Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 09-01-2020, 00:44   #31 (permalink)
Member: 500827
Thanks Meter: 2
Thanks a lot UMT team ,
UMT mean more than value for money,
But team what about Mi Note5 pro(whyred)
Old 09-01-2020, 02:52   #32 (permalink)
2111002640's Avatar
Member: 2487960
Thanks Meter: 208
waitting for support Xiaomi Mi 9 with FD On
Operation : Multi Flash
Checking for existing devices...Found
Port : Qualcomm HS-USB QDLoader 9008 (COM21)
Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7
Opening Port...OK
Init Handshake Sequence...OK
Hardware ID : E1500A00 [SD855] 00007200
OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7
Initializing Protocol...OK
Sending Loader [prog_ufs_firehose_sdm855_ddr.elf]...Done
Executing Loader...OK
Auth Enabled Device! You need Mi Auth Account to service!
Requesting UMT Auth Service (FREE)...Failed
Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJFUlJPUjogU2lnbmF0dXJl IFZlcmlmaWNhdGlvbiBGYWlsZWQuIiAvPjwvZGF0YT48P3htbC B2ZXJzaW9uPSIxLjAiIGVuY29kaW5nPSJVVEYtOCIgPz4KPGRh dGE+CjxyZXNwb25zZSB2YWx1ZT0iTkFLIiByYXdtb2RlPSJmYW xzZSIgLz48L2RhdGE+
Reading Auth Blob...OK
Blob : NDE1MTQxNDE0MTQ2NEQ0MjQxNDE0Mzc0NjYzNDZFNTAzMzY4N0 E2OTU1NEI3MDMyNDE3MjQyNzM2NDQ2MkQ0MTc1NzEzNDYxNTg1 MT==
Requesting UMT Server for Auth Data...Find Device is ON!
Please make sure Find Device is OFF then try again.
Detecting Chip Type...Failed
Please use correct loader and check USB port / cable.
Operation Failed.
QcFire Ver. 6.0
Opening Port...OK
Using Auto Loader Selection [4]
No compatible loader found. Device may not boot with this loader.
Preparing Loader...Done
Sending Loader [SD855]...Write Error!
Operation Failed.
QcFire Ver. 6.0
Old 09-01-2020, 04:23   #33 (permalink)
Member: 1288070
Sonork: 552832
Thanks Meter: 2
Please add Redmi 6 and 6a
Mi account reset
The Following User Says Thank You to cpsgopal For This Useful Post:
Old 09-01-2020, 04:30   #34 (permalink)
Unlockinfo's Avatar
Member: 1785930
Thanks Meter: 3,234
Mi account reset
We Will try to add it in future update.
BR,
Unlockinfo
The Following User Says Thank You to Unlockinfo For This Useful Post:
Old 09-01-2020, 05:12   #35 (permalink)
Yashbanswara's Avatar
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 601
My Dear UMT Product Manager & Supports
This UMTv2 / UMTPro - QcFire v6.0 Best Update
But My Personal AIM & Request To Both You In Next Update Must ADD Redmi 6 and 6a Mi Account Reset
Thanks & Regards By:All TECH 4 You
The Following User Says Thank You to Yashbanswara For This Useful Post:
Old 09-01-2020, 05:26   #36 (permalink)
Member: 1279781
Thanks Meter: 40
umt better than bla bla tool with bla bla loader
Old 09-01-2020, 05:37   #37 (permalink)
4star's Avatar
Member: 1596162
Sonork: 100.1616391
Thanks Meter: 122
Redmi note 7 pro unlock ,flash done by umt ver 6
Operation : Format FS
Port : Qualcomm HS-USB QDLoader 9008 (COM48)
Driver Info : Lenovo Inc., leusbser.sys, 2.0.9.6
Opening Port...OK
Hardware ID : E1500900 [SM6150] 00007200
Using Auto Loader Selection [1]
Sending Loader [SM6150]...Done
Requesting UMT Auth Service (FREE)...OK
Detecting Chip Type...OK
Hardware : SM6150, eMMC, 64 GB
LU Count : 1 [0x0747C000]
WARNING! High Speed Driver is not installed.
Please install driver from QcFire\Drivers folder using Device Manager.
Payload Info : In: 65536 [65536], Out: 262144, Sector Size: 512
Reading Partition Table...OK
Reading Device Information...OK
Device : Xiaomi Redmi Note 7 Pro [violet]
Brand : xiaomi
Prod.Name : violet
Software : PKQ1.181203.001, V11.0.10.0.PFHINXM [Fri Jul 17 22:08:35 CST 2020]
Android Ver. : 9
Patch Level : 2020-06-01
Formatting userdata [SafeMode]...Done
Resetting FRP Lock.......Done
Operation Finished.
