Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 09-01-2020, 16:47   #61 (permalink)
mhodkaif's Avatar
Member: 949310
Sonork: 1649436
Thanks Meter: 45
umt pro sab ka baap
AGAIN BAAP BAAP HI HOTA HAI
POCO F1 MI ACCOUNT DONE
Operation : Reset Mi Account
Checking for existing devices...Found
Port : Qualcomm HS-USB QDLoader 9008 (COM2)
Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7
Opening Port...OK
Init Handshake Sequence...OK
Hardware ID : E1B00800 [SDM845] 00007200
OPK_DATA : 99AF649E077EBCE3E9E187442ABDC70BD715756DE9ED192E9F 7883A10EBE09F4
Initializing Protocol...OK
Using Auto Loader Selection [1]
Preparing Loader...Done
Sending Loader [SDM845]...Done
Executing Loader...OK
Auth Enabled Device! You need Mi Auth Account to service!
Requesting UMT Auth Service (FREE)...OK
Detecting Chip Type...OK
Hardware : SDM845, UFS, 128 GB
LU Count : 6 [0x01CA5800] [0x00000800] [0x00000800] [0x00002000] [0x00120000] [0x00002000]
Payload Info : In: 262144 [65536], Out: 262144, Sector Size: 4096
Reading Partition Table...OK
Reading Device Information...OK
Device : Xiaomi POCO F1 [beryllium]
Brand : Xiaomi
Prod.Name : beryllium
Software : PKQ1.180729.001, V10.3.7.0.PEJMIXM [Fri Aug 9 19:16:04 WIB 2019]
Android Ver. : 9
Patch Level : 2019-07-01
Resetting Mi Account Data...Done
Preparing Data...Done
Formatting Userdata...Done
When phone is completely ON, connect to Internet and add Mi Account.
-------------- INFORMATION --------------
The Following 5 Users Say Thank You to mhodkaif For This Useful Post:
Old 09-01-2020, 16:50   #62 (permalink)
Member: 1517638
Sonork: 100.1620436
Thanks Meter: 31
Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable.
Some phones may need Special Boot Cable or TestPoint for EDL mode.
Found Port : Qualcomm HS-USB QDLoader 9008 (COM36)
Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2
Connecting to phone...OK
Waiting for response...OK
Hardware ID : E1C00800 [8996] 00000000
OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1
Sending Loader [8996_022]...Done
Requesting UMT Auth Service (FREE)...Failed
Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJTaWduYXR1cmUgVmVyaWZp Y2F0aW9uIEZhaWxlZCIvPgo8L2RhdGE+PD94bWwgdmVyc2lvbj 0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID8+CjxkYXRhPgo8cmVz cG9uc2UgdmFsdWU9Ik5BSyIgLz4KPC9kYXRhPn==
Reading Auth Blob...Not Found!
DebugData : BAAAABAAAAANAAAAAQAAAA==
Storage Initializaton Failed!
Please use correct loader and check USB port / cable.
Operation Finished.
QcFire Ver. 6.0
Old 09-01-2020, 19:16   #63 (permalink)
Member: 62545
Thanks Meter: 33
Device : Xiaomi BlackShark 1
Checking for existing devices...Not Found
Found Port : Qualcomm HS-USB QDLoader 9008 (COM169)
Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0
Hardware ID : E1600400 [8953] 00000000
OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B
Sending Loader [8953]...Done
Hardware : 8953, eMMC, 64 GB
LU Count : 1 [0x0747C000]
WARNING! High Speed Driver is not installed.
Please install driver from QcFire\Drivers folder using Device Manager.
Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512
Device : Xiaomi MI MAX 2 [msm8953] [oxygen]
Brand : Xiaomi
Prod.Name : oxygen
Software : NMF26F, V10.3.1.0.NDDMIXM [Thu Jun 13 20:59:18 CST 2019]
Android Ver. : 7.1.1
Patch Level : 2019-03-01
New Firmware may cause hang on logo.
In such case, you need to flash phone to recover.
Or downgrade firmware and try Reset Mi Account again.
Operation Finished.
