Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 09-13-2020, 18:57   #136 (permalink)
U.M.T's Avatar
Member: 2465108
Sonork: No More Used
Thanks Meter: 9,761
Originally Posted by Agapito86 View Post
i can't get NB0 FILE for this device, if anyone have this firmware help me pls!
Or an UMT TEAM do something about these new NEW SMART FEATURE PHONES devices
Operation : Format FS
Checking for existing devices...Not Found
Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable.
Some phones may need Special Boot Cable or TestPoint for EDL mode.
Found Port : Qualcomm HS-USB QDLoader 9008 (COM8)
Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7
Connecting to phone...OK
Waiting for response...OK
Init Handshake Sequence...OK
Hardware ID : E1400900 [8909] 50004200
OPK_DATA : 2F467D27EF09F251CBE50AE2E73C44F55360B6818775E73D40 F90D81778E04E2
Initializing Protocol...OK
Using Auto Loader Selection [4]
No compatible loader found. Device may not boot with this loader.
Preparing Loader...Done
Sending Loader [8909_037]...Write Error!
Please use correct loader and check USB port / cable.
Operation Finished.
QcFire Ver. 6.0
Sure, we will try to add support for these.
Br,
UMT
Old 09-14-2020, 23:51   #137 (permalink)
Member: 2601900
Thanks Meter: 472
Operation : Flash
Found Port : Qualcomm HS-USB QDLoader 9008 (COM32)
Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.1.0
Hardware ID : E1600E00 [E1600E00] 00007200
OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7
Sending Loader [prog_ufs_firehose_sdm855_ddr.elf]...Done
Executing Loader...OK
Auth Enabled Device! You need Mi Auth Account to service!
Requesting UMT Auth Service (FREE)...Failed
Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJFUlJPUjogQmxvYiBzaG91 bGQgaW5pdCBmaXJzdC4iIC8+PC9kYXRhPjw/eG1sIHZlcnNpb249IjEuMCIgZW5jb2Rpbmc9IlVURi04IiA/Pgo8ZGF0YT4KPHJlc3BvbnNlIHZhbHVlPSJOQUsiIHJhd21vZG U9ImZhbHNlIiAvPjwvZGF0YT5=
Reading Auth Blob...OK
Blob : NDE1MTQxNDE0MTQ3MzA0MjQxNDE0MjQzNDQzMTM0Nzg3NjU3NE I0QzRGNzQ1ODRBNDk1MTRDNDM2RTVBNTc1OTM1MzU1QTQ3NjY0 MT==
User declined using UMT Server.
Storage Initializaton Failed!
Operation Finished.
QcFire Ver. 6.0
Old 09-16-2020, 09:25   #138 (permalink)
Member: 372750
Thanks Meter: 42
Operation : Reset Mi Account
Checking for existing devices...Found
Port : Qualcomm HS-USB QDLoader 9008 (COM16)
Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0
Opening Port...OK
Hardware ID : E1B00800 [SDM845] 00007200
OPK_DATA : 99AF649E077EBCE3E9E187442ABDC70BD715756DE9ED192E9F 7883Axxxxxxxxxxxx
Using Auto Loader Selection [1]
Sending Loader [SDM845]...Done
Requesting UMT Auth Service (FREE)...OK
Detecting Chip Type...OK
Hardware : SDM845, UFS, 64 GB
LU Count : 6 [0x00DC0800] [0x00000800] [0x00000800] [0x00002000] [0x00120000] [0x00002000]
WARNING! High Speed Driver is not installed.
Please install driver from QcFire\Drivers folder using Device Manager.
Payload Info : In: 65536 [65536], Out: 262144, Sector Size: 4096
Reading Partition Table...OK
Reading Device Information...OK
Device : Xiaomi POCO F1 [beryllium]
Brand : Xiaomi
Prod.Name : beryllium
Software : OPM1.171019.011, V9.6.25.0.OEJMIFD [Mon Oct 8 14:45:10 WIB 2018]
Android Ver. : 8.1.0
Patch Level : 2018-09-01
Resetting Mi Account Data...Done
Preparing Data...Done
Formatting Userdata...Done
When phone is completely ON, connect to Internet and add Mi Account.
-------------- INFORMATION --------------
New Firmware may cause hang on logo.
In such case, you need to flash phone to recover.
Or downgrade firmware and try Reset Mi Account again.
Operation Finished.
