09-10-2021, 03:57 | #91 (permalink) |
Registered User Join Date: Jan 2012 Location: Above the earth
Member: 1711578 Status: Offline Sonork: 100.1606127 Thanks Meter: 51 | Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM9 Port Name: MediaTek USB Port_V1633 (COM9) Path: \\?\usb#vid_0e8d&pid_0003#6&1319f84&0&9#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0766, [MT6765] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: False DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... Disable Auth Success Preloader saved as : preloader_k62v1_64_bsp_210909_110402.bin DA : MTK_AllInOne_DA.bin Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1633 (COM9) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Build Date : Tue Jul 27 22:28:59 CST 2021 Build Flavor : full_k62v1_64_bsp-user Build Desc. : full_k62v1_64_bsp-user 11 RP1A.200720.012 eng.compil.20210727.223248 release-keys Android Ver. : 11 Display ID : RP1A.200720.012 release-keys Patch Level : 2021-07-01 Platform : MT6765 Board : k62v1_64_bsp Platform : mt6765 Platform : MT6765 Board : k62v1_64_bsp Platform : mt6765 Userdata is NOT ENCRYPTED Formatting Userdata... - Failed! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.4] |
09-17-2021, 06:59 | #95 (permalink) |
No Life Poster Join Date: Aug 2005 Location: MY
Member: 172261 Status: Offline Thanks Meter: 364 | RMX2020 RESET Operation : Oppo/Realme Factory Reset (Meta) Checking for existing META ports... Found MediaTek PreLoader USB VCOM_V1633 (Android) (COM58) on COM58 Device Path : usb\vid_22d9&pid_0006&rev_???? Configuring Communication Channel... Reading phone information... CPU : MT6768 SW Ver. : MOLY.LR12A.R2.TC16.Q.G70.PR1.SP.V1.P55 HW Ver. : OPPO_RM_G70_Q0MP1_K69V1_64_BSP_H Brand: realme Model: RMX2020 Name: realme C3 Platform: MT6768 OEM Prod.: RMX2020 OEM Device: RMX2020 Build Date: Thu Jun 10 22:49:53 CST 2021 Display ID: RMX2020_11_A.63 OTA Version: RMX2020_11.A.63_0630_202106102145 Patch Level: 2021-06-05 Starting Safe Factory Reset... Reset Success Operation finished If META method does not work, try Format FS in BROM mode. [UltimateMTK Ver. 4.4] [UltimateMTK Ver. 4.4] |
The Following User Says Thank You to andre128 For This Useful Post: |
09-17-2021, 07:26 | #96 (permalink) | ||
Member: 172261 Status: Offline Thanks Meter: 364 | Neffos X1 Lite FRP not work Quote:
09-28-2021, 07:57 | #99 (permalink) |
No Life Poster Join Date: Nov 2020 Location: karachi Age: 29
Member: 2973928 Status: Offline Thanks Meter: 260 | Dear team plz Add all Model chip... Dimensity 700 (MT6833, MT6833V/NZA) Dimensity 720 (MT6853, MT6853V/ZA) Dimensity 800 (MT6873) Dimensity 800U (MT6853V/TNZA) Dimensity 1100 (MT6891Z/CZA) Dimensity 1100+ (MT6889Z/CZA) Dimensity 1200 (MT6893) Thnxx best of luck... |
10-06-2021, 13:29 | #100 (permalink) |
Freak Poster Join Date: Mar 2017 Location: south africa
Member: 2696842 Status: Offline Sonork: 100.1683002 Thanks Meter: 296 | Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM6 Port Name: USB Modem Driver (COM6) Path: \\?\usb#vid_0e8d&pid_0003#5&2f4c81a&0&3#{f9f3ff14-ae21-48a0-8a25-8011a7a931d9} Chipset: 0x0766, [MT6765] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: False DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... Disable Auth Success Preloader saved as : preloader_k65v1_64_bsp_titan_rat_211006_142510.bin DA : MTK_AllInOne_DA.bin Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : USB Modem Driver (COM6) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Build Date : Mon Jun 28 19:26:13 +07 2021 Build Flavor : a12nsxx-user Build Desc. : a12nsxx-user 11 RP1A.200720.012 A125FXXU1BUF9 release-keys Android Ver. : 11 Display ID : RP1A.200720.012.A125FXXU1BUF9 Patch Level : 2021-05-01 Userdata is ENCRYPTED Seeking FRP Data... Resetting FRP... - Success! - Resetting FRP[2]... - Success! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.4] |
The Following User Says Thank You to umerkhalid1992 For This Useful Post: |
10-09-2021, 09:52 | #101 (permalink) | |
Banned Join Date: May 2018 Location: 28.7041 , 77.1025
Member: 2835487 Status: Offline Thanks Meter: 194 | Realme 8 Unlock done Quote:
The Following User Says Thank You to samfrnds90 For This Useful Post: |
10-10-2021, 13:18 | #102 (permalink) | |
Member: 2835487 Status: Offline Thanks Meter: 194 | Realme C20 unlock done Quote:
10-17-2021, 06:06 | #104 (permalink) |
Member: 2835487 Status: Offline Thanks Meter: 194 | please fix an issue with oppo A15 (CPH2185) after reset lock device stuck on recovery booting with blank screen (freez) i face same problem in 3 handset, not able to alive auto booting in recovery beacuse mics/para partition wipe ,reboot,flash but same condition |