THANKS UMT
The Following 4 Users Say Thank You to y_info2004 For This Useful Post:
Old 09-01-2020, 23:42   #64 (permalink)
Yusuf Lawal's Avatar
Member: 1677653
Thanks Meter: 2,345
Redmi 7 failed to patch
https://ibb.co/gFfX6yn
Operation : Xiaomi Boot Patch
Port : Qualcomm HS-USB QDLoader 9008 (COM21)
Opening Port...OK
Invalid response from device!
Found Port : Qualcomm HS-USB QDLoader 9008 (COM21)
Waiting for response...Ignored
Hardware ID : E1A00B00 [8953] 00007200
Sending Loader [8953_027]...Done
Using Alternate Method...
Error getting Payload Information!
Error Log : BAAAABAAAAANAAAAAQAAAA==
Operation Finished.
QcFire Ver. 6.0
The Following User Says Thank You to Yusuf Lawal For This Useful Post:
Old 09-02-2020, 05:54   #65 (permalink)
Member: 1905772
Please add in the next update redmi 6 redmi 6a in ultimate mtk module it would be a great update thanks team, keep going. The best UMT equipment.
Old 09-02-2020, 06:11   #66 (permalink)
Member: 652992
Sonork: 100.1651242
Thanks Meter: 28
team yesterday i unlocked 8a dual mi ac its getting relock again and again i used anti relock i used disable mi ac same it comes back on mi ac unlock help
Old 09-02-2020, 06:12   #67 (permalink)
muksforu's Avatar
Member: 50805
Thanks Meter: 79
hi good update
here is log of redmi note 7 pro MI account disable ok but wifi not working and when i format fs handset working ok but again mi activation lock i do
1-Reset Account (STUCK ON LOGO)
2-flash handset
3-reset account
4-format fs (handset switch on ok)
5-Anti Relock
after connecting internet same with sim again mi account comes
now accept wifi bt all woking ok how to solve wifi bt and relock issue ( if i format fs wifi bt woking ok but after connecting to wifi handet again lock to mi account)
any solution
thanks
Hardware ID	: E1500900 [SM6150] 00007200
OPK_DATA	: 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE1D25A7B0472DD7
Sending Loader [SM6150]...Done
Hardware	: SM6150, eMMC, 128 GB
LU Count	: 1 [0x0E8F6000]
Payload Info	: In: 65536 [65536], Out: 262144, Sector Size: 512
Device	: Xiaomi Redmi Note 7 Pro [violet]
Brand	: xiaomi
Prod.Name	: violet
Software	: PKQ1.181203.001, V11.0.6.0.PFHINXM [Thu Dec 19 23:58:09 CST 2019]
Android Ver.	: 9
Patch Level	: 2019-12-01
Operation Finished.
QcFire Ver. 6.0
Old 09-02-2020, 06:22   #68 (permalink)
globaltelecom's Avatar
Member: 358717
Sonork: 100.1648649
Thanks Meter: 41
one of the fineaset dongal i ever i seen great job sir
Old 09-02-2020, 06:23   #69 (permalink)
Member: 358717
Sonork: 100.1648649
Thanks Meter: 41
Old 09-02-2020, 06:44   #70 (permalink)
Member: 2711124
Thanks Meter: 42
umt Good Update from Big Team
Can you add more VIVO and OPPO and Huawei models
Old 09-02-2020, 07:03   #71 (permalink)
Member: 947347
Sonork: 100.108278
Thanks Meter: 19
nice update thanks big update boom boom
Old 09-02-2020, 07:32   #72 (permalink)
U.M.T's Avatar
Member: 2465108
Sonork: No More Used
Thanks Meter: 9,753
Opening Port...OK
Operation Finished.
QcFire Ver. 6.0
Communication issue.
Br,
UMT
The Following User Says Thank You to U.M.T For This Useful Post:
Old 09-02-2020, 07:33   #73 (permalink)
U.M.T's Avatar
Member: 2465108
Thanks Meter: 9,753
Originally Posted by muksforu View Post
hi good update
2-flash handset
3-reset account
5-Anti Relock
any solution
thanks
Brand	: xiaomi
Prod.Name	: violet
Android Ver.	: 9
Operation Finished.