QcFire Ver. 6.0.1
Last edited by TriddicK; 09-16-2020 at 09:28. Reason: Thank you UMT Team..You are the best!!!
The Following User Says Thank You to TriddicK For This Useful Post:
Old 09-16-2020, 13:28   #139 (permalink)
Member: 372750
Thanks Meter: 42
Operation : Reset FRP
Opening Port...OK
OPK_DATA : 99AF649E077EBCE3E9E187442ABDC70BD715756DE9ED192xxx xxxxxxxx
Device : Xiaomi
Software : , V11.0.9.0.QEJMIXM [Mon Jul 6 05:41:30 WIB 2020]
Android Ver. : 10
Patch Level : 2020-06-01
Resetting FRP Lock.......Done
Operation Finished.
QcFire Ver. 6.0.1
Old 09-16-2020, 13:30   #140 (permalink)
Member: 372750
Thanks Meter: 42
Operation : Flash
Opening Port...OK
OPK_DATA : 99AF649E077EBCE3E9E187442ABDC70BD715756DE9ED192E9F 7883xxxxxxxxxxx
Writing [imagefv.elf] -> [ImageFv] ...Done
Writing [gpt_main5.bin] -> [PrimaryGPT] ...Done
Writing [gpt_backup5.bin] -> [BackupGPT] ...Done
Applying Patches................Done
Resetting device...Done
Operation Finished.
QcFire Ver. 6.0.1
Old 09-16-2020, 18:46   #141 (permalink)
Member: 2312431
Thanks Meter: 13
Please add redmi note 8 gunko to flash withouth auth
Old 09-17-2020, 17:07   #142 (permalink)
Member: 326228
Thanks Meter: 31
please update
vivo u10
Old 09-17-2020, 21:02   #143 (permalink)
Member: 2870594
Sonork: yoandyveronika
Thanks Meter: 27
Please, when can the bootloaders of redmi 7 be unlocked since whenever I go to do the process the server is in maintenance or out of service I hope you can fix that
Old 09-19-2020, 04:14   #144 (permalink)
Member: 2494408
Thanks Meter: 83
very good for update
Sent from my iPhone using Tapatalk
Old 09-19-2020, 05:06   #145 (permalink)
Crazy Poster
Member: 2876711
Thanks Meter: 12
Originally Posted by naru3321 View Post
Vivo V15pro(6+128) safe format success but frp not cleared... I have tryed many more time in reset frp function but device stuck on JUS SEC... on statrtup setup...
when umt ask to safe format or not
select no
it will bootup properly
i tried it
Sent from my SM-A505F using Tapatalk
Old 09-19-2020, 05:08   #146 (permalink)
Crazy Poster
Member: 2876711
Thanks Meter: 12
please umt add support for redmi 6a (cactus) if possible
Old 09-21-2020, 20:08   #147 (permalink)
Member: 2650288
Sonork: 1681737
Thanks Meter: 69
vivo y91 1811 error
vivo 1811 format fs error log show 1807 but device is 1811 y91
Found Port : Qualcomm HS-USB QDLoader 9008 (COM13)
Waiting for response...Ignored
Hardware ID : E1F00B00 [8937] 00000000
OPK_DATA : 30315EBED1DD09CEAAE927CAE0EE967076BC178CA33718DB4F FF8F02A0E7FAD2
Sending Loader [8937_029]...Done
Hardware : 8937, eMMC, 32 GB
LU Count : 1 [0x03A3E000]
Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512
Device : vivo vivo 1807 [msm8937_64]
Brand : vivo
Prod.Name : msm8937_64
Software : OPM1.171019.026 release-keys, eng.compil.20200616.101753 [Tue Jun 16 10:17:53 CST 2020]
Formatting Userdata...Failed
Resetting FRP Lock...Failed
Operation Failed.
