Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 01-29-2022, 08:51   #31 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,218
please update FTM2EDL option for auth xiaomi model.
Old 01-30-2022, 15:33   #32 (permalink)
KYEJUSA's Avatar
Member: 394869
Sonork: TAKE NO CHANCES
Thanks Meter: 515
NOKIA 5.4 TILL THIS ERROR WITH LOADER:
Checking for existing devices...Not Found
Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable.
Some phones may need Special Boot Cable or TestPoint for EDL mode.
Found Port : HS-USB Diagnostics 9008 (COM25)
Driver Info : Mobile, qcusbser.sys, 2.1.2.2
Connecting to phone...OK
Waiting for response...OK
Init Handshake Sequence...OK
Hardware ID : E1D01400 [SDM662] 00000000
OPK_DATA : 33C81B0D9C95728D384C524C64A4E5996B51A9D888417B18AB 704ECD276936FF
Initializing Protocol...OK
Using Auto Loader Selection [4]
No compatible loader found. Device may not boot with this loader.
Preparing Loader...Done
Sending Loader [SDM662]...Write Error!
Please use correct loader and check USB port / cable.
Operation Finished.
Old 01-30-2022, 18:19   #33 (permalink)
U.M.T's Avatar
Member: 2465108
Sonork: No More Used
Thanks Meter: 13,921
Please extract this loader and select in loader and try.
Br,
UMT
Old 01-31-2022, 10:43   #34 (permalink)
KYEJUSA's Avatar
Member: 394869
Thanks Meter: 515
Br,
UMT
shows this error:
Operation : Format FS
Sending Loader [prog_firehose_nokia54]...Write Error!
Operation Finished.
QcFire Ver. 7.4
Old 01-31-2022, 17:58   #35 (permalink)
U.M.T's Avatar
Member: 2465108
Can you please give more details about your model like TA-XXXX etc.?
Better to open new thread with related information as this thread is dedicted to this update.
Br,
UMT
Old 01-31-2022, 17:58   #36 (permalink)
U.M.T's Avatar
Member: 2465108
Br,
UMT
The Following User Says Thank You to U.M.T For This Useful Post:
Old 02-01-2022, 13:27   #37 (permalink)
Member: 2835487
Thanks Meter: 194
Plz fix fastboot flashing on xiaomi
Operation : Fastboot Flash
Searching for Device in FastBoot Mode...OK
Reading Information...OK
FastBoot Ver. : 0.5
Product : secret
Warranty : No
Bootloader : Unlocked
Writing [preloader_k85v1_64.bin] to [preloader_a]...OK
Writing [preloader_k85v1_64.bin] to [preloader_b]...OK
Writing [vbmeta.img] to [vbmeta_a]...OK
Writing [vbmeta.img] to [vbmeta_b]...OK
Writing [vbmeta_system.img] to [vbmeta_system_a]...OK
Writing [vbmeta_system.img] to [vbmeta_system_b]...OK
Writing [vbmeta_vendor.img] to [vbmeta_vendor_a]...OK
Writing [vbmeta_vendor.img] to [vbmeta_vendor_b]...OK
Writing [md1img.img] to [md1img_a]...OK
Writing [md1img.img] to [md1img_b]...OK
Writing [spmfw.img] to [spmfw_a]...OK
Writing [spmfw.img] to [spmfw_b]...OK
Writing [audio_dsp.img] to [audio_dsp_a]...OK
Writing [audio_dsp.img] to [audio_dsp_b]...OK
Writing [scp.img] to [scp_a]...OK
Writing [scp.img] to [scp_b]...OK
Writing [sspm.img] to [sspm_a]...OK
Writing [sspm.img] to [sspm_b]...OK
Writing [cam_vpu1.img] to [cam_vpu1_a]...OK
Writing [cam_vpu1.img] to [cam_vpu1_b]...OK
Writing [cam_vpu2.img] to [cam_vpu2_a]...OK
Writing [cam_vpu2.img] to [cam_vpu2_b]...OK
Writing [cam_vpu3.img] to [cam_vpu3_a]...OK
Writing [cam_vpu3.img] to [cam_vpu3_b]...OK
Writing [gz.img] to [gz_a]...OK
Writing [gz.img] to [gz_b]...OK
Writing [lk.img] to [lk_a]...OK
Writing [lk.img] to [lk_b]...OK
Writing [boot.img] to [boot_a]...OK
Writing [boot.img] to [boot_b]...OK
Writing [dtbo.img] to [dtbo_a]...OK
Writing [dtbo.img] to [dtbo_b]...OK
Writing [tee.img] to [tee_a]...OK
Writing [tee.img] to [tee_b]...OK
Writing [logo.bin] to [logo]...OK
Writing [rescue.img] to [rescue]...OK
Processing [super.img]...OK
Writing [super.img] to [super]...Communication Error!OK
Processing [cust.img]...OK
Writing [cust.img] to [cust]...Communication Error!OK
Processing [userdata.img]...OK
Writing [userdata.img] to [userdata]...Communication Error!OK
More than 1 slot found, activating slot [a]...Done
Operation Finished.