QcFire Ver. 6.0
Possibly device in lost mode.
Need BL unlock amd write custom ROM.
Br,
UMT
The Following 2 Users Say Thank You to U.M.T For This Useful Post:
Old 09-02-2020, 07:40   #74 (permalink)
Member: 2227538
Thanks Meter: 27
Originally Posted by fast unlocking View Post
we are pleased to announce
umtv2 / umt pro
innovative and intelligent
qcfire v6.0
the ultimate qualcomm tool
supported functions
- read / write firmware
- backup / restore qcn
- imei repair in ftm/diag + flash mode
- backup / reset / restore security (efs)
- reset frp (google factory reset protection)
- format userdata
- read pattern lock (android < 6.0, un-encrypted devices only)
- reset locks (pin, password, pattern w/o data loss, un-encrypted devices only)
- enable diag (need oem unlock, may not work on bl locked devices)
- reboot to edl from fastboot
- reset mi account for xiaomi devices
- disable mi account for xiaomi devices
- factory reset (sideload mode) for xiaomi devices
- disable / restore locks for encrypted userdata
- motorola boot repair
- xiaomi edl locked device service
- bootloader unlock in edl mode for some xiaomi devices
- one click root in edl mode for generic qualcomm devices
- forensic functions (read contacts / messages in edl mode)
- one click lock reset for vivo phones (encrypted userdata)
- factory method for format fs
- edl authentication using xiaomi auth app (service account required)
- xiaomi wipe efs in sideload mode
- xiaomi imei repair for rsa protected phones
- xiaomi boot loader unlock
- unique method for vivo reset locks for protected devices
- xiaomi edl auth using umt server
- xiaomi flashing in fastboot mode
- nokia factory firmware (nb0) direct flashing in edl mode
- oppo ofp firmware exctration added
- xiaomi free auth service - new!!!
note : Some features are device/brand specific, may not work on all devices.
added
tecno
- a88
zte
- nubia red magic 5g
xiaomi no auth/free auth service added (beta)
- mi a3
- poco f1
- redmi 6 pro
- redmi 7a
- redmi 8
- redmi 8a
- redmi 8a dual
- redmi 8a pro
- redmi note 7 pro
added free auth service
- if phone ask for edl auth, software will first try with free service
- if free service does not work, it will ask for auth server as usual
xiaomi fb flasher
- disabled crclist flashing by default to avoid crc check error on some devices
- you can tick mark crclist and sparsecrclist if you want to flash
- added select all and unselect all button
special thanks to:
- amjadnona
- technomak
it has begun...
keep following us...
some nice updates are on the way...
special thanks to our valuable users for their love and support for more than 4 years
warning :
esn / meid / imei repair is intended to repair esn / meid / imei to original one written on phone back label / box. We do not endorse or encourage esn / meid / imei changing. Its illegal. User is sole responsible for any illegal activity done with use of features provided in our software, not limited to esn / meid / imei.
any user using our software for illegal purpose will be sole responsible for his acts.
we condemn use of our software for any illegal purpose.
statutory warning - read carefully
using international edition of our software is prohibited by indian law.
We strictly advice you to use indian edition if you are in india.
If you use international edition in india, it may cause legal action against you by local law enforcement agencies.
We will not be liable for any loss or damaged caused.
:: No fake advertisement ::
:: No fake updates ::
:: No fake world's first ::
:: No fake bla bla bla ::
how to download:
- download umt support access.
- connect umt box/dongle to pc and run umt support access.
- download required executable from installer folder.
- enjoy!
- download mirrors
please do not post off topic here. Only post regarding this update and supported models. Any off topic post will be deleted
thank u for this update, plz add redmi note 8 bootloader unlock
Old 09-02-2020, 09:34   #75 (permalink)
muksforu's Avatar
Member: 50805
Thanks Meter: 79
Br,
UMT
ok thanks will try and post result
Page generated in 0.21308 seconds with 7 queries
