06-17-2017, 22:31 | #77 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Quote:
Br, Ultimate Multi Tool | |
06-18-2017, 02:21 | #79 (permalink) |
No Life Poster Join Date: Dec 2013 Location: ecuador
Member: 2078045 Status: Offline Thanks Meter: 151 | Operation : Reset Mi Account Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port Driver Info : TCL, qcusbser.sys, 2.1.2.1 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1507000 [8916] 00000000 Initializing Protocol... OK Using Auto Selection Preparing Firehose Loader... Done Sending Loader [8916.ufl]... Done Executing Loader... OK Hardware : 8916, eMMC, 16 GB Warning! High Speed Driver not installed. Please install driver from QcFire\Drivers folder. Payload Info : In: 65536 [4096], Out: 16384, Sector Size: 512 Reading Partition Table... OK Reading Device Information... OK Device : Xiaomi wt88047 [msm8916] Software : LMY47V, V8.2.1.0.LHJMIDL [Wed Feb 15 09:59:02 CST 2017] Android Ver. : 5.1.1 Reading Data... Done Last edited by spd3; 06-18-2017 at 02:29. |
The Following User Says Thank You to spd3 For This Useful Post: |
06-18-2017, 02:29 | #80 (permalink) |
Member: 2078045 Status: Offline Thanks Meter: 151 | Operation : Read Firmware Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Android HS-USB QDLoader 9008 (COM33) Driver Info : TCL, qcusbser.sys, 2.1.2.1 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1507000 [8916] 00000000 Initializing Protocol... OK Using Auto Selection Preparing Firehose Loader... Done Sending Loader [8916.ufl]... Done Executing Loader... OK Hardware : 8916, eMMC, 16 GB Warning! High Speed Driver not installed. Please install driver from QcFire\Drivers folder. Payload Info : In: 65536 [4096], Out: 16384, Sector Size: 512 Reading Partition Table... OK Reading Device Information... OK Device : Xiaomi wt88047 [msm8916] Software : LMY47V, V8.2.1.0.LHJMIDL [Wed Feb 15 09:59:02 CST 2017] Android Ver. : 5.1.1 Reading [modem]... Done Reading [sbl1]... Done Reading [sbl1bak]... Done Reading [aboot]... Done Reading [abootbak]... Done Reading [rpm]... Done Reading [rpmbak]... Done Reading [tz]... Done Reading [tzbak]... Done Reading [hyp]... Done Reading [hypbak]... Done Reading [pad]... Done Reading [modemst1]... Done Reading [modemst2]... Done Reading [misc]... Done Reading [fsc]... Done Reading [ssd]... Done Reading [splash]... Done Reading [DDR]... Done Reading [fsg]... Done Reading [sec]... Done Reading [boot]... Done Reading [system]... Done Reading [cache]... Done Reading [persist]... Done Reading [recovery]... Done Reading [keystore]... Done Reading [config]... Done Reading [oem]... Done Reading [userdata]... Done Reading [PrimaryGPT]... Done Reading [BackupGPT]... Done Saved to : C:\UMTool\QcFire\Read\wt88047_LMY47V_5.1.1\ Operation Finished. Module Ver. 0.9 |
06-20-2017, 02:49 | #83 (permalink) |
Freak Poster Join Date: Feb 2016
Member: 2526783 Status: Offline Thanks Meter: 22 | Ellipsis 10 frp??? When i put the ellipsis 10 into download mode, the device manager says that there is a device labeled as "TD2". I can't seen to find the drivers for this device. I did find the qtair7 drivers. Has anyone been successful at reseting the frp on the ellipsis 10 device? vzw. |
06-20-2017, 09:15 | #84 (permalink) | |
Freak Poster Join Date: Mar 2012 Location: BARNALA
Member: 1734313 Status: Offline Sonork: 100.1620886 Thanks Meter: 70 | Quote:
If YES, is there any way to take it in EDl mode without opening and shorting test points ??? | |
06-20-2017, 11:01 | #85 (permalink) |
Crazy Poster Join Date: May 2013 Location: INDIAN
Member: 1943146 Status: Offline Thanks Meter: 11 | Operation : Disable Mi Account Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : RELINK HS-USB QDLoader 9008 (COM53) Driver Info : Woowellstrong Electronic co.,ltd, cmnxusbser.sys, 2.1.0.3 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1B09000 [8936] 00000000 Initializing Protocol... OK Using Auto Selection Preparing Firehose Loader... Done Sending Loader [8936.ufl]... Write Error! Please use correct loader and check USB port / cable. Operation Failed. |
06-20-2017, 12:04 | #86 (permalink) |
Member: 1943146 Status: Offline Thanks Meter: 11 | mi 4i error ..... Operation : Disable Mi Account Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : RELINK HS-USB QDLoader 9008 (COM53) Driver Info : Woowellstrong Electronic co.,ltd, cmnxusbser.sys, 2.1.0.3 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1B09000 [8936] 00000000 Initializing Protocol... OK Using Auto Selection Preparing Firehose Loader... Done Sending Loader [8936.ufl]... Write Error! Please use correct loader and check USB port / cable. Operation Failed. |
06-22-2017, 11:24 | #89 (permalink) |
No Life Poster Join Date: Dec 2009 Location: pAK+Africa
Member: 1190193 Status: Offline Sonork: 1619687 Thanks Meter: 406 | Port : ADB Interface / Recovery Baud Rate : Not Applicable Device : Android MTK Operation : IMEI Repair Searching for Device... Found Model : Samsung Galaxy J1(2016) Version : 4.2.2 Hardware : mt6582 Baseband : MOLY.WR8.W1315.MD.WG.MP.V23, 2016/09/16 15:45 SIM Card : READY CPU : armeabi-v7a Type : GSM IMEI(1) : 352112111215155 Type : GSM IMEI(2) : 351212125454542 Checking Root Access... OK Root : Rooted Reading Data from Phone... Done Backup : NVRAM_Samsung Galaxy J1(2016)_mt6582_4.2.2_352112111215155_170622_15172 9.Bak IMEI To Repair - IMEI[1] : 352121021212129 IMEI[2] : 352112145454549 Preparing Data[0]... . . . Done Updating IMEI Information... Done Rebooting Phone... Done Operation Finished. Elapsed Time: 00:19 [Module Ver. 3.9] Log Saved to Logs\170622_151744.log |
The Following User Says Thank You to akhtar.abbas For This Useful Post: |
06-24-2017, 20:34 | #90 (permalink) |
Freak Poster Join Date: Dec 2005 Age: 47
Member: 205157 Status: Offline Sonork: 100.1574537 Thanks Meter: 82 | MI 4X 2017 Factory Reset In SideloadMode Done Searching for phone in sideload mode... Found Device Id : santoni_global Version : V8.2.9.0.MAMMIEA Code Base : 6.0.1 Ext Info : GB, en, F Formatting Data... Done Rebooting device... Done Operation Finished. Module Ver. 0.9 |
