05-02-2017, 10:53 | #47 (permalink) | |||
No Life Poster Join Date: Dec 2015 Location: hossting
Member: 2501288 Status: Offline Thanks Meter: 328 | Quote:
Operation : Disable Mi Account Checking for existing devices... Found Port : COM79 Opening Port... OK Init Handshake Sequence... OK Hardware ID : E1009B00 [8976] 00000000 Initializing Protocol... OK Preparing Firehose Loader... Done Sending Loader [8976.ufl]... Write Error! Please use correct loader and check USB port / cable. Operation Failed. i change laoder Quote:
The Following User Says Thank You to Steve-1 For This Useful Post: |
05-02-2017, 11:20 | #49 (permalink) | ||
05-02-2017, 15:28 | #50 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Use read Firmware - tick Plain - Unselect all partitions and select only persist and Read. After read and zip it and upload somewhere amd send link in PM. Br, Ultimate Multi Tool |
05-03-2017, 05:50 | #51 (permalink) |
Freak Poster Join Date: Dec 2007 Location: М.o.s.c.o.w.
Member: 649775 Status: Offline Thanks Meter: 242 | ===> Error reset frp zte axón mini 7 - QcFire v0.7 -<=== Error sending loader 8952_2.ufl ...write error Please use correct loader and check usb port / cable Operation failed |
05-03-2017, 12:06 | #54 (permalink) |
Member: 649775 Status: Offline Thanks Meter: 242 | Zte axon mini 7 B2017G Operation : Read Pattern Lock Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.0.1000.0 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1209700 [8952] 04000000 Initializing Protocol... OK Preparing Firehose Loader... Done Sending Loader [8952_2.ufl]... Write Error! Please use correct loader and check USB port / cable. Operation Failed.. Last edited by srockyou; 05-03-2017 at 12:14. |
