A02s Reset frp android 11 error Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM47) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1A00900 [8953] 00002000 OPK_DATA : 98431A976541787E851B78549BBDA354E64C343814B5A8618B B79571EF8267A5 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953_051]...Write Error! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 7.1.0 |
But plz try to add Samsung test point Pic |
sir support m115m frp test point mode??? |
Poco x3 please team add Poco x3......thanks in advance |
Very well update But what about MTK chipset kg lock like M013f and others |
Please UMT TEAM help me. How to unlock bootloader mi 10 lite using UMT. |
vivov y20 done Model : Y20 (PD2034F) Operation : Erase Userdata Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM11) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1601300 [E1601300] 03007300 OPK_DATA : F754F13EE91BF54295CA1FBD64D182067440B35FC41B798A53 9670EA259771BA Initializing Protocol...OK Preparing Loader...Done Sending Loader [PD2034F]...Done Executing Loader...OK Initiazling Storage...OK Read : Protected Write : Protected Alt. Write : Blocked Erasing Userdata...Done Erasing FRP Data... ..Done Operation Finished. |
oppo a37f rest done Device : Oppo A37f Operation : Format FS Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM11) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1507000 [8916] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A2 6AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8916_014]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8916, EMMC, 16 GB LU Count : 1 [0x01D1F000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 16384, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : OPPO A37f [msm8916] Brand : OPPO Prod.Name : A37f Software : A37fEX_11_190711, 1480422943 [Thu Jul 11 03:29:34 CST 2019] Android Ver. : 5.1.1 Patch Level : 2018-03-01 Formatting userdata [SafeMode]...Done Resetting FRP Lock......Done Operation Finished. |
Hi UMT TEAM. I humble request to you please add this model mi 10 lite on next update. :):):) |
HI TEAM, Please add MOTO G9 PLAY. |
hello , Please add note 9 pro joyeuse , remove mi account or automatic unlock bootloader :D |
VIVO V17PRO IMEI REPAIR DONE AFTER EMARGENCY CALL AND IMEI 0000000000000 Operation : Repair IMEI Searching for Device in FTM Mode...Not Found Port : COM35 : Qualcomm HS-USB Diagnostics 9025 (COM35) Compile : Jul 13 2021 18:32:09 Release : Jun 08 2021 06:00:00 Hw. Ver. : sm6150.g Software : ---- IMEI : 869742049394296 / 869742049394288 Reading QCN Data...Done Saved As : C:\UMTool\QcFire\QCN_Backup\sm6150.g_----_869742049394296_210807_032404.qcn Switching to EDL Mode...Failed Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM20) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1500900 [SM6150] 03007300 OPK_DATA : F754F13EE91BF54295CA1FBD64D182067440B35FC41B798A53 9670EA259771BA Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [SM6150_001]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : SM6150, UFS, 128 GB LU Count : 6 [0x01D83800] [0x00000800] [0x00000800] [0x00002000] [0x00040000] [0x00004000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [65536], Out: 16384, Sector Size: 4096 Reading Partition Table...OK Reading Device Information...OK Software : , eng.compil.20210713.182706 [Tue Jul 13 18:27:06 CST 2021] Android Ver. : 11 Patch Level : 2021-07-01 Saving EFS Backup.......OK EFS Backup : EFS_2021-07-01_210807_032623.ueb Reset EFS (Full).......Done Port : COM35 : Qualcomm HS-USB Diagnostics 9025 (COM35) Processing background tasks...Done Restoring QCN Data...Done Finalizing process...Done Operation Finished. QcFire Ver. 7.1.0 |
VIVO 1906 Y11 Pin lock remove done with umt last version, but phone have still locked[emoji24] I was try 4/5 time but same[emoji848] Need to fix it[emoji57][emoji117]https://uploads.tapatalk-cdn.com/202...2cf9015b04.jpg Sent from my 5053K using Tapatalk |
Sent from my CPH1727 using Tapatalk |
Sa-M115f mdm lock After MDM unlock still same Logs: Quote:
