Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 11-15-2022, 04:46   #31 (permalink)
Member: 1744748
Thanks Meter: 746
Samsung MDM Unlock in EDL Mode
does this function actually work?
Old 11-15-2022, 08:19   #32 (permalink)
haroon454's Avatar
Member: 653398
Sonork: 100.1619594
Thanks Meter: 637
mi note 10 5g frp reset done
Searching for phone in sideload mode...Found
Device Id : camellian_global
Version : V13.0.3.0.SKSMIXM
Code Base : 12
Ext Info : GB, en, F
Model : M2103K19C
Reading Partition Table...OK
Resetting FRP...Done
Operation Finished.
QcFire Ver. 8.3
The Following 3 Users Say Thank You to haroon454 For This Useful Post:
Old 11-15-2022, 08:23   #33 (permalink)
prince2047's Avatar
Member: 1181899
Thanks Meter: 75
redmi note 10a mi account remove on click
Operation : Reset Mi Account (Sideload)
Device Id : mojito_in_global
Version : V13.0.3.0.SKGINXM
Code Base : 12
Serial : 0x36d0c9db
Ext Info : US, en, F, 2, 2
Model : mojito
Resetting Mi Account...Done
Account : 17923
Phone : +91810*****34
Display ID : 3REI6ZHHLNPQ
Unsupported Device for Anti-Relock!
Operation Finished.
QcFire Ver. 8.4
The Following 3 Users Say Thank You to prince2047 For This Useful Post:
Old 11-16-2022, 15:21   #34 (permalink)
Member: 797019
Thanks Meter: 25
Operation : Flash Miui Package (Sideload)
Device Id : alioth_global
Version : V13.0.6.0.SKHMIXM
Code Base : 12
Serial : 0x204b6c3d
Ext Info : GB, en, F, 2, 2
Model : M2012K11AC
Package : miui_ALIOTHGlobal_V13.0.6.0.SKHMIXM_e83b44e411_12. 0.zip
Calculating Firmware Hash...OK
Requesting Token...OK
Sending Package...Completed
Operation Finished.
QcFire Ver. 8.4
The Following 2 Users Say Thank You to fcel For This Useful Post:
Old 11-17-2022, 12:01   #35 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,214
Good work UMT Team Keep it up
Old 11-17-2022, 23:17   #36 (permalink)
Member: 181405
Thanks Meter: 245
Device Id : cupid
Version : V13.0.4.0.SLCLMCR
Code Base : 12
Serial : 0x000004328d4f184b
Ext Info : , es-US, F, 2, 2
Model : 2201123G
Package : miui_CUPIDGlobal_V13.0.4.0.TLCMIXM_271430c4dc_13.0 .zip
Requesting Token...Failed
Error : No puede instalar un ROM no oficial.
Operation Failed.
QcFire Ver. 8.4
Old 11-19-2022, 10:38   #37 (permalink)
bk.gsm's Avatar
Member: 869809
Thanks Meter: 1,336
Device Id : cupid
Code Base : 12
Model : 2201123G
Operation Failed.
QcFire Ver. 8.4
you are using different region firmware or it's not official rom
b.r.
Old 11-22-2022, 05:02   #38 (permalink)
Member: 2264179
Thanks Meter: 3
Operation : Reset FRP (Sideload)
Device Id : merlin_in_global
Version : V12.0.8.0.QJOINXM
Code Base : 10
Serial : 0xb0669f9401f57f5b5d85bb3cab54aacd763f0728
Ext Info : IN, en, F, 2, 2
Model : M2003J15SC
Reading Partition Table...Failed
Operation Failed.
QcFire Ver. 8.4
Old 11-22-2022, 06:35   #39 (permalink)
Member: 172261
Thanks Meter: 308
Device : Xiaomi Poco F1
Checking for existing devices...Not Found
Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable.
Some phones may need Special Boot Cable or TestPoint for EDL mode.
Found Port : Qualcomm HS-USB QDLoader 9008 (COM30)
Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2
Connecting to phone...OK
Waiting for response...OK
Init Handshake Sequence...OK
Hardware ID : E1B00800 [SDM845] 00007200
OPK_DATA : 99AF649E077EBCE3E9E187442ABDC70BD715756DE9ED192E9F 7883A10EBE09F4
Initializing Protocol...OK
Using Auto Loader Selection [1]
Preparing Loader...Done
Sending Loader [SDM845]...Done
Executing Loader...OK
Auth Enabled Device! You may need Mi Auth Account to service!
