateMTK v4.1 - Oppo, Realme, Nokia NB0 Extracter & more
UMTv2 / UMT Pro
UltimateMTK v4.1
Supported functions:
- Read Info
- Reset FRP (For devices supporting this feature)
- Reset Locks (All Android Versions, Encrypted Userdata NOT Supported)
- Read Pattern (Android 5.x and earlier, Encrypted Userdata NOT Supported)
- Format FS
- Format FS (Advance)
- IMEI Repair in META / Boot Mode
- Backup NVRAM
- Restore NVRAM
- Reboot to META / FACTORY / FASTBOOT Mode
- Added Support for Helio CPU (MT6750, MT6755, MT6763, MT6739 etc)
- Disable Lock / Restore Lock for Encrypted Userdata
- Remove Locks for Encrypted Userdata for Vivo
- Factory Reset in META Mode (Vivo, Oppo and others)
- SafeFormat Option to let device format itself safely in recovery
- Added Support for Helio X20 (MT6797)
- Oppo/Realme Safe Factory Reset in META Mode
- Added Disable Auth to disable SLA/DAA
- Added Mi Account Reset
- Xiaomi IMEI Repair
- NVRAM/NVDATA Format
- META Reboot for SLA Enabled Devices
Added:
Gionee
- F205
iTel
- A62
Oppo
- A12 (CPH2083)
- Narzo 20 Pro (RMX2161)
- R15 (PACM00)
- Realme 3i (RMX1827)
- Realme 7 (RMX2151)
- Realme 7 (RMX2163)
- Reno2Z (CPH1951)
Tecno
- Spark Go 2020 (KE5)
Updated META (New) IMEI Repair Method
- There should not be "Failed to locate" error anymore
- If Xiaomi Method does not work, use this method instead
Updated Oppo Reset in META Mode
- Now device creating ETS/ELT port should work fine
Added Nokia (nb0) Firmware extraction
- Only Generic Factory Firmware is supported
Added Format NVDATA on NVRAM Restore
Special thanks to:
- neyaz007
- nksonu_jobner
Important
- Features introduced may work on other devices too, which are not listed here.
- User needs to untick By Model checkbox to be able to select Platform manually.
- For manual work, just select Platform and DA.
- For new secured devices, use Disable Auth, and select Preloader.
- Rest operations will work same.
Note : Some features are device/OS specific and may not work on all devices.
WARNING :
ESN / MEID / IMEI REPAIR IS INTENDED TO REPAIR ESN / MEID / IMEI TO ORIGINAL ONE WRITTEN ON PHONE BACK LABEL / BOX. WE DO NOT ENDORSE OR ENCOURAGE ESN / MEID / IMEI CHANGING. ITS ILLEGAL. USER IS SOLE RESPONSIBLE FOR ANY ILLEGAL ACTIVITY DONE WITH USE OF FEATURES PROVIDED IN OUR SOFTWARE, NOT LIMITED TO ESN / MEID / IMEI.
ANY USER USING OUR SOFTWARE FOR ILLEGAL PURPOSE WILL BE SOLE RESPONSIBLE FOR HIS ACTS.
WE CONDEMN USE OF OUR SOFTWARE FOR ANY ILLEGAL PURPOSE.
Download using Support Access or Mirrors
Official Website
The Following 47 Users Say Thank You to Fast Unlocking For This Useful Post:
Old 04-09-2021, 00:19   #2 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,177
nice update umt team please add option read firmware too
The Following User Says Thank You to CHANDARAKK For This Useful Post:
Old 04-09-2021, 00:33   #3 (permalink)
FFX
FFX's Avatar
Member: 1332792
Thanks Meter: 102
Please add bootloader Unlock for xiaomi mtk
The Following 2 Users Say Thank You to FFX For This Useful Post:
Old 04-09-2021, 00:54   #4 (permalink)
Member: 2220699
Thanks Meter: 71
Please team. Add reading firmware...
Add unlock bootloader...
Add bypass antirelock...
The Following 3 Users Say Thank You to jerrsoftware For This Useful Post:
Old 04-09-2021, 04:00   #5 (permalink)
Member: 1752305
Thanks Meter: 64
Great Update UMT Team
Old 04-09-2021, 04:50   #6 (permalink)
Member: 1185918
Sonork: 100.1617322
Thanks Meter: 125
Good Update for MediaTek Devices
Carry on We are hopeful for more good news
thnx Team
Old 04-09-2021, 06:09   #7 (permalink)
Member: 1910376
Thanks Meter: 49
plz ad vivo fastboot to edl
The Following 4 Users Say Thank You to khothbharat For This Useful Post:
Old 04-09-2021, 06:55   #8 (permalink)
Member: 2947987
Sonork: Null
Thanks Meter: 17
Nice update umt team
Sent from my CPH1727 using Tapatalk
Old 04-09-2021, 07:07   #9 (permalink)
Nishan_Raja's Avatar
Member: 2554807
Thanks Meter: 545
Oppo A12 Nt LOCK unlock BUT still lock
Operation : Oppo Unlock
Hold VOL UP + DOWN and connect USB Cable.
Some phone may have different key combination for BROM mode.
Waiting for device in BROM mode...
Port: COM6
Port Name: MediaTek USB Port_V1632 (COM6)
Path: \\?\usb#vid_0e8d&pid_0003#5&143fc924&0&9#{86e0d1e0-8089-11d0-9ce4-08003e301f73}
Chipset: 0x0766, [MT6765]
Hardware Info: 0x8A00, 0xCA00, 0x00
SecureBoot: True
SLA: False
DA Auth: True
Disabling WatchDog...
