05-11-2021, 11:32 | #76 (permalink) |
No Life Poster Join Date: Aug 2005 Location: MY
Member: 172261 Status: Offline Thanks Meter: 364 | Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM322 Port Name: MediaTek USB Port_V1633 (COM322) Path: \\?\usb#vid_0e8d&pid_0003#5&155d656&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0766, [MT6765] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: False DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... - Result: 0xA1A2A3A4 Disable Auth Success Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1633 (COM322) (..\..\flashtool\Utility\LogFilesClean.cpp (..\..\flashtool\Utility\LogFilesClean.cpp,38 (..\..\flashtool\Utility\LogFilesClean.cpp,38) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Brand : vivo Manufacturer : vivo Model : vivo 1808 Prod. Name : PD1732F_EX Device : PD1732F_EX Build Date : Sat Feb 27 20:52:58 CST 2021 Build Flavor : full_k62v1_64_bsp-user Build Desc. : full_k62v1_64_bsp-user 8.1.0 O11019 1614430384 release-keys Android Ver. : 8.1.0 Display ID : O11019 release-keys Patch Level : 2021-02-01 Board : k62v1_64_bsp Platform : mt6765 Board : k62v1_64_bsp Platform : mt6765 Userdata is ENCRYPTED Seeking Userdata... Formatting Userdata... - Success! Seeking FRP Data... Resetting FRP... - Success! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.2] |
The Following User Says Thank You to andre128 For This Useful Post: |
05-12-2021, 13:17 | #77 (permalink) |
No Life Poster Join Date: Apr 2006 Location: IN INDIA
Member: 263005 Status: Offline Thanks Meter: 147 | pc shutdown problem when i reseting mi mtk phones pc is studown like this error. tried to reinstall soft and driver but still same |
The Following User Says Thank You to alimuamin For This Useful Post: |
05-13-2021, 05:35 | #79 (permalink) |
Member: 172261 Status: Offline Thanks Meter: 364 | wiko view 4 lite failed Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM322 Port Name: MediaTek USB Port_V1633 (COM322) Path: \\?\usb#vid_0e8d&pid_0003#5&155d656&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0766, [MT6765] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: False DA Auth: False Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... - Result: 0xA1A2A3A4 Disable Auth Success Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1633 (COM322) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Userdata is ENCRYPTED Seeking Userdata... Formatting Userdata... - Failed! Erasing Userdata... - Failed! Seeking FRP Data... Resetting FRP... - Failed! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.2] |
05-13-2021, 10:29 | #82 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Quote:
Br, UMT | |
05-13-2021, 10:29 | #83 (permalink) | |
Br, UMT | |
05-13-2021, 14:32 | #84 (permalink) |
Freak Poster Join Date: Nov 2016 Location: India
Member: 2650288 Status: Offline Sonork: live:hackb151 Thanks Meter: 153 | vivo v11i done one clik Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM21 Port Name: MediaTek USB Port_V1632 (COM21) Path: \\?\usb#vid_0e8d&pid_0003#7&1d2facea&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0788, [MT6771] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: False DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... - Result: 0xA1A2A3A4 Disable Auth Success Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1632 (COM21) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Build Date : Thu Apr 15 12:29:55 CST 2021 Build Flavor : full_k71v1_64_bsp-user Build Desc. : full_k71v1_64_bsp-user 10 QP1A.190711.020 compiler04151201 release-keys Android Ver. : 10 Display ID : QP1A.190711.020 release-keys Patch Level : 2021-04-01 Platform : MT6771 Board : k71v1_64_bsp Platform : mt6771 Platform : MT6771 Board : k71v1_64_bsp Platform : mt6771 Userdata is ENCRYPTED Seeking Userdata... Formatting Userdata... - Success! Seeking FRP Data... Resetting FRP... - Success! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.2] |
The Following User Says Thank You to neyaz007 For This Useful Post: |
05-19-2021, 10:30 | #86 (permalink) | |
Member: 172261 Status: Offline Thanks Meter: 364 | Y85 one click done Code: Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM322 Port Name: MediaTek USB Port_V1633 (COM322) Path: \\?\usb#vid_0e8d&pid_0003#5&155d656&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0766, [MT6765] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: False DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... - Result: 0xA1A2A3A4 Disable Auth Success Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1633 (COM322) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Brand : vivo Manufacturer : vivo Model : vivo 1726 Prod. Name : PD1803F_EX Device : PD1803F_EX Build Date : Wed Apr 14 16:04:49 CST 2021 Build Flavor : full_k62v1_64_bsp-user Build Desc. : full_k62v1_64_bsp-user 8.1.0 O11019 1618387501 release-keys Android Ver. : 8.1.0 Display ID : O11019 release-keys Patch Level : 2021-03-01 Board : k62v1_64_bsp Platform : mt6765 Board : k62v1_64_bsp Platform : mt6765 Userdata is ENCRYPTED Seeking Userdata... Formatting Userdata... - Success! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.2] Quote:
05-20-2021, 12:38 | #88 (permalink) |
Junior Member Join Date: Oct 2018
Member: 2874244 Status: Offline Thanks Meter: 2 | I have a problem about xiaomi redmi 9 imei repair. I make format nvram, factory reset, xiaomi methot and meta(new), but not successful. UMT show successful, but phone imei not changed. Please help. |