Skipping Auth...OK
Detecting Storage Type...OK
Hardware : SDM845, UFS, 128 GB
LU Count : 6 [0x01CA5800] [0x00000800] [0x00000800] [0x00002000] [0x00120000] [0x00002000]
WARNING! High Speed Driver is not installed.
Please install driver from QcFire\Drivers folder using Device Manager.
Payload Info : In: 262144 [65536], Out: 16384, Sector Size: 4096
Reading Device Information...OK
Device : Xiaomi
Software : , V12.0.3.0.QEJMIXM [Sun Dec 27 14:13:40 WIB 2020]
Android Ver. : 10
Patch Level : 2020-12-01
Resetting FRP Lock.......Done
Operation Finished.
QcFire Ver. 8.4
The Following User Says Thank You to andre128 For This Useful Post:
Old 11-24-2022, 17:50   #40 (permalink)
Member: 1550712
Thanks Meter: 17
Device Id : renoir_global
Version : V12.5.2.0.RKIMIXM
Code Base : 11
Serial : 0xa9e17fc5
Model : M2101K9G
Reading Partition Table...[115] OK
Account : 1665249865
Display ID : 44EX-X52Y-6HRMQA
Operation Finished.
QcFire Ver. 8.4.1
At the end of the operation, the device continues to be blocked by the MI account
Old 11-24-2022, 18:27   #41 (permalink)
U.M.T's Avatar
Member: 2465108
Sonork: No More Used
Thanks Meter: 11,808
Code Base : 11
Serial : 0xa9e17fc5
Model : M2101K9G
Operation Finished.
QcFire Ver. 8.4.1
MTK device is not yet supported for Anti Relock in sideload.
Br,
UMT
Old 11-24-2022, 23:05   #42 (permalink)
Crazy Poster
Member: 2919541
Sonork: Tasawariqbal110
Thanks Meter: 8
اَلسَلامُ عَلَيْكُم وَرَحْمَةُ اَللهِ وَبَرَكاتُهُ‎
U didn't mension
What is the purpose of these models
Or which support added ?
Samsung
- Galaxy A6s SM-G6200
- Galaxy A71 (SM-A715F)
- Galaxy A80 (SM-A805F)
- Galaxy S10e (SM-G970U)
- Galaxy S20 5G (SM-G981U)
Old 11-25-2022, 07:41   #43 (permalink)
Y Michael's Avatar
Member: 2947987
Sonork: Null
Thanks Meter: 40
Originally Posted by Tasawariqbal View Post
اَلسَلامُ عَلَيْكُم وَرَ*ْمَُ اَللهِ وَبَرَكاتُهُ‎
U didn't mension
Samsung
The Samsung model added is for removing frp
Sent from my CPH1727 using Tapatalk
Old 11-25-2022, 11:44   #44 (permalink)
Member: 1485505
Redmi note 10 pro sweet flash error help please
HELP PLEASE
Operation : Multi Flash
Checking for existing devices...Found
Port : Qualcomm HS-USB QDLoader 9008 (COM6)
Opening Port...OK
Hardware ID : E1600E00 [SM7150] 00007200
OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7
Sending Loader [SM7150]...Done
Skipping Auth...Failed
Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJFUlJPUjogQmxvYiBzaG91 bGQgaW5pdCBmaXJzdC4iIC8+PC9kYXRhPjw/eG1sIHZlcnNpb249IjEuMCIgZW5jb2Rpbmc9IlVURi04IiA/Pgo8ZGF0YT4KPHJlc3BvbnNlIHZhbHVlPSJOQUsiIHJhd21vZG U9ImZhbHNlIiAvPjwvZGF0YT5=
Reading Auth Blob...OK
Blob : NDE1MTQxNDE0MTQ3MzA0MjQxNDE0MjU3NTY2QzU2NjE3NzcyNj Q2QzUzN0EzMjZCNjQ0Mzc1NjY2NjM5NzQ2QzMyNjU3ODZGNTY3 Nz==
Requesting UMT Server for Auth Data...Sign key getting error
Storage Initializaton Failed!
Please use correct loader and check USB port / cable.
Operation Failed.
QcFire Ver. 8.4.1
Old 11-29-2022, 08:44   #45 (permalink)
Member: 172261
Thanks Meter: 308
Redmi Note8 mi account
Device Id : ginkgo_global
Version : V12.5.2.0.RCOMIXM
Code Base : 11
Serial : 0xedd2008f
Model : Redmi Note 8
Account : 6278867018
Phone : +62818*****88
Display ID : 44UW-AMXC-JTW4-CK1
Applying Anti-Relock Patch...Done
Operation Finished.
QcFire Ver. 8.4
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.11958 seconds with 7 queries
