11-13-2020, 07:51 | #1 (permalink) |
No Life Poster Join Date: Apr 2016
Member: 2561651 Status: Offline Sonork: 100.******* Thanks Meter: 292 | genral mobile 5d error how are you yesterday i got this device which is from turkey and for imei purpose i flash eng rom and device stuck in edl but before i make dump from another crack tool, but now the problem is its not accepting any FW giving this error i try many loader but still same Operation : Flash Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM41) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1507000 [8916] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A2 6AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8916_014]...Done Executing Loader...OK Detecting Chip Type...OK DebugData : UXVhbGNvbW0gSFMtVVNCIFFETG9hZGVyIDkwMDggKENPTTQxKT == Using Alternate Method... DebugData : UXVhbGNvbW0gSFMtVVNCIFFETG9hZGVyIDkwMDggKENPTTQxKT == Error getting Payload Information! Error Log : UXVhbGNvbW0gSFMtVVNCIFFETG9hZGVyIDkwMDggKENPTTQxKT == Please use correct loader and check USB port / cable. Operation Finish |
11-13-2020, 10:48 | #2 (permalink) |
Member: 2561651 Status: Offline Sonork: 100.******* Thanks Meter: 292 | and now its not detect even device here,s the log Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM41) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...Unknown Response! QcFire Ver. 4.7 |
11-13-2020, 11:52 | #3 (permalink) |
Member: 2561651 Status: Offline Sonork: 100.******* Thanks Meter: 292 | i got the same file from net, for this model and most important thing is this file readed by umt tool but when i try to flash so again same error Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM41) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1507000 [8916] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A2 6AB1B4B3F1CF9E Initializing Protocol...OK Sending Loader [prog_emmc_firehose_8952_ddr.mbn]...Done Executing Loader...OK Detecting Chip Type...OK DebugData : UXVhbGNvbW0gSFMtVVNCIFFETG9hZGVyIDkwMDggKENPTTQxKT == Using Alternate Method... DebugData : UXVhbGNvbW0gSFMtVVNCIFFETG9hZGVyIDkwMDggKENPTTQxKT == Error getting Payload Information! Error Log : UXVhbGNvbW0gSFMtVVNCIFFETG9hZGVyIDkwMDggKENPTTQxKT == Please use correct loader and check USB port / cable. |
11-15-2020, 19:15 | #5 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Team was waiting for you to read our response to such issues previously. This error means either: - phone battery is disconnected - some other software is trying to capture port - loader may not be good Br, UMT |
The Following User Says Thank You to U.M.T For This Useful Post: |
11-16-2020, 07:17 | #6 (permalink) |
Member: 2561651 Status: Offline Sonork: 100.******* Thanks Meter: 292 | ok team allow me to go more deeper to explain it, thanks for allowing i flashed this device already with auto loader via umt.... device fully flashed... but behind eng rom i flashed wrong rom again, and device back to 9008 after that i used other emmc crack tool to flash the device,,, and after that this issue becomes, and about your 3 points.... 1st batter should disconneted to edl model, for this device.... if i connected via battery so its giving this error Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM41) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...Unknown Response! QcFire Ver. 4.7 2nd trying to capture port! so i restarted whole pc and today try again but still this error Operation : Flash Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM41) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1507000 [8916] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A2 6AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8916_014]...Done Executing Loader...OK Detecting Chip Type...OK DebugData : UXVhbGNvbW0gSFMtVVNCIFFETG9hZGVyIDkwMDggKENPTTQxKT == Using Alternate Method... DebugData : UXVhbGNvbW0gSFMtVVNCIFFETG9hZGVyIDkwMDggKENPTTQxKT == Error getting Payload Information! Error Log : UXVhbGNvbW0gSFMtVVNCIFFETG9hZGVyIDkwMDggKENPTTQxKT == Please use correct loader and check USB port / cable. Operation Finished. and about your 3rd wrong loader, as i upper said, i already flashed once this device fully flashed with auto loader... but now i even changed loaders but after change the loader its giving loader error thanks team for your response |
11-16-2020, 07:32 | #7 (permalink) |
Member: 2561651 Status: Offline Sonork: 100.******* Thanks Meter: 292 | ok see this team, i even chose another loader but still same Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM41) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1507000 [8916] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A2 6AB1B4B3F1CF9E Initializing Protocol...OK Sending Loader [prog_emmc_firehose_8916.mbn]...Done Executing Loader...OK Detecting Chip Type...OK DebugData : UXVhbGNvbW0gSFMtVVNCIFFETG9hZGVyIDkwMDggKENPTTQxKT == Using Alternate Method... DebugData : UXVhbGNvbW0gSFMtVVNCIFFETG9hZGVyIDkwMDggKENPTTQxKT == Error getting Payload Information! Error Log : UXVhbGNvbW0gSFMtVVNCIFFETG9hZGVyIDkwMDggKENPTTQxKT == Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 4.7 |
11-23-2020, 10:28 | #9 (permalink) |
Member: 2561651 Status: Offline Sonork: 100.******* Thanks Meter: 292 | lates version not working due to forbidin 12 error, my pc have tv only i even unstalled but still detect, you guys make a auto run bat to deleted the all files which need to remove |
11-23-2020, 17:08 | #10 (permalink) | |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,706 | Quote:
and if u have any log to the phone info before flashing post it here b.r. | |
11-26-2020, 10:44 | #12 (permalink) |
No Life Poster Join Date: Oct 2005 Location: AsTeknik Elektronik
Member: 194874 Status: Offline Thanks Meter: 458 | General Mobila 5d FRP -------------------- Operation : Boot Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM9) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.1.2 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1507000 [8916] [00000000] Initializing Protocol... OK Preparing Firehose Loader... Done Sending Firehose Loader... Done Executing Loader... OK Hardware : 8916, eMMC, 16 GB Warning! High Speed Driver not installed. Please install driver from QcFire\Drivers folder. Payload Info : In: 65536 [4096], Out: 16384, Sector Size: 512 Reading Partition Table... OK Reading Device Information... OK Device : [msm8916] Software : NLC17B, 152 [2017年 01月 25日 星期三 12:15:16 CST] Android Ver. : 7.1.1 Resetting FRP Lock... . . . Done Remove cable, reconnect battery / hold Power Button ~15 seconds. |
