04-23-2021, 13:04 | #91 (permalink) |
No Life Poster Join Date: Aug 2005 Location: MY
Member: 172261 Status: Offline Thanks Meter: 364 | Operation : Read Pattern Lock Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM129) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...Failed Operation Finished. QcFire Ver. 6.7 |
04-23-2021, 13:07 | #92 (permalink) |
Member: 172261 Status: Offline Thanks Meter: 364 | Device : Oppo A37f Operation : Read Pattern Lock Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM129) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...Failed Operation Finished. QcFire Ver. 6.7 Device : Oppo A37f Operation : Format FS Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM129) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Opening Port...OK Init Handshake Sequence...Failed Operation Finished. QcFire Ver. 6.7 |
04-23-2021, 14:44 | #93 (permalink) |
Insane Poster Join Date: Jul 2014 Location: India
Member: 2227538 Status: Offline Thanks Meter: 30 | Operation : Reset Mi Account (New) Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM62) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8917]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8917, EMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi 4A [msm8937] [rolex] Brand : Xiaomi Prod.Name : rolex Software : MMB29M, V8.5.5.0.MCCMIED [Tue Aug 29 11:30:58 WIB 2017] Android Ver. : 6.0.1 Patch Level : 2017-07-01 Patching Mi Account...OK...Done Operation Finished. SHOWING DONE BUT,AFTER WIFI CONNECT IT IS RELOCKING... |
The Following User Says Thank You to raj_333 For This Useful Post: |
04-23-2021, 18:24 | #96 (permalink) | |
No Life Poster Join Date: Jan 2011 Location: Cuba
Member: 1484663 Status: Offline Thanks Meter: 344 | mi account remove for Mi9 SE?.... Quote:
04-24-2021, 16:27 | #99 (permalink) |
Insane Poster Join Date: Mar 2017 Location: bogota Age: 38
Member: 2690687 Status: Offline Thanks Meter: 42 | redmi note 7 reset mi account new no relock done Operation : Reset Mi Account (New) Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM31) Driver Info : Network Connect, qcusbser.sys, 3.0.0.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Preparing Loader...Done Sending Loader [RedmiNote7_64]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, EMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Software : QKQ1.190910.002 V12.0.1.0.QFGMIXM, V12.0.1.0.QFGMIXM [Fri Oct 23 20:42:11 WIB 2020] Android Ver. : 10 Patch Level : 2020-10-01 Patching Mi Account...OK...Done Operation Finished. QcFire Ver. 6.7 |
The Following User Says Thank You to moisesorozco30 For This Useful Post: |
04-26-2021, 21:15 | #104 (permalink) |
Freak Poster Join Date: Feb 2016 Location: san jose
Member: 2534813 Status: Offline Thanks Meter: 18 | auto loader no work!!! a115m Device : Samsung Galaxy A11 (SM-A115F) Operation : Format FS Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM100) Driver Info : Network Connect, qcusbser.sys, 3.0.0.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1A00900 [8953] 00002000 OPK_DATA : 58C5414A3A35B2E6DAA9C7A3B816E594DA247411000F7E9422 1BF5F13119812C Initializing Protocol...OK Using Auto Loader Selection [3] Device may possibly not boot with this loader. Preparing Loader...Done Sending Loader [8953_036]...Write Error! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 6.7 |
