03-26-2023, 08:38 | #1 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,245 | [26-03-23] UMTv2/UMTPro UltimateMTK2 v0.4 - Xiaomi Patch Cert, Oppo DL Error Fix... UltimateMTK2 v0.4 The Ultimate MediaTek Tool What's New: Added Xiaomi Patch Cert Method 1 - Use this function if you face NV Data Corrupted Issue - Tested on: - Redmi 9 - Redmi 9 Prime - Poco M2 - In case of issue, make sure phone has MIUI v12.x Added Oppo DL Error Fix: - CPH1725 - CPH1859 - CPH1909 - CPH1911 - CPH1923 - CPH1989 - CPH2001 - CPH2015 - CPH2035 - CPH2083 - CPH2121 - CPH2185 - CPH2239 - CPH2269 - CPH2285 - RMX1821 - RMX1941 - RMX2040 - RMX2117 - RMX2189 - RMX3201 Added Internal Preloader for Listed Models - No need to use preloader if you select a model - Useful if preloader dump not work, for example if using TestPoint for BROM mode - Motorola G10 (TA-1346) - Motorola G20 (TA-1372) - Motorola G31 (XT2173-3) - Oppo A5s (CPH1909) - Oppo A83 (CPH1827) - Oppo A91 (CPH2021) - Oppo F11 Pro (CPH2209) - Oppo F17 Pro (CPH2119) - Oppo F7 (CPH1819) - Oppo F9 Pro (CPH1823) - Oppo Reno Z (CPH1979) - Realme 7 (RMX2151) - Realme C15 (RMX2180) - Realme Narzo 20 (RMX2193) - Vivo S1 (PD1913F) - Vivo Y11 (PD1930F) - Vivo Y12S (PD2036HF) - Vivo Y15 (PD1901FB) - Vivo Y17 (PD1901) - Vivo Y1s (PD2104) - Vivo Y30 (PD1987BF) - Vivo Y33S (PD2166) - Vivo Y55 5G (PD2166F) - Vivo Y81S (PD1732) - Vivo Y91c (PD1818HF) - Xiaomi Poco C3 - Xiaomi Poco M2 - Xiaomi Redmi 10A - Xiaomi Redmi 10X - Xiaomi Redmi 10X 4G - Xiaomi Redmi 10X Pro - Xiaomi Redmi 9C - Xiaomi Redmi Note 10 5G - More models will be added in next update Added Special Internal DA: - 6781 - 6785 - 6797 - 6833 - 6853 - 6873 - 6877 - 6885 - 6893 Added Patch DM-Verity - You can find it in Bootloader Unlock functions - Usefull if you flashed device and DM-Verity is again enforced Fixed RPMB Read/Write/Erase Function Improved Scatter Flashing Some cosmetic changes and improvements Important Notes: - You can flash device with both BROM and Preloader mode - If default DA does not work, use own DA in custom DA - Force BROM may not work on new security, use Test Point instead - When using Test Point, you must select Preloader in PL (not needed when flashing) - If you need to connect device in Preloader mode, you must select PRELOADER in connection settings, otherwise software will try to Crash Preloader (may not work on new security devices) Note : Some features are device/OS specific and may not work on all devices WARNING : ESN / MEID / IMEI REPAIR IS INTENDED TO REPAIR ESN / MEID / IMEI TO ORIGINAL ONE WRITTEN ON PHONE BACK LABEL / BOX. WE DO NOT ENDORSE OR ENCOURAGE ESN / MEID / IMEI CHANGING. ITS ILLEGAL. USER IS SOLE RESPONSIBLE FOR ANY ILLEGAL ACTIVITY DONE WITH USE OF FEATURES PROVIDED IN OUR SOFTWARE, NOT LIMITED TO ESN / MEID / IMEI. ANY USER USING OUR SOFTWARE FOR ILLEGAL PURPOSE WILL BE SOLE RESPONSIBLE FOR HIS ACTS. WE CONDEMN USE OF OUR SOFTWARE FOR ANY ILLEGAL PURPOSE. Download using Support Access or Mirrors Official Website |
The Following 42 Users Say Thank You to Fast Unlocking For This Useful Post: |
