04-27-2021, 07:24 | #106 (permalink) |
Junior Member Join Date: Mar 2016
Member: 2545914 Status: Offline Thanks Meter: 0 | |
04-29-2021, 14:48 | #108 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Quote:
If you want, please come on skype. Br, UMT | |
04-29-2021, 14:48 | #109 (permalink) | |
04-29-2021, 18:14 | #111 (permalink) |
Junior Member Join Date: Aug 2014
Member: 2244285 Status: Offline Thanks Meter: 5 | Error in xiaomi Redmi 4x Hello, tried with QCfire 6.7 format fs and than reset mi account, phone power on normally, but after set wifi, relock. So i try with old methoth with qcfire 6.5, make reset mi account and after "anti relock method" with ADB, that works, but phone freeze after try set wifi. how to solve it? |
05-01-2021, 06:39 | #112 (permalink) |
Junior Member Join Date: Jul 2017 Location: Zimbabwe,Masvingo
Member: 2739037 Status: Offline Sonork: NULL Thanks Meter: 1 | REDMI NOTE 9 PRO RESET MI ACCOUNT SERVER ALWAYS OFFLINE please UMT BR we need an offline loader for this phone SERVER ALWAYS OFF some find my phone ON & SERVER Will reject please UMT Qualcom Masters Patch this boot for us. |
05-02-2021, 06:49 | #114 (permalink) | ||
No Life Poster Join Date: Aug 2005 Location: MY
Member: 172261 Status: Offline Thanks Meter: 364 | what's wrong with this Quote:
05-02-2021, 08:33 | #115 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Try with other cable/port. Also check if some application like HiSuite, PC Companion etc is running, if yes close them first. Br, UMT |
05-04-2021, 10:16 | #118 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | So you think both are same? Did you noticed that you used Package Loader in 6.7 but NO package loader in 6.0? Better provide link for this firmware to see what exactly is the issue with firmware. UPDATE: Thanks for not providing further details or firmware, but we have figured out that Loader from Package was not loaded because it seems NON-Standard firmware and FIREHOSE is defined as FIREHORSE there. Br, UMT Last edited by U.M.T; 05-05-2021 at 21:20. |
The Following User Says Thank You to U.M.T For This Useful Post: |
05-05-2021, 16:02 | #119 (permalink) |
Freak Poster Join Date: Mar 2006 Location: I live in Ukraine, the city of Age: 44
Member: 245130 Status: Offline Thanks Meter: 6 | Error in xiaomi Redmi 4x but after set wifi, relock. Operation : Reset Mi Account (New) Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Huawei Incorporated, qu_usb_serial.sys, 2.1.1.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1B00600 [8937] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8937_003]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8937, EMMC, 16 GB LU Count : 1 [0x01D1F000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi 4X [msm8937] [santoni] Brand : Xiaomi Prod.Name : santoni Software : MMB29M, V8.2.10.0.MAMMIEA [Fri Jun 9 21:22:12 WIB 2017] Android Ver. : 6.0.1 Patch Level : 2017-05-01 Patching Mi Account...OK...Done Operation Finished. QcFire Ver. 6.7 |
05-06-2021, 15:32 | #120 (permalink) |
Freak Poster Join Date: Jul 2012 Location: brazil
Member: 1789551 Status: Offline Thanks Meter: 90 | MI MAX 3 (nitrogen) DebugData : BAAAABAAAAANAAAAAQAAAA== Operation : Flash Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM11) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Detecting Chip Type...OK DebugData : BAAAABAAAAANAAAAAQAAAA== Using Alternate Method... DebugData : BAAAABAAAAANAAAAAQAAAA== Error getting Payload Information! Error Log : BAAAABAAAAANAAAAAQAAAA== Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 6.7 |
