01-15-2021, 10:47 | #1 (permalink) |
No Life Poster Join Date: Oct 2015 Location: Pakistan
Member: 2478233 Status: Offline Thanks Meter: 596 | need unlock solution tps360 app lock [SOLVED] Operation : Read Information Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM40) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1009600 [8909] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A2 6AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [2] Preparing Loader...Done Sending Loader [8909_012]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8909, EMMC, 16 GB LU Count : 1 [0x01D1F000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : unknown TPS360 [msm8909] [msm8909] Brand : qcom Prod.Name : TPS360 Software : 20200728.150607, eng.20200728.150335 [2020年 07月 28日 星期二 15:03:35 CST] Android Ver. : 7.1.2 Patch Level : 2017-07-28 USERDATA : Normal You can use RESET LOCKS to remove Pin/Pattern/Password WITHOUT Data Loss. Operation Finished. QcFire Ver. 6.4 |
01-15-2021, 12:02 | #2 (permalink) |
Member: 2478233 Status: Offline Thanks Meter: 596 | Operation : Read Firmware Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM40) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1009600 [8909] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A2 6AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [2] Preparing Loader...Done Sending Loader [8909_012]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8909, EMMC, 16 GB LU Count : 1 [0x01D1F000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK USERDATA : Normal Reading Device Information...OK Device : unknown TPS360 [msm8909] [msm8909] Brand : qcom Prod.Name : TPS360 Software : 20200728.150607, eng.20200728.150335 [2020年 07月 28日 星期二 15:03:35 CST] Android Ver. : 7.1.2 Patch Level : 2017-07-28 Reading [modem]...Done Reading [sbl1]...Done Reading [sbl1bak]...Done Reading [aboot]...Done Reading [abootbak]...Done Reading [rpm]...Done Reading [rpmbak]...Done Reading [tz]...Done Reading [tzbak]...Done Reading [misc]...Done Reading [splash]...Done Reading [DDR]...Done Reading [sec]...Done Reading [boot]...Done Reading [system]...Done Reading [persist]...Done Reading [cache]...Done Reading [recovery]...Done Reading [oem]...Done Reading [userdata]...Done Reading [gpt_main0]...Done Reading [gpt_back0]...Done Saved to : C:\UMTool\QcFire\Read\unknown_TPS360_20200728.1506 07_2017-07-28\ Operation Finished. QcFire Ver. 6.4 |
01-15-2021, 15:08 | #3 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | If app is in Userdata in you can try format device, but less chance of luck. You may try to root it using QcFire and see if it works, and then remove APK, but even if you succeed to root, can you open settings to enable USB debugging? Br, UMT |
01-16-2021, 07:35 | #4 (permalink) |
Member: 2478233 Status: Offline Thanks Meter: 596 | no bro settings are disabled in old biomatric device it was easy to bypass than install any apk launcher it works flawlessly but this is lateset version andriod 7.0 thats why i cant bypass i dont want to delet compnay installted apps is there any other way that i can dump device and do experiments and after that i can restore tab to default softwear and installed apps using qc fire read firmware +dump user data ? |
01-16-2021, 09:25 | #5 (permalink) |
Member: 2478233 Status: Offline Thanks Meter: 596 | its telpo desk launcher apk which i want to install after that tab will be unlocked is there a way to uninstall a specific app form phone in edl mode bacause i cant able to open settings |
01-16-2021, 09:54 | #6 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | If you modify syatem and flash back, possibly it wont boot to system as boot is locked. Try rooting in EDL and check if works. Else you can restore original boot.img. Br, UMT |
01-16-2021, 11:03 | #7 (permalink) |
Member: 2478233 Status: Offline Thanks Meter: 596 | i did format with umt than from status bar i open settings enabled usb debuging enabled oem and did read info in adb mode after that tab again stuck on telpo launcher but now adb is enabled now what i do to install launcher |
01-16-2021, 14:02 | #8 (permalink) |
Member: 2478233 Status: Offline Thanks Meter: 596 | problem solved by formating and enetering in settings enabeld developer mode and usb debuging uninstall telpo desk everything works fine |
The Following User Says Thank You to Arslanmayo For This Useful Post: |
