06-17-2019, 09:44 | #61 (permalink) | |
Junior Member Join Date: Feb 2008
Member: 702363 Status: Offline Thanks Meter: 2 | Quote:
This model wiseguy | |
06-17-2019, 09:45 | #62 (permalink) | |
No Life Poster Join Date: Oct 2006 Location: RAJASTHAN JAIPUR Age: 46
Member: 379001 Status: Offline Sonork: 100.1606686 Thanks Meter: 494 | Quote:
*note* what is use of this teb answer is if your phone not format fs and show error erased gpt. When you use this flasher select firmware folder xml file then format thanks | |
06-19-2019, 09:35 | #67 (permalink) |
Insane Poster Join Date: Jan 2016 Location: Derbent
Member: 2516133 Status: Offline Thanks Meter: 55 | Redmi Note 7 Device : Xiaomi Redmi Note 7 Operation : Read Information Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM10) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_022]...Done Executing Loader...OK Detecting Chip Type...Failed VIP Enabled / Auth Enabled Device! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 4.3 But after PC rebooting everything is OK Device : Xiaomi Redmi Note 7 Operation : Read Information Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM10) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_022]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 7 [lavender] Software : PKQ1.180904.001, V10.3.5.0.PFGMIXM [Wed Apr 24 13:00:55 WIB 2019] Android Ver. : 9 Patch Level : 2019-04-05 USERDATA : Encrypted You can use DISABLE LOCKS to Disable Pin/Pattern/Password WITHOUT Data Loss. Operation Finished. QcFire Ver. 4.3 I have noticed that sometimes QcFire can't identify authorized devices like Note 5 Pro, Note 6 Pro. But after PC rebooting there is no problem. And then again problem with detection and after rebooting it's OK. Can you explain me this. There is no problem with drivers or USB ports. Thanks. |
06-19-2019, 16:31 | #69 (permalink) |
No Life Poster Join Date: May 2006 Location: wordwide Age: 48
Member: 279394 Status: Offline Sonork: 1591760 Thanks Meter: 105 | please add XIOAMY POCOFHONE F1 Operation : Reset Mi Account Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM14) Driver Info : Network Connect, qcusbser.sys, 3.0.0.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1B00800 [SD845] 00007200 OPK_DATA : 99AF649E077EBCE3E9E187442ABDC70BD715756DE9ED192E9F 7883A10EBE09F4 Initializing Protocol...OK Using Auto Loader Selection [4] No compatible loader found. Device may not boot with this loader. Preparing Loader...Done Sending Loader [SD845]...Write Error! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 4.3 BR treo29 |
The Following User Says Thank You to treo29 For This Useful Post: |
06-20-2019, 12:22 | #72 (permalink) |
Freak Poster Join Date: Aug 2017 Location: IN THIS WORLD
Member: 2752048 Status: Offline Thanks Meter: 58 | Worl no1 team for realsed exclusive solutions. What a developing team. Like there work. Love umt team.love fastunlocking 😍 |
The Following User Says Thank You to nzsyl For This Useful Post: |
06-21-2019, 05:02 | #74 (permalink) |
Freak Poster Join Date: Oct 2016 Location: Surandai TN India Age: 38
Member: 2637068 Status: Offline Thanks Meter: 276 | I am ready to activate yearly but umt MTK Tool is not good NCK MTK Tool is Working Fine Same Update Give Umt MTK also Add umt MTK Tool Read Flash and auto mode And Also release SPD Tool |