QcFire Ver. 7.5
Old 02-01-2022, 15:07   #38 (permalink)
U.M.T's Avatar
Member: 2465108
What was the result of flashing?
Br,
UMT
Old 02-09-2022, 06:29   #39 (permalink)
Member: 2835487
Thanks Meter: 194
xiaomi fastboot flashing error
Br,
UMT
same as screen short no flashing just skip ,i manually flashing those partitions
and also facing old redmi device mi account reset error show ( i Try on redmi note 4g)
old version working well on mi accounnt old methord
Operation : Reset Mi Account
Found Port : Qualcomm HS-USB QDLoader 9008 (COM19)
Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7
Hardware ID : E1507000 [8916] 00000000
OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A2 6AB1B4B3F1CF9E
Using Auto Loader Selection [1]
Sending Loader [8916_014]...Done
Executing Loader...OK
Detecting Chip Type...OK
Hardware : 8916, EMMC, 16 GB
LU Count : 1 [0x01D5A000]
WARNING! High Speed Driver is not installed.
Please install driver from QcFire\Drivers folder using Device Manager.
Payload Info : In: 65536 [4096], Out: 16384, Sector Size: 512
Reading Partition Table...OK
Reading Device Information...OK
Device : Xiaomi HM NOTE 1S [msm8916] [*****]
Brand : Xiaomi
Prod.Name : *****
Software : KTU84P, V9.2.3.0.KHKMIEK [Mon Jan 15 21:20:41 CST 2018]
Android Ver. : 4.4.4
Patch Level : 2016-10-01
Reading Data Backup...Done
Backup : persist_Xiaomi_HM NOTE 1S_KTU84P_2016-10-01_220207_190659.img
Resetting Mi Account Data...Done
Preparing Data...Done
Formatting Userdata...Done
When phone is completely ON, connect to Internet and add Mi Account.
Resetting FRP Lock......Done
-------------- INFORMATION --------------
New Firmware may cause hang on logo.
In such case, you need to flash phone to recover.
Or downgrade firmware and try Reset Mi Account again.
Operation Finished.
QcFire Ver. 7.2
Old 02-09-2022, 16:42   #40 (permalink)
U.M.T's Avatar
Member: 2465108
Old method has been fixed, if you want to test, please contact in private.
Br,
UMT
Old 02-10-2022, 15:12   #41 (permalink)
Member: 2201155
Thanks Meter: 37
a2 flash error
Operation : Flash
Checking for existing devices...Found
Port : Qualcomm HS-USB QDLoader 9008 (COM20)
Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.0.3
Opening Port...OK
Hardware ID : E1C00800 [8996] 00000000
OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1
Sending Loader [8996_022]...Done
Auth Enabled Device! You may need Mi Auth Account to service!
Skipping Auth...OK
Detecting Stroage Type...OK
Hardware : MSM8996, EMMC, 64 GB
LU Count : 4 [0x0747C000] [0x00002000] [0x00002000] [0x00002000]
Payload Info : In: 262144 [4096], Out: 131072, Sector Size: 512
Writing [persist.img] -> [persist] ...Done
Writing [persist.img] -> [persistbak] ...Done
Writing [boot.img] -> [boot_a] ...Done
Writing [boot.img] -> [boot_b] ...Done
Writing [system.img ] -> [system_a]...FailedFailed
Operation Finished.
QcFire Ver. 7.5
Old 02-10-2022, 17:52   #42 (permalink)
U.M.T's Avatar
Member: 2465108
Originally Posted by g0dsend313 View Post
a2 flash error
Operation : Flash
Opening Port...OK
Skipping Auth...OK
Operation Finished.
QcFire Ver. 7.5
Phone condition? Why you are flashing phone?
Error on same partiton everytime?
