10-11-2021, 08:56 | #91 (permalink) |
Junior Member Join Date: Apr 2018
Member: 2832748 Status: Offline Thanks Meter: 6 | I got auth problem too. I tried to flash 3 times Xiaomi MI 10 5G: Operation : Multi Flash Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM35) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1300C00 [SD8250] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7 Initializing Protocol...OK Sending Loader [prog_firehose_lite.elf]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Skipping Auth...Failed Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJFUlJPUjogU2lnbmF0dXJl IFZlcmlmaWNhdGlvbiBGYWlsZWQuIiAvPjwvZGF0YT48P3htbC B2ZXJzaW9uPSIxLjAiIGVuY29kaW5nPSJVVEYtOCIgPz4KPGRh dGE+CjxyZXNwb25zZSB2YWx1ZT0iTkFLIiByYXdtb2RlPSJmYW xzZSIgLz48L2RhdGE+ Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTQ3NTE0MjQxNDE0NDQ0NTI3NTUyNzU3MDZCNT UzNzRBNjY0OTc3NjM0OTZBNUYyRDY2MzQzNTdBNkQ2OTc2NzI1 MT== Requesting UMT Server for Auth Data...OK Credits Left: 15 Authenticating...OK Detecting Chip Type...OK Hardware : SD8250, UFS, 128 GB LU Count : 6 [0x01D83000] [0x00001000] [0x00001000] [0x00002000] [0x00040000] [0x00004000] Payload Info : In: 262144 [65536], Out: 16384, Sector Size: 4096 Processing [rawprogram0.xml] Writing [dummy.img] -> [switch] ...Done Writing [misc.img] -> [misc] ...Done Writing [logfs_ufs_8mb.bin] -> [logfs] ...Done Writing [metadata.img ] -> [metadata]...Done Writing [recovery.img] -> [recovery] ...Failed Operation Failed. QcFire Ver. 7.3 Every flashing job stopped after metadata flashing also flashing consumed 3x 10 credits UMT team, please help and advice me. thank you very much for your great work and supporting |
10-12-2021, 16:03 | #92 (permalink) | |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,207 | Quote:
1 what was status of phone in first place 2 Credits Left: 15 so it used 15 not 3 x 10 | |
10-13-2021, 11:04 | #93 (permalink) | |
Member: 2832748 Status: Offline Thanks Meter: 6 | Quote:
Credits are not so important for me. It's possible that I made more operations and credits lost. I'm telling only like a feedback. I'm really appericiating your tool and supporting. =) At first state I get the phone from customer with unlocked bootloader. I flashed firmware by fastboot. Flashing was ok but after bootloader lock it writes System has been destroyed. NOw i Need to unlock BL or flash ENG firmware. I think That there was IMEI repair and NV ram is damaged. The phone has been working perfect before BL lock but I didn't compare the IMEIs. I do not have any problems with flashing other xiaomis and Qualcomms on my computer. I think that MI 10 has some security improvements that causing this problems. Thanks UMT team and all gsmhosting users for helping to solve my problem | |
10-13-2021, 15:26 | #94 (permalink) |
Freak Poster Join Date: Mar 2018
Member: 2823049 Status: Offline Thanks Meter: 14 | when i try to unlock with redmi s2 always show this error Operation : Reset Mi Account (New) Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM14) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.0.3 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Done Executing Loader...OK Detecting Chip Type...OK DebugData : UXVhbGNvbW0gSFMtVVNCIFFETG9hZGVyIDkwMDggKENPTTE0KT == Using Alternate Method... DebugData : UXVhbGNvbW0gSFMtVVNCIFFETG9hZGVyIDkwMDggKENPTTE0KT == Error getting Payload Information! Error Log : UXVhbGNvbW0gSFMtVVNCIFFETG9hZGVyIDkwMDggKENPTTE0KT == Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 7.3 |
10-28-2021, 14:59 | #101 (permalink) |
Freak Poster Join Date: Jul 2006 Location: W-no
Member: 310418 Status: Offline Thanks Meter: 13 | not working for me... Operation : Flash Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1500A00 [SD855] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7 Initializing Protocol...OK Sending Loader [prog_ufs_firehose_sdm855_ddr.elf]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Skipping Auth...Failed Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJFUlJPUjogQmxvYiBzaG91 bGQgaW5pdCBmaXJzdC4iIC8+PC9kYXRhPjw/eG1sIHZlcnNpb249IjEuMCIgZW5jb2Rpbmc9IlVURi04IiA/Pgo8ZGF0YT4KPHJlc3BvbnNlIHZhbHVlPSJOQUsiIHJhd21vZG U9ImZhbHNlIiAvPjwvZGF0YT5= Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTQ2NEQ0MjQxNDE0NDY3NzA1MDRBNjI1NzM2Mz Y2NjcyNjY0MTc1MzY3MTUxNDY2OTY4NEU0NzY5NzYzODU0NDM3 Nz== Requesting UMT Server for Auth Data...Find Device is ON! Please make sure Find Device is OFF then try again. Detecting Chip Type...Failed Auth Enabled Device! You need Mi Auth Account to service! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 7.3 Checking for Available Credits....OK Available Credits : 10 |
10-28-2021, 15:10 | #102 (permalink) | |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,704 | Quote:
and it will never works for u cuz you didn't waste alittle time to search and the answer for your problem in front of you: Code: Requesting UMT Server for Auth Data...Find Device is ON! Please make sure Find Device is OFF then try again. and check here too: https://forum.gsmhosting.com/vbb/f97...aning-2904018/ b.r. | |
10-28-2021, 15:48 | #103 (permalink) | |
Member: 310418 Status: Offline Thanks Meter: 13 | reply Quote:
bro there is no mi account boud to the phone! (there was phone connected to the account but phone has been removed! and now phone is dead.) NFI why this program says it is?!?! | |
10-28-2021, 16:14 | #104 (permalink) | |
b.r. | |
10-28-2021, 16:38 | #105 (permalink) | |
Member: 310418 Status: Offline Thanks Meter: 13 | Quote:
jezus i said find device is OFF!!!! off im sure on server on mi account, no idea what is on the phone i relay on that what i done on mi account. | |
