07-23-2021, 02:31 | #36 (permalink) |
Junior Member Join Date: Dec 2006
Member: 403806 Status: Offline Thanks Meter: 5 | Operation : MDM Unlock Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM26) Driver Info : Network Connect, qcusbser.sys, 3.0.0.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1508000 [8x26] 00000000 OPK_DATA : EED101E1789B6DC193C77E74066137A4AF5694B574BC147987 1ACA0EF4748F63 Initializing Protocol...OK Using Auto Loader Selection [3] Device may possibly not boot with this loader. Preparing Loader...Done Sending Loader [8x26_012]...Done Executing Loader...OK Detecting Chip Type...OK DebugData : UXVhbGNvbW0gSFMtVVNCIFFETG9hZGVyIDkwMDggKENPTTI2KT == Using Alternate Method... DebugData : UXVhbGNvbW0gSFMtVVNCIFFETG9hZGVyIDkwMDggKENPTTI2KT == Error getting Payload Information! Error Log : UXVhbGNvbW0gSFMtVVNCIFFETG9hZGVyIDkwMDggKENPTTI2KT == Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 7.1.0 |
07-23-2021, 06:28 | #38 (permalink) | |
Freak Poster Join Date: Oct 2018 Location: india,gujarat
Member: 2874024 Status: Offline Thanks Meter: 488 | Quote:
07-23-2021, 10:52 | #39 (permalink) | ||
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Explain how you re xxxxxx Quote:
07-23-2021, 14:36 | #43 (permalink) |
Freak Poster Join Date: May 2010 Location: Heart.
Member: 1294579 Status: Offline Thanks Meter: 178 | Nokia 2.3 Ta-1206 NV problam..... Brand : Nokia Model : 2.3 Operation : Backup NVRAM Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM87 Port Name: MediaTek USB Port_V1632 (COM87) Path: \\?\usb#vid_0e8d&pid_0003#5&39132e10&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0717, [MT6761] Hardware Info: 0x8A00, 0xCA01, 0x200 SecureBoot: True SLA: True DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... Disable Auth Success Preloader saved as : preloader_t99621aa2_210723_183320.bin Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1632 (COM87) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Executing Flashing Task... Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Device : IRM_sprout Build Date : Fri Jan 15 19:59:07 CST 2021 Build Flavor : full_T99621AA2-user Build Desc. : full_T99621AA2-user 10 QP1A.190711.020 p1k61v164bspP66 release-keys Android Ver. : 10 Display ID : 00WW_2_340_SP02 Patch Level : 2021-01-05 Platform : MT6761 Board : MT6761 Platform : mt6761 Userdata is NOT ENCRYPTED Reading NV IMEI Data... Failed to Seek! NV IMEI1 : NV IMEI2 : Saved NVRAM as: NVRAM___mt6761___210723_183337.nvr Saved NVDATA as: NVDATA___mt6761___210723_183342.nvd Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.4] Failed to seek problam how to solve please???? |
07-23-2021, 15:38 | #44 (permalink) |
No Life Poster Join Date: Aug 2017 Location: India
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | I have used other tools but umt makes the work really easy, even the things that will be hard work on other tools becomes easy on umt tool, thanks umt team!!!!!! |