Br,
UMT
Old 02-17-2022, 16:52   #43 (permalink)
Member: 2227538
Thanks Meter: 30
vivo pd2060f efs restore failed
Originally Posted by Fast Unlocking View Post
We are pleased to announce
UMTv2 / UMT Pro
Innovative and Intelligent
QcFire v7.5
The Ultimate Qualcomm Tool
Supported Functions
- Read / Write Firmware
- Backup / Restore QCN
- IMEI Repair in FTM/Diag + Flash Mode
- Backup / Reset / Restore Security (EFS)
- Reset FRP (Google Factory Reset Protection)
- Format UserData
- Read Pattern Lock (Android < 6.0, Un-Encrypted Devices Only)
- Reset Locks (PIN, Password, Pattern w/o Data Loss, Un-Encrypted Devices Only)
- Enable Diag (Need OEM Unlock, May not work on BL Locked Devices)
- Reboot to EDL from Fastboot
- Reset Mi Account for Xiaomi Devices
- Disable Mi Account for Xiaomi Devices
- Factory Reset (sideload Mode) for Xiaomi Devices
- Disable / Restore Locks for Encrypted Userdata
- Motorola Boot Repair
- Xiaomi EDL Locked Device Service
- Bootloader Unlock in EDL Mode for some Xiaomi Devices
- One Click Root in EDL Mode for Generic Qualcomm Devices
- Forensic Functions (Read Contacts / Messages in EDL Mode)
- One Click Lock Reset for Vivo Phones (Encrypted Userdata)
- Factory Method for Format FS
- EDL Authentication using Xiaomi Auth App (Service Account Required)
- Xiaomi Wipe EFS in Sideload Mode
- Xiaomi IMEI Repair for RSA Protected Phones
- Xiaomi Boot Loader Unlock
- Unique Method for Vivo Reset Locks for Protected Devices
- Xiaomi EDL Auth Using UMT Server
- Xiaomi Flashing in Fastboot Mode
- Nokia Factory Firmware (nb0) Direct Flashing in EDL mode
- Oppo OFP Firmware Exctration Added
- Xiaomi Free Auth Service (bypass).
- Mi Account Reset without Relock
- Mi Account Patch on Flashing (EDL/Fastboot)
- Samsung MDM Unlock in EDL Mode
Note : Some features are device/brand specific, may not work on all devices.
Added:
OnePlus
- OnePlus Nord N10 5G
Xiaomi
- Mi 8SE (Test Loader, may need auth)
- Mi 10T / 10T Pro (Needs Auth)
Added Bl Unlock Patch for Redmi Note8
Updated Bl Unlock in Fastboot
- Software will auto try Flashing Unlock method if Oem Unlock fails
Restored Fix 9008 Port on user requests
- Use this option only if you know what you are doing
- Mostly it is used after changing eMMC etc.
Added Read Info on Flash
- It is to keep note of firmware on device before you flashed
Fixed "not a valid integer value" Error
Improved Booting Function
Special thanks to:
- ask4moon
- bk.gsm
Please use UMT Card Manager to Update Card Counter / Firmware / Activate Add-on, available via Support Access.
It Has Begun...
Keep Following Us...
Some Nice Updates Are On The Way...
SPECIAL THANKS TO OUR VALUABLE USERS FOR THEIR LOVE AND SUPPORT FOR MORE THAN 5 YEARS
WARNING :
ESN / MEID / IMEI REPAIR IS INTENDED TO REPAIR ESN / MEID / IMEI TO ORIGINAL ONE WRITTEN ON PHONE BACK LABEL / BOX. WE DO NOT ENDORSE OR ENCOURAGE ESN / MEID / IMEI CHANGING. ITS ILLEGAL. USER IS SOLE RESPONSIBLE FOR ANY ILLEGAL ACTIVITY DONE WITH USE OF FEATURES PROVIDED IN OUR SOFTWARE, NOT LIMITED TO ESN / MEID / IMEI.
ANY USER USING OUR SOFTWARE FOR ILLEGAL PURPOSE WILL BE SOLE RESPONSIBLE FOR HIS ACTS.
WE CONDEMN USE OF OUR SOFTWARE FOR ANY ILLEGAL PURPOSE.
STATUTORY WARNING - READ CAREFULLY
Using International Edition of our software is prohibited by Indian Law.
We strictly advice you to use Indian Edition if you are in India.
If you use International Edition in India, it may cause legal action against you by local law enforcement agencies.
We will not be liable for any loss or damaged caused.
:: NO FAKE ADVERTISEMENT ::
:: NO FAKE UPDATES ::
:: NO FAKE WORLD'S FIRST ::
:: NO FAKE BLA BLA BLA ::
How to Download:
- Download UMT Support Access.
- Connect UMT Box/Dongle to PC and Run UMT Support Access.
- Download required Executable from Installer folder.
- Enjoy!
- Download Mirrors
PLEASE DO NOT POST OFF TOPIC HERE. ONLY POST REGARDING THIS UPDATE AND SUPPORTED MODELS. ANY OFF TOPIC POST WILL BE DELETED
Device : Vivo Y12s (PD2060F)
Operation : Restore EFS
Found Port : Qualcomm HS-USB QDLoader 9008 (COM9)
Waiting for response...Ignored
Hardware ID : E1F00B00 [8937] 00000000
OPK_DATA : 30315EBED1DD09CEAAE927CAE0EE967076BC178CA33718DB4F FF8F02A0E7FAD2
Sending Loader [8937_029]...Done
Hardware : 8937, EMMC, 32 GB
LU Count : 3 [0x03A3E000] [0x00002000] [0x00002000]
Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512
Software : , eng.compil.20211206.163736 [Mon Dec 6 16:31:00 CST 2021]
Android Ver. : 11
Patch Level : 2021-12-01
Backup File : EFS_2021-12-01_220217_161416.ueb
Restoring EFS...Failed
Operation Failed.
Page generated in 0.25376 seconds with 9 queries
