04-17-2021, 05:53 | #32 (permalink) |
Registered User Join Date: Aug 2016 Location: Multan Pakistan
Member: 2608490 Status: Offline Thanks Meter: 921 | Device : Vivo V11 Pro Operation : Vivo Format FS / FRP Reset Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM12) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1F00B00 [8937] 00000000 OPK_DATA : 30315EBED1DD09CEAAE927CAE0EE967076BC178CA33718DB4F FF8F02A0E7FAD2 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8937_029]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8937, EMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : vivo vivo 1906 [PD1930F_EX] Brand : vivo Prod.Name : PD1930F_EX Software : PKQ1.190616.001 release-keys, compiler08210558 [Fri Aug 21 05:57:23 CST 2020] Android Ver. : 9 Patch Level : 2020-08-01 Formatting userdata...Done Resetting FRP Lock...Done Wipe cache / userdata from Recovery and reboot. First startup may take 2-5 minutes. Operation Finished. QcFire Ver. 6.7 |
The Following User Says Thank You to GSM AR For This Useful Post: |
04-17-2021, 09:26 | #36 (permalink) |
Freak Poster Join Date: Feb 2012 Location: shakil mobile pakistan
Member: 1726210 Status: Offline Thanks Meter: 25 | Operation : Reset Mi Account (New) Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM19) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1A00B00 [8953] 00007200 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953_027]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Skipping Auth...Failed Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+PGRhdGE+PGxvZyB2YWx1ZT0iU2lnbmF0dXJlIFZlcmlmaWNh dGlvbiBGYWlsZWQiIC8+PC9kYXRhPjw/eG1sIHZlcnNpb249IjEuMCIgZW5jb2Rpbmc9IlVURi04IiA/PjxkYXRhPjxyZXNwb25zZSB2YWx1ZT0iTkFLIiAvPjwvZGF0YT 5= Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTQ2MzA0MjQxNDE0NDU5NTI1MzRBNzM2OTcwNz k3MjY5NjY1MjZFNTg3ODY2N0E1NjM2NDc1OTVGMzY3MTRDNjM2 Nz== Requesting UMT Server for Auth Data...SERVER_TEMPORARY_OFFLINE Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 6.7 |
04-17-2021, 09:27 | #37 (permalink) |
Member: 1726210 Status: Offline Thanks Meter: 25 | Operation : Reset Mi Account (New) Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM19) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1A00B00 [8953] 00007200 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953_027]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Skipping Auth...Failed Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+PGRhdGE+PGxvZyB2YWx1ZT0iU2lnbmF0dXJlIFZlcmlmaWNh dGlvbiBGYWlsZWQiIC8+PC9kYXRhPjw/eG1sIHZlcnNpb249IjEuMCIgZW5jb2Rpbmc9IlVURi04IiA/PjxkYXRhPjxyZXNwb25zZSB2YWx1ZT0iTkFLIiAvPjwvZGF0YT 5= Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTQ2MzA0MjQxNDE0NDU5NTI1MzRBNzM2OTcwNz k3MjY5NjY1MjZFNTg3ODY2N0E1NjM2NDc1OTVGMzY3MTRDNjM2 Nz== Requesting UMT Server for Auth Data...SERVER_TEMPORARY_OFFLINE |
04-17-2021, 10:21 | #38 (permalink) | |
Freak Poster Join Date: Mar 2017 Location: Tajikistan Age: 39
Member: 2695998 Status: Offline Thanks Meter: 68 | Forbidden Aplication (13) detected Quote:
hello UMT team i have problem with latest version of umt when i install 6.6 or 6.7 version show error Forbidden Aplication (13) detected when install 6.5 version work normal | |
04-17-2021, 20:11 | #45 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Quote:
Customer: Really? What is the use if I can not use it to open phone screws. Br, UMT | |
The Following 2 Users Say Thank You to U.M.T For This Useful Post: |
