10-20-2021, 04:31 | #66 (permalink) |
Freak Poster Join Date: May 2011 Location: Panamá
Member: 1570514 Status: Offline Thanks Meter: 59 | Realme C11 2021 FRP Code: [0]Custom loader: RMX3231-user-native_SHARKL3_R11.loader Phone Storage: EMMC EXE: Ultimate Unisoc Module v0.1 SELECTED: Autodetect by loader ACTION: Erase FRP Loader format:NEW Start Detect phone... Phone must be off with battery inside. Long press "VOL -" key while inserting usb cable. For some phones need to Long press "VOL -"+ "VOL +" key while inserting usb cable. Detected: SPRD U2S Diag (COM4) Sending loader, keep boot key untill loader start. Loader OK: Spreadtrum Boot Block version 1.1 Changing bautrate OK. Send Second Loader. New flash metod detected. *************** [S]Manufacturer: realme [S]Brand: realme [S]Device: RMX3231 [S]Model: RMX3231 Build ID: RP1A.201005.001 CPU arhitecture: armeabi-v7a Build product name: RMX3231 Build description: RMX3231-user 11 RP1A.201005.001 72 release-keys Build Id: RP1A.201005.001 Android Release: 11 Android Version: RMX3231_11.A.28 Security patch: 2021-05-05 Removing frp, wait... Format OK. [can take 0-10 sec]Wait untill phone restart. Log saved: C:\Users\RTX\Documents\spreadtrum_module\Saved_Logs\RMX3231_11.A.28_erase_frp.txt Total Time: 00:00:20 Done. |
The Following User Says Thank You to kem89 For This Useful Post: |
10-25-2021, 16:03 | #67 (permalink) |
No Life Poster Join Date: Feb 2012 Location: Pakistan
Member: 1726229 Status: Offline Thanks Meter: 223 | L5006C frp ?? [0]Custom loader: L5006C-F3212-10.0-IN-V020-20201124_2157_user_1.loader Phone Storage: EMMC EXE: Ultimate Unisoc Module v0.1 SELECTED: Autodetect by loader ACTION: Erase FRP Loader format:NEW Start Detect phone... Phone must be off with battery inside. Long press "VOL -" key while inserting usb cable. For some phones need to Long press "VOL -"+ "VOL +" key while inserting usb cable. Detected: SPRD U2S Diag (COM34) Sending loader, keep boot key untill loader start. Loader OK: Spreadtrum Boot Block version 1.1 Changing bautrate OK. Send Second Loader. New flash metod detected. [BSL_CMD_DISABLE_TRANSCODE]Error send frame Restart phone and try again, if problem still persist, posible loader is not accepted by phone. |
11-20-2021, 07:52 | #71 (permalink) | |
Major Poster Join Date: Jul 2011 Location: Russia
Member: 1615277 Status: Offline Thanks Meter: 11 | Quote:
------------ Action: Reset Phone. Detecting phone, wait... Using connection mode 2 Detected: SPRD U2S Diag (COM130) Platform Version: MOCORTM_14B_MP_7731G_W16.28.2_Debug Project Version: sc7731g_CP0_modem BASE Version: TM_BASE_W16.28.2 HW Version: sc7731g_CP0_modem 07-04-2016 12:49:15 Build number: sp7731c_1h10_32v4_oversea-user 6.0 MRA58K eng.ylh-hdf253.20171219.193703 release-keys IMEI 1: 355202 IMEI 2: 355202 IMEI 3: 867400 IMEI 4: 867400 DONE DONE DONE DONE Reset done, phone must restart. Done. Log saved: C:\Users\OZ\Documents\spreadtrum_module\Saved_Logs \sp7731c_1h10_32v4_oversea-user6.0MRA58Keng.ylh-hdf253.20171219.193703release-keys_3552_diag_reset_phone.txt | |
11-20-2021, 09:36 | #72 (permalink) | |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,254 | Quote:
did you try flashing the phone? what was the issue with phone in first place? | |
11-20-2021, 09:58 | #73 (permalink) | |
does not connect with a standard loader. connected through the diagnostic mode. the same can be seen in the logs. And how would I make a custom loader if the body is a clone. there is no firmware on it. well, I haven't found them yet. just did a factory reset and that's it. | |
