Dear sir i have a big problem i have 3 pic of redmi 3s prime problem are same pattern lock after factory reset done pattern lock remove but ask for mi ac main problem is both 3 set not connect when i press vol-+vol+ at same time but in fast boot connected properly and work only vol-+vol+ method not work volume key working fine please help me hanks |
Great team great update , love you i need moto imei repair solution plz add ........... i am requested many times plz plz |
For further details, please use search. Br, Ultimate Multi Tool |
Umt can remove Lenovo k6 note frp ? |
If it is Qualcomm and can enter download mode, then yes. Br, Ultimate Multi Tool |
Please any solution for Xiomi mimax pro mi account activate after disable when connect to wifi ! |
Msm 8976pro and msm 8976 are same...? Because i want to repair imei of samsung c900f (c9 pro) Is that plssible to do that with selecting msm8976..? Pls reply umt team Pls.. |
If you can put Samsung in EDL, then yes, you may try. I really not found any samsung device entering EDL. About IMEI repair, Generic Qualcomm and samsung are really very different. Br, Ultimate Multi Tool |
OMG Non-Stop Update...UMT is on fire....great.. |
Sir is that possible to repair imei of samsung c900f with umt...? Can u add the feature of samsung qualcomm support? |
GSM Module some phone supported. Quote:
Other vendors use customize method, like Samsung Huawei etc who have added certificate or other layer of security. Br, Ultimate Multi Tool |
Operation : Read Firmware Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM58) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1600500 [8917] 00000000 Initializing Protocol... OK Preparing Firehose Loader... Done Sending Loader [8937_4..ufl]... Write Error! Please use correct loader and check USB port / cable. Module Ver. 0.9 |
with 8917 loader... Operation : Read Firmware Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM58) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1600500 [8917] 00000000 Initializing Protocol... OK Preparing Firehose Loader... Done Sending Loader [8917.ufl]... Write Error! Please use correct loader and check USB port / cable. Module Ver. 0.9 |
Ultimate Multi Tool Team Please Add Huawei FRP Reset Thank You... |
