01-27-2021, 18:09 | #31 (permalink) |
Freak Poster Join Date: Dec 2009 Location: Assam
Member: 1189538 Status: Offline Thanks Meter: 22 | tried with may time changing cables also Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM12) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Skipping Auth...Failed Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJTaWduYXR1cmUgVmVyaWZp Y2F0aW9uIEZhaWxlZCIvPgo8L2RhdGE+PD94bWwgdmVyc2lvbj 0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID8+CjxkYXRhPgo8cmVz cG9uc2UgdmFsdWU9Ik5BSyIgLz4KPC9kYXRhPn== Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTQ2NkI0MjQxNDE0MjQxNEM2RjYyNzI2MzM2NU E0RjMwMzE2NzU5NjY1NzQ2NEYzMzQ5NTE1QTcyNUYzNjUzNzM1 MT== User declined using UMT Server. Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 6.5 |
01-27-2021, 18:29 | #33 (permalink) | |
Member: 1189538 Status: Offline Thanks Meter: 22 | same problem using without internet Quote: Br, | |
01-28-2021, 15:55 | #34 (permalink) |
No Life Poster Join Date: Nov 2006 Location: DEATH VALLEY
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks Meter: 500 | kindly support this cpu in next update,,its oppo cph 2095: Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : HS-USB Diagnostics 9008 (COM25) Driver Info : Mobile, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1D01400 [E1D01400] 00005100 OPK_DATA : 19CF99D55CA3B2E11EA19E52E3541DEDF01898FD9F8C40E625 48F1C7F60ABD47 Initializing Protocol...OK Using Auto Loader Selection [0] CPU not found in database. Operation Finished. QcFire Ver. 6.5 |
02-02-2021, 09:16 | #38 (permalink) |
Freak Poster Join Date: Sep 2014 Location: Feni
Member: 2266273 Status: Offline Sonork: Iqbal008 Thanks Meter: 16 | Samsung A015G/DS Frp Remove Fail Device : Samsung SM-M015G/DS Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM52) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1F00B00 [8937] 00002000 OPK_DATA : BA59757DCC8617C74C8212AD15AB758AA44C068D941EB87D3D DCC46C443FCFE3 Initializing Protocol...OK Using Auto Loader Selection [3] Device may possibly not boot with this loader. Preparing Loader...Done Sending Loader [8937_044]...Write Error! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 6.5 |
02-02-2021, 09:16 | #39 (permalink) |
Member: 2266273 Status: Offline Sonork: Iqbal008 Thanks Meter: 16 | Samsung A015G/DS Frp Remove Fail Samsung A015G/DS Frp Remove Fail Device : Samsung SM-M015G/DS Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM52) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1F00B00 [8937] 00002000 OPK_DATA : BA59757DCC8617C74C8212AD15AB758AA44C068D941EB87D3D DCC46C443FCFE3 Initializing Protocol...OK Using Auto Loader Selection [3] Device may possibly not boot with this loader. Preparing Loader...Done Sending Loader [8937_044]...Write Error! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 6.5 |
02-02-2021, 09:50 | #40 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Quote:
Br, UMT | |
02-02-2021, 09:50 | #41 (permalink) | |
Br, UMT | |
02-03-2021, 20:31 | #42 (permalink) |
Junior Member Join Date: May 2009
Member: 1032636 Status: Offline Thanks Meter: 0 | Device : Samsung SM-M015F/DS Operation : Reset FRP Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM9) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1F00B00 [8937] 00002000 OPK_DATA : B0F75607F03929422ADA159518DA3EC476DA7DE8F7953B6BA6 7BAF9610DF27F8 Initializing Protocol...OK Using Auto Loader Selection [3] Device may possibly not boot with this loader. Preparing Loader...Done Sending Loader [8937_044]...Write Error! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 6.5 Last edited by SergXP; 02-03-2021 at 20:36. |
02-06-2021, 08:30 | #45 (permalink) |
Freak Poster Join Date: Jan 2016 Location: faisalabad Age: 41
Member: 2518014 Status: Offline Thanks Meter: 43 | Vivo y51 pdf v2024 imei null plz help me umt team helo every one i have vivo y51 pdf v2024 imei null security damage plz help me [IMG]https://i.postimg.cc/NFRN7ytp/f2fb933e-8bbd-4594-b632- 858d6979f3f7.jpg[/IMG] https://i.postimg.cc/4dmqtNnS/2ff692...d53d90e24a.jpg https://i.postimg.cc/Ls00HKvB/3f3a13...28a7fbe166.jpg |