- Success
Sending Payload data...
- Payload sent
Initiating Control Transfer...
- Done
Waiting for result...
- Result: 0xA1A2A3A4
Disable Auth Success
Waiting for Phone in Flash Mode...
Connect Power Off phone within 30 secs...
Port : MediaTek USB Port_V1632 (COM6)
Connected to BROM.
Sending Download Agent...
connect DA end stage: 2, enable DRAM in 1st DA: 0
Connected to Download Agent..
Executing Flashing Task...
Syncing with Target...
Reading Partition Table...
Storage : eMMC
Reading Device Information...
Manufacturer : OPPO
Build Flavor : full_oppo6765_19451-user
Build Desc. : full_oppo6765_19451-user 9 PPR1.180610.011 eng.root.20210118.235914 release-keys
Android Ver. : 9
Patch Level : 2021-01-05
Platform : MT6765
Board : oppo6765_19451
Platform : mt6765
Userdata is NOT ENCRYPTED
Unlocking Simlock...
- Done.
Disconnect Battery/Cable and Power On Phone.
[UltimateMTK Ver. 4.1]
Old 04-09-2021, 07:44   #10 (permalink)
raisalina's Avatar
Member: 1911970
Sonork: 9741081772
Thanks Meter: 1,860
oppo f9 cph1881 extracted firmware downgrade done.
CPU : MT6771
Storage : EMMC
Scatter : C:\Users\Salina\Desktop\Oppo F9 CPH1881\Extracted\MT6771_Android_scatter.txt
DA Version : MTK_AllInOne_DA_v3.3001.2019-12-31.22:58
Port: COM9
Port Name: MediaTek USB Port_V1633 (COM9)
Path: \\?\usb#vid_0e8d&pid_0003#5&29057cd7&0&4#{86e0d1e0-8089-11d0-9ce4-08003e301f73}
Chipset: 0x0788, [MT6771]
SecureBoot: True
SLA: False
DA Auth: True
- Success
- Payload sent
- Done
Connect Power Off phone now...
Port : MediaTek USB Port_V1633 (COM9)
Connected to BROM.
[0] WRITE TO PARTITION [ preloader ]
Flashing Bootloader...
[3] WRITE TO PARTITION [ recovery ]
Flashing Firmware...
[22] WRITE TO PARTITION [ md1img ]
[23] WRITE TO PARTITION [ spmfw ]
[24] WRITE TO PARTITION [ scp1 ]
[25] WRITE TO PARTITION [ scp2 ]
[26] WRITE TO PARTITION [ sspm_1 ]
[27] WRITE TO PARTITION [ sspm_2 ]
[28] WRITE TO PARTITION [ cam_vpu1 ]
[29] WRITE TO PARTITION [ cam_vpu2 ]
[30] WRITE TO PARTITION [ cam_vpu3 ]
[34] WRITE TO PARTITION [ lk ]
[35] WRITE TO PARTITION [ lk2 ]
[36] WRITE TO PARTITION [ boot ]
[37] WRITE TO PARTITION [ logo ]
[38] WRITE TO PARTITION [ odmdtbo ]
[39] WRITE TO PARTITION [ tee1 ]
[40] WRITE TO PARTITION [ tee2 ]
[41] WRITE TO PARTITION [ odm ]
write signature file. [ C:\Users\Salina\Desktop\Oppo F9 CPH1881\Extracted\vendor.sig ]
[42] WRITE TO PARTITION [ vendor ]
write signature file. [ C:\Users\Salina\Desktop\Oppo F9 CPH1881\Extracted\system.sig ]
[43] WRITE TO PARTITION [ system ]
[44] WRITE TO PARTITION [ cache ]
write signature file. [ C:\Users\Salina\Desktop\Oppo F9 CPH1881\Extracted\userdata.sig ]
[45] WRITE TO PARTITION [ userdata ]
Flashing Done.
Disconnect cable and Power ON phone.
The Following 4 Users Say Thank You to raisalina For This Useful Post:
Old 04-09-2021, 07:57   #11 (permalink)
Member: 2882702
Thanks Meter: 29
good update......
Old 04-09-2021, 08:15   #12 (permalink)
Member: 2816782
Sonork: 100.1596027
Good Update ��������������
Old 04-09-2021, 08:47   #13 (permalink)
Member: 2973928
Thanks Meter: 39
Great work team but plzz add MT6779V Helio P95 (12 nm & MT6853 Dimensity 800U 5G (7 nm) thnxxx...
The Following User Says Thank You to blushis For This Useful Post:
Old 04-09-2021, 09:16   #14 (permalink)
U.M.T's Avatar
Member: 2465108
Sonork: No More Used
Thanks Meter: 10,682
It is just request and you have checked it supported?
Br,
UMT
Old 04-09-2021, 09:19   #15 (permalink)
U.M.T's Avatar
Member: 2465108
Port: COM6
SecureBoot: True
SLA: False
DA Auth: True
- Success
- Payload sent
- Done
Connected to BROM.
Storage : eMMC
Manufacturer : OPPO
Android Ver. : 9
Platform : MT6765
Platform : mt6765
- Done.
You need to repeat both Flash mode and then Meta mode unlocking.
Btw, this is beta and may not work, but some user reported working on some phone.
This is the reason we never mentioned it.
Br,
UMT
The Following User Says Thank You to U.M.T For This Useful Post:
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.29030 seconds with 7 queries