ErrorLog : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+PGRhdGE+PGxvZyB2YWx1ZT0iWE1MICgwIGJ5dGVzKSBub3Qg dmFsaWRhdGVkIiAvPjwvZGF0YT48P3htbCB2ZXJzaW9uPSIxLj AiIGVuY29kaW5nPSJVVEYtOCIgPz48ZGF0YT48cmVzcG9uc2Ug dmFsdWU9Ik5BSyIgLz48L2RhdGE+PD94bWwgdmVyc2lvbj0iMS 4wIiBlbmNvZGluZz0iVVRGLTgiID8+PGRhdGE+PGxvZyB2YWx1 ZT0iWE1MICgwIGJ5dGVzKSBub3QgdmFsaWRhdGVkIiAvPjwvZG F0YT48P3htbCB2ZXJzaW9uPSIxLjAiIGVuY29kaW5nPSJVVEYt OCIgPz48ZGF0YT48cmVzcG9uc2UgdmFsdWU9Ik5BSyIgLz48L2 RhdGE+PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRG LTgiID8+PGRhdGE+PGxvZyB2YWx1ZT0iWE1MICgwIGJ5dGVzKS Bub3QgdmFsaWRhdGVkIiAvPjwvZGF0YT48P3htbCB2ZXJzaW9u PSIxLjAiIGVuY29kaW5nPSJVVEYtOCIgPz48ZGF0YT48cmVzcG 9uc2UgdmFsdWU9Ik5BSyIgLz48L2RhdGE+PD94bWwgdmVyc2lv bj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID8+PGRhdGE+PGxvZy B2YWx1ZT0iWE1MICgwIGJ5dGVzKSBub3QgdmFsaWRhdGVkIiAv PjwvZGF0YT48P3htbCB2ZXJzaW9uPSIxLjAiIGVuY29kaW5nPS JVVEYtOCIgPz48ZGF0YT48cmVzcG9uc2UgdmFsdWU9Ik5BSyIg Lz48L2RhdGE+PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz 0iVVRGLTgiID8+PGRhdGE+PGxvZyB2YWx1ZT0iWE1MICgwIGJ5 dGVzKSBub3QgdmFsaWRhdGVkIiAvPjwvZGF0YT48P3htbCB2ZX JzaW9uPSIxLjAiIGVuY29kaW5nPSJVVEYtOCIgPz48ZGF0YT48 cmVzcG9uc2UgdmFsdWU9Ik5BSyIgLz48L2RhdGE+PD94bWwgdm Vyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID8+PGRhdGE+ PGxvZyB2YWx1ZT0iWE1MICgwIGJ5dGVzKSBub3QgdmFsaWRhdG VkIiAvPjwvZGF0YT48P3htbCB2ZXJzaW9uPSIxLjAiIGVuY29k aW5nPSJVVEYtOCIgPz48ZGF0YT48cmVzcG9uc2UgdmFsdWU9Ik 5BSyIgLz48L2RhdGE+PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNv ZGluZz0iVVRGLTgiID8+PGRhdGE+PGxvZyB2YWx1ZT0iWE1MIC gwIGJ5dGVzKSBub3QgdmFsaWRhdGVkIiAvPjwvZGF0YT48P3ht bCB2ZXJzaW9uPSIxLjAiIGVuY29kaW5nPSJVVEYtOCIgPz48ZG F0YT48cmVzcG9uc2UgdmFsdWU9Ik5BSyIgLz48L2RhdGE+
QcFire Ver. 6.0
finaly done vivo format/fs tab
Device : Vivo Y91
Operation : Vivo Format FS / FRP Reset
Brand : vivo
Formatting userdata...Done
Resetting FRP Lock...Done
Wipe cache / userdata from Recovery and reboot.
First startup may take 2-5 minutes.
Operation Finished.
QcFire Ver. 6.0
reset lock faield by vivo reset lock
Operation : Reset Locks (Vivo)
Brand : vivo
USERDATA : Encrypted
Reading Extended Information...OK
Model : vivo 1811
Product : PD1818BF_EX
Cust. Name : PD1818BF_EX_IN_NULL_NULL
Version : PD1818BF_EX_A_1.20.2
Resetting Locks (Vivo)...FailedFailed
Operation Failed.
QcFire Ver. 6.0
Old 09-21-2020, 23:18   #148 (permalink)
Member: 2024050
Requesting UMT Server for Auth Data...SERVER_UNDER_MAINTENANCE
iv been trying for 6 hours and the same result please please what time the server will be online
Old 09-22-2020, 07:51   #149 (permalink)
Member: 2225969
Sonork: 100.1611549
Thanks Meter: 75
please add bootloader unlock support for more xiaomi phones
Old 09-22-2020, 09:01   #150 (permalink)
Member: 1975260
Bootloader unlock files for xiaomi redmi 7 do not work, there is an authorization account error, I have specially bought credits and the problem persists. Please answer why this is happening.
Page generated in 0.15566 seconds with 7 queries
