02-25-2023, 13:30 | #1 (permalink) |
No Life Poster Join Date: Apr 2013 Location: morocco Age: 36
Member: 1917054 Status: Offline Thanks Meter: 268 | Can poco x3 nfc be updated in sideload mode Operation : Flash Miui Package (Sideload) Searching for phone in sideload mode...Found Device Id : surya_global Version : V12.0.9.0.QJGMIXM Code Base : 10 Serial : 0x3460ffdf Ext Info : RU, ru, F, 2, 2 Model : M2007J20CG Package : miui_SURYAGlobal_V13.0.1.0.SJGMIXM_e6fc65cbd3_12.0 .zip Calculating Firmware Hash...OK Requesting Token...Failed Error : Sorry, flash to this stable version is not allowed. Operation Failed. QcFire Ver. 8.6 |
02-25-2023, 14:07 | #2 (permalink) |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,706 | hi there does your phone has Mi account lock issue and you want to bypass it? anyhow,the error you are facing is Xiomi server response not from our side Error : Sorry, flash to this stable version is not allowed. b.r. |
The Following User Says Thank You to bk.gsm For This Useful Post: |
02-25-2023, 15:01 | #4 (permalink) |
Member: 869809 Status: Offline Thanks Meter: 1,706 | it will not be done cuz as I said in my previous post that error you faced was from Xiomi side Xiomi has the ability to check the device before processing to upgrade any device via sideload mode,if the device has Mi account locked,it will not accept the update operation.. b.r. |
