09-10-2020, 10:01 | #121 (permalink) | |
Insane Poster Join Date: Sep 2007 Location: PL
Member: 582064 Status: Offline Thanks Meter: 14 | (tested few pieces) Quote:
09-10-2020, 15:20 | #122 (permalink) | |
Freak Poster Join Date: Oct 2006 Location: Russia Age: 48
Member: 372750 Status: Offline Thanks Meter: 77 | Quote:
Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM39) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1F00B00 [8937] 00007200 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8937_035]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Requesting UMT Auth Service (FREE)...OK Detecting Chip Type...OK Hardware : 8937, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi 8 [olive] Brand : Xiaomi Prod.Name : olive_ru Software : ZQL2115-olive-build-20191025191631, V10.3.3.0.PCNRUXM [Fri Oct 25 19:18:53 CST 2019] Android Ver. : 9 Patch Level : 2019-10-01 Resetting Mi Account Data...Done Preparing Data...Done Formatting Userdata...Done When phone is completely ON, connect to Internet and add Mi Account. -------------- INFORMATION -------------- New Firmware may cause hang on logo. In such case, you need to flash phone to recover. Or downgrade firmware and try Reset Mi Account again. Operation Finished. QcFire Ver. 6.0 Redmi 8(Olive) ALL WORKING FINE.. | |
The Following User Says Thank You to TriddicK For This Useful Post: |
09-11-2020, 07:51 | #126 (permalink) |
Insane Poster Join Date: Jan 2018 Location: Dar es salaam, Tanzania
Member: 2804958 Status: Offline Thanks Meter: 79 | Add new nokia features phone Add new Nokia feature phones, i.e NOKIA 800 TOUGH (TA-1189, TA-1186, TA-1180, TA-1176), NOKIA 220 (TA-1155, TA-1171, TA- 1148) and others feature phone with Qualicomm bellow is log for NOKIA 800 TOUGH Operation : Read Information Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM8) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1400900 [8909] 50004200 OPK_DATA : 2F467D27EF09F251CBE50AE2E73C44F55360B6818775E73D40 F90D81778E04E2 Initializing Protocol...OK Using Auto Loader Selection [4] No compatible loader found. Device may not boot with this loader. Preparing Loader...Done Sending Loader [8909_037]...Write Error! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 6.0 Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM8) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1400900 [8909] 50004200 OPK_DATA : 2F467D27EF09F251CBE50AE2E73C44F55360B6818775E73D40 F90D81778E04E2 Initializing Protocol...OK Using Auto Loader Selection [4] No compatible loader found. Device may not boot with this loader. Preparing Loader...Done Sending Loader [8909_037]...Write Error! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 6.0 |
The Following User Says Thank You to Agapito86 For This Useful Post: |
09-11-2020, 16:09 | #127 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Quote:
Br, UMT | |
09-12-2020, 10:02 | #131 (permalink) |
No Life Poster Join Date: Jan 2010 Location: fontecno
Member: 1201378 Status: Offline Sonork: 100.1594717 Thanks Meter: 303 | Mi 8 dippe Account Remove FOR FREE WITH UMT ALL THANKS TO UMT FOR THE HARD WORK THIS IS WHY I HAVE ALWAY BELIVE IN YOU GUYS AND I WILL ALWAY ACTIVATE ALL UR TOOL. Operation : Reset Mi Account Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM40) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1B00800 [SDM845] 00007200 OPK_DATA : 99AF649E077EBCE3E9E187442ABDC70BD715756DE9ED192E9F 7883A10EBE09F4 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [SDM845]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Requesting UMT Auth Service (FREE)...OK Detecting Chip Type...OK Hardware : SDM845, UFS, 64 GB LU Count : 6 [0x00DC0800] [0x00000800] [0x00000800] [0x00002000] [0x00120000] [0x00002000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [65536], Out: 262144, Sector Size: 4096 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Software : , V11.0.5.0.QEAMIXM [Mon Jul 6 18:48:15 CST 2020] Android Ver. : 10 Patch Level : 2020-06-01 Resetting Mi Account Data...Done Preparing Data...Done Formatting Userdata...Done When phone is completely ON, connect to Internet and add Mi Account. -------------- INFORMATION -------------- New Firmware may cause hang on logo. In such case, you need to flash phone to recover. Or downgrade firmware and try Reset Mi Account again. Operation Finished. QcFire Ver. 6.0 |
The Following 2 Users Say Thank You to FON-TECNO For This Useful Post: |
09-12-2020, 14:57 | #133 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: india Age: 47
Member: 196194 Status: Offline Thanks Meter: 47 | redmi 6 pro mi accoumt removed thanks umt team Quote:
The Following 2 Users Say Thank You to shoeb7 For This Useful Post: |
09-13-2020, 18:54 | #135 (permalink) | |
Member: 2804958 Status: Offline Thanks Meter: 79 | Quote:
Or an UMT TEAM do something about these new NEW SMART FEATURE PHONES devices Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM8) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1400900 [8909] 50004200 OPK_DATA : 2F467D27EF09F251CBE50AE2E73C44F55360B6818775E73D40 F90D81778E04E2 Initializing Protocol...OK Using Auto Loader Selection [4] No compatible loader found. Device may not boot with this loader. Preparing Loader...Done Sending Loader [8909_037]...Write Error! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 6.0 | |
