Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 12-27-2018, 15:07   #76 (permalink)
Member: 2863973
Thanks Meter: 6
UMT TEAM please update on qc fire tool support vivo v11 pro flashing...every body reset efs this phone and can not restore efs ,invalid imei ,so please solution any chance this phone flashing support or write original efs file thanks advance ,,hope you will be fix it.
The Following User Says Thank You to Raazgsm1 For This Useful Post:
Old 12-31-2018, 13:32   #77 (permalink)
Member: 2814511
Thanks Meter: 51
Xiaomi redmi note 5A mi account remove done by UMT ....................
The Following 2 Users Say Thank You to gsmmim For This Useful Post:
Old 01-03-2019, 16:31   #78 (permalink)
Member: 772386
Thanks Meter: 157
We want oppo ofp file extractor
Please add this next update
Only xxxx team have this
Old 01-04-2019, 00:57   #79 (permalink)
Member: 1212969
Sonork: 141023
menunggu UMT update suppot tipe teratas .
Old 01-04-2019, 01:07   #80 (permalink)
Member: 2238099
Thanks Meter: 4
pocophone f1 remove mi cloud supported
miui 10
Old 01-05-2019, 10:14   #81 (permalink)
Member: 2741816
Thanks Meter: 3
oneplus 6 imei repair is it okay ???
Old 01-05-2019, 22:23   #82 (permalink)
Member: 586491
please update for xiaomi Mi 8 remove account
Old 01-10-2019, 00:39   #83 (permalink)
Member: 2608186
Thanks Meter: 7
sir, when are you going to have pocophone f1 my cloud solution?
Old 01-10-2019, 10:00   #84 (permalink)
U.M.T's Avatar
Member: 2465108
Sonork: No More Used
Thanks Meter: 12,139
Try to extract firmware and then see what is supported by xxxx.
Old 01-10-2019, 15:57   #85 (permalink)
Member: 1797426
Thanks Meter: 253
Hi,Team i have xiaomi Mi8 for test ,need to remove mi account.Can you help?
Old 01-12-2019, 17:02   #86 (permalink)
kachman's Avatar
Member: 272581
Thanks Meter: 118
MI MAX 3 Cannot remove MI account
Device : Xiaomi Mi Max 3
Operation : Disable Mi Account
Checking for existing devices...Found
Port : Qualcomm HS-USB QDLoader 9008 (COM20)
Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.0.5
Opening Port...OK
Init Handshake Sequence...OK
Hardware ID : E1C00C00 [8996] 00000000
OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1
Initializing Protocol...OK
Using Auto Loader Selection [1]
Preparing Loader...Done
Sending Loader [8996_016]...Done
Executing Loader...OK
Using User Defined Storage Type : UFS
VIP Enabled / Auth Enabled Device!
Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJFUlJPUjogT25seSBub3Ag YW5kIHNpZyB0YWcgY2FuIGJlIHJlY2V2aWVkIGJlZm9yZSBhdX RoZW50aWNhdGlvbi4iLz4KPC9kYXRhPjw/eG1sIHZlcnNpb249IjEuMCIgZW5jb2Rpbmc9IlVURi04IiA/Pgo8ZGF0YT4KPHJlc3BvbnNlIHZhbHVlPSJOQUsiIC8+CjwvZG F0YT5=
Please use correct loader and check USB port / cable.
Operation Finished.
QcFire Ver. 3.5
Old 01-16-2019, 13:12   #87 (permalink)
Member: 2620603
Thanks Meter: 35
Please help! After root ZTE chapel z831 only bootloop, no ftm mode, only recovery! i need test point to boot qualcomm 9008 mode
Old 03-01-2019, 21:31   #88 (permalink)
Member: 2770819
Thanks Meter: 3
help, I can not start ultimate frp or qcfire
https://ibb.co/fHJnMtb
https://ibb.co/7YGVsj9
Old 09-08-2020, 04:48   #89 (permalink)
Member: 1730398
i want this file----its urgent
VIVO Y91 EFS FIX Baseband
Old 03-30-2021, 18:00   #90 (permalink)
validity's Avatar
Member: 1708749
Thanks Meter: 14
can umt remove vivo y95 encrypted user data ... android version 8.0.1 .bcoz i need the data ..just want to reset ,remove pin password
Page generated in 0.17884 seconds with 9 queries