QcFire Ver. 6.0
The Following 4 Users Say Thank You to 4star For This Useful Post:
Old 09-01-2020, 05:41   #38 (permalink)
Member: 2613282
Thanks Meter: 10
Very useful update....
Old 09-01-2020, 05:55   #39 (permalink)
khawajagsm's Avatar
Member: 639462
Thanks Meter: 381
great team great update
Old 09-01-2020, 05:55   #40 (permalink)
Member: 2622356
Thanks Meter: 2
I have a doubt that this version is beta, does it mean that later it can be paid?
Old 09-01-2020, 06:06   #41 (permalink)
shahzadthe1's Avatar
Member: 541117
Sonork: .::100.1586906::.
Thanks Meter: 140
expecting S1 pro from the best team
Old 09-01-2020, 06:42   #42 (permalink)
Member: 2136677
Thanks Meter: 6
Please add Redmi Note 8 (Ginko) patch unlock bootloader
Old 09-01-2020, 07:03   #43 (permalink)
behruz_abab's Avatar
Member: 2695998
Thanks Meter: 68
Originally Posted by U.M.T View Post
Can you read properly? If not, learn to read.
Show us where it is mentioned in update post?
Or you are just another spammer?
Operation : Flash
Port : Qualcomm HS-USB QDLoader 9008 (COM41)
Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0
Opening Port...OK
Hardware ID : E1F00B00 [8937] 00007200
OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B
Sending Loader [8937_035]...Done
Hardware : 8937, eMMC, 16 GB
LU Count : 1 [0x01D5A000]
Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512
Writing [sec.dat] -> [sec] ...Done
Writing [vbmeta.img] -> [vbmeta] ...Done
Writing [vbmeta.img] -> [vbmetabak] ...Done
Writing [devcfg.mbn] -> [devcfg] ...Done
Writing [devcfg.mbn] -> [devcfgbak] ...Done
Writing [dummy.img] -> [apdp] ...Done
Writing [dummy.img] -> [msadp] ...Done
Writing [sbl1.mbn] -> [sbl1] ...Done
Writing [sbl1.mbn] -> [sbl1bak] ...Done
Writing [rpm.mbn] -> [rpm] ...Done
Writing [rpm.mbn] -> [rpmbak] ...Done
Writing [cmnlib_30.mbn] -> [cmnlib] ...Done
Writing [cmnlib_30.mbn] -> [cmnlibbak] ...Done
Writing [cmnlib64_30.mbn] -> [cmnlib64] ...Done
Writing [cmnlib64_30.mbn] -> [cmnlib64bak] ...Done
Writing [km4.mbn] -> [keymaster] ...Done
Writing [km4.mbn] -> [keymasterbak] ...Done
Writing [misc.img] -> [misc] ...Done
Writing [emmc_appsboot.mbn] -> [aboot] ...Done
Writing [emmc_appsboot.mbn] -> [abootbak] ...Done
Writing [tz.mbn] -> [tz] ...Done
Writing [tz.mbn] -> [tzbak] ...Done
Writing [dtbo.img] -> [dtbo] ...Done
Writing [dtbo.img] -> [dtbobak] ...Done
Writing [splash.img] -> [splash] ...Done
Writing [adspso.bin] -> [dsp] ...Done
Writing [adspso.bin] -> [dspbak] ...Done
Writing [persist.img] -> [persist] ...Done
Writing [mdtp.img] -> [mdtp] ...Done
Writing [mdtp.img] -> [mdtpbak] ...Done
Writing [boot.img] -> [boot] ...Done
Writing [recovery.img] -> [recovery] ...Done
Writing [cache.img ] -> [cache]...Done
Writing [NON-HLOS.bin] -> [modem] ...Done
Writing [system.img ] -> [system]...Done
Writing [vendor.img ] -> [vendor]...Done
Writing [cust.img ] -> [cust]...Done
Writing [userdata.img ] -> [userdata]...Done
Writing [gpt_main0.bin] -> [PrimaryGPT] ...Done
Writing [gpt_backup0.bin] -> [BackupGPT] ...Done
Applying Patches................Done
Resetting device...Done
Operation Finished.
QcFire Ver. 6.0
REALLY WORK FOR REDMI 7A THANKS UMT TEAM )))))))))))))
The Following 5 Users Say Thank You to behruz_abab For This Useful Post:
Old 09-01-2020, 07:07   #44 (permalink)
Member: 2285339
good update
Old 09-01-2020, 07:27   #45 (permalink)
drbilal's Avatar
Member: 213808
Sonork: 100.1615441
Thanks Meter: 108
Good update team.
Page generated in 0.19653 seconds with 7 queries
